CamaroTom 9 Posted August 24, 2015 Hey guys I know this hopup is hard to find but I'm piecing together a kit myself. I've found the carbon piece and the L parts tree does anyone have a part list of what else I need? Share this post Link to post Share on other sites
Droopy1975 39 Posted August 24, 2015 You can find what you need in the black special manual that is on the tamiyas USA site compare it with the avante 2011 manual. I also used the egress manual as I collected egress spare parts for this steering set. Share this post Link to post Share on other sites
Mokei Kagaku 2706 Posted August 24, 2015 The parts that you need for the BS steering which aren't included with the (regular) Avante 2011 are: 50587 3mm Spring Washers3405051 Steering Bridge9115328 L-Parts (Steering Bellcranks)9804510 5x6mm Hexagonal Bushings9805583 Steering Rod (70mm) + 4 pcs. 850 Ball Bearing 1 Share this post Link to post Share on other sites
CamaroTom 9 Posted August 24, 2015 The parts that you need for the BS steering which aren't included with the (regular) Avante 2011 are: 50587 3mm Spring Washers 3405051 Steering Bridge 9115328 L-Parts (Steering Bellcranks) 9804510 5x6mm Hexagonal Bushings 9805583 Steering Rod (70mm) + 4 pcs. 850 Ball Bearing Thank you so much! Share this post Link to post Share on other sites
94eg! 834 Posted August 27, 2015 If you are piecing this kit together for a runner, then I would not use the steering rod from the older Egress kit that you were looking at in the for-sale section. You should definitely use the newer 3mm x 70mm rod with 3mm rod ends. Much much less play in the steering system. Also use a hi-torque servo saver. The standard grey one is junk. Share this post Link to post Share on other sites
CamaroTom 9 Posted September 1, 2015 If you are piecing this kit together for a runner, then I would not use the steering rod from the older Egress kit that you were looking at in the for-sale section. You should definitely use the newer 3mm x 70mm rod with 3mm rod ends. Much much less play in the steering system. Also use a hi-torque servo saver. The standard grey one is junk. Thank you for the advice, the only place I found the newer rod you speak of was at modelsport uk so I ordered it. Share this post Link to post Share on other sites
