OCD 514 Posted October 13, 2007 - Does anyone know where I can find a complete list of 49XXX limited part numbers? I'm not necessarily interested in the kit #s, but rather the parts and hop-ups. An example would be special parts bags like the 49573 TA02 suspension arms moulded in white, or other 'limited' colors. I know I've seen white, orange, and fluorescent green or these particular parts, but I've would be interested to know if there were other colors. I do remember the Tamiya USA site having a 49000 parts category, but I can't seem to find it now.. maybe they took it down? -Steve 1 Share this post Link to post Share on other sites
Singapore_959 18 Posted October 15, 2007 I never understand when posts get alot of views but 0 responces so I am responding to your post at the least! I think it is a good question and I'd liek the answer too. Tamiya.com english site has some listed but not all. Perhaps one of our Japan based members can point to an online list.... ? Share this post Link to post Share on other sites
europro975 75 Posted October 17, 2007 Steve, I have a near complete list of all Tamiya's 49xxx Limited Edition part numbers. Email me and I'll send you a copy Antony Share this post Link to post Share on other sites
djmcnz 754 Posted October 17, 2007 Steve,I have a near complete list of all Tamiya's 49xxx Limited Edition part numbers. Email me and I'll send you a copy Antony Perhaps you could post it for all? No? Share this post Link to post Share on other sites
Singapore_959 18 Posted October 17, 2007 Perhaps you could post it for all? No? YES PLEASE! With neat little photos like the back of Tamiya Guides too....! Share this post Link to post Share on other sites
OCD 514 Posted October 18, 2007 Wow -Thanks for the response guys! - Sorry I hadn't noticed sooner, but my thread subscription thing doesn't seem to work anymore...? Anthony - I'd love to get a copy of the list as would many of the 'collectors' around here -- Any chance it's in a 'post-able' format? -Steve Share this post Link to post Share on other sites
europro975 75 Posted October 18, 2007 Here's the list: Tamiya 49xxx Limited Edition Parts 49001-49020 ????? 49021 2WD FRONT Day Glow Wheel Set (Red) 49022 2WD FRONT Day Glow Wheel Set (Yellow) 49023 2WD Front Day-Glow Wheel Set (Green) 49024 2WD Rear Day-Glow Wheel Set (Red) 49025 2WD Rear Day-Glow Wheel Set (Yellow) 49026 2WD Rear Day-Glow Wheel Set (Green) 49027-49036 ????? 49037 Low Friction Aluminum Damper (Blue 1 Pair) 49038 One Piece 5 Spoke Wheel (Black, 1 Pair) 49039 M-Chassis Heat Sink (Blue) 49040 Mini Cooper Wheels (Yellow, 1 Pair) 49041 Mini Cooper Wheels (Red, 1 Pair) 49042 Mini Cooper Wheel Set (Blue, 1 Pair) 49043 Mini Cooper Wheels (White, 1 Pair) 49044 M-Chassis A Parts (Moss Green) 49045 M-Chassis B Parts (Moss Green) 49046 5mm Adjuster Red 49047 M-Chassis Number Sticker Mini Cooper 49048 Nylon Band with Metal Hook (Blue) 49049 Nylon Band with Metal Hook (Yellow) 49050 Nylon Band with Metal Hook (Green) 49051 Nylon Band with Metal Hook (Orange) 49052 Nylon Band with Metal Hook (Dark Red) 49053-49066 ????? 49067 Aluminum King Pins Red 49068 Aluminum King Pins Blue 49069 TA03 Super Low Friction Damper Blue 49070 TA03 Super Low Friction Damper Purple 49071 5mm Alu. Ball Connector (Red) 49072 5mm Alu. Ball Connector (Blue) 49073 TA03 Aluminum Pulley (Blue, 16T) 49074 TA03 Aluminum Pulley (Red, 16T) 49075 Carbon Reinforced 1-piece 5-spoke Wheel 49076 Lancia Rally Body Parts Set (Re-Issue) 49077 Porsche Boxster Front Carbon-Reinforced Wheel 49078 Porsche Boxster Rear Carbon-Reinforced Wheel 49079 CVA Mini Shock II - Transparent 49080 Not Used 49081 Not Used 49082 Rover Mini Cooper Complete Kit 49083 Fiat Abarth 1000TCR Berlina Corsa Complete Kit 49084 Honda S-MX Lowdown Complete Kit 49085 Porsche Boxster Complete Kit - M02L 49086 Mercedes-Benz SLK Complete Kit 49087 CVA Mini Shock Unit II - Transparent 49088 CVA Super Mini Shock Unit Set Transparent 49089 TA03 Super Low Friction Damper - Metallic Black 49090 5mm Aluminum Ball Connector - Purple 49091 TA03 Lightweight Drive Shaft Purple 49092 Aluminum Servo Stay Blue 49093 Aluminum Servo Stay Purple 49094 4mm Alum Flange Lock Nuts - Red/Blue (2pcs each) 49095 Countach LP500S Re-issue 1/10 Body Parts Set (White). 49096 Aluminum Servo Stay - Pink 49097 TA03 Alum Front Hub Carrier - Blue 49098 TA03 Universal Drive Shaft - Pink 49099 TA03 Low Friction Damper - Silver/Blue 49100 TA03 Low Friction Damper - Silver/Pink 49101 Aluminum King Pins Pink 49102 Aramid Fiber Drive Belt - TA03F/R Blue 49103 TA03FS & RS Reinforced Drive Belt Red 49104 Glass Tape Blue 49105 Glass Tape Red 49106 Glass Tape Black 49107 Antenna Pipe (black) 49108 TA03 Carbon Reinforcing Plate - Blue 49109 TA03 Carbon Reinforcing Plate Black 49110 TA03 A Parts (Gear Case) - Black 49111 TA03 B Parts (Rr Gear Case) - Black 49112 TA03 D Parts (Sus Arm) - Black 49113 1/12 Celica LB Turbo GR.5 Body Set 49114 Damper oil #900 2 set 49115 TA03 Pully Stopper 49116 Piston Set for 53280????? 49117 Clear Silicon Damper Seals (???) 49118 ????? 49119 ????? 49120 Lightweight Aluminum Wheel Hub 49121 TA03 Stabilizer Stopper Set 49122 Damper Air Remover 49123 Damper Tune-up Set 49124 ????? 49125 ????? 49126 Porsche 911 GT1 Lightweight Body Parts Set 49127 TRF Original Sticker 19128 ????? 49129 ????? 49130 Stealth Box 49131 ????? 49132 TRF414 Chassis Kit 49133 ????? 49134 ????? 49135 ????? 49136 ????? 49137 ????? 49138 Tyrrell P34 Six Wheeler Body Parts Set 49139 TA03R-S TRF Special Chassis Kit w/Lightweight Body 49140 Aluminum Setting Wheel 49141 TA04 TRF Pro Special Damper (1 Pair) 49142 Lt Wgt Alum Wheel Hub - Thick 49143 ????? 49144 Camber Gauge 49145 Impreza WRC Body - Painted 49146 Calsonic Skyline GT-R (R34) Lightweight Body Parts Set 49147 Bag 49148 Subaru Impreza WRC (Fully Assembled w/RC Unit) - TGX 49149 TGX-Mk.1 SUBARU IMPREZA WRC Complete Kit 49150 ????? 49151 ????? 49152 ????? 49153 ????? 49154 Tyrrell P34 Six Wheeler Kit 49155 ????? 49156 3x8 Round Hex Head Screw 49157 3x10 Round Hex Head Screw 49158 3x12 Round Hex Head Screw 49159 3x14 Round Hex Head Screw 49160 3x8 Countersunk Hex Screw 49161 3x10 Countersunk Hex Screw 49162 3x16 Countersunk Hex Screw 49163 Countersunk Washer for Hex Screw 49164 Hex Wrench Driver - 1.5, 2mm 49165 Screw Case 49166 Juggernaut 2 Anodized Chassis Frame Set (Blue) 49167 Juggernaut 2 Anodized Chassis Frame Set (Red) 49168 Juggernaut 2 Bumper Blue 49169 Juggernaut 2 Bumper Red 49170 Esso Ultron Tiger Supra Kit - TGX 49171 7.2V Racing Pack 1700MP Battery 49172 TG10 Mk.1 PRO Racing - Long Suspension w/Body Kit 49173 TRF414M Custom Pack M 49174 Mad Bull Special Complete Kit 49175 TRF414M Chassis Kit 49176 Subaru WRC 2001- TG10 49177 Ferrari 312T3 Body Parts Set 49178 ????? 49179 Body Set Ferrari Modena - Light Weight Body Set 49180 GP Body Set CLK DTM 2000 - Original Teile Finished Body 49181 Unimog U300 Complete Kit (Orange) 49182 Unimog U300 Complete Kit (Green) 49183 Medium Narrow Dish Wheels - Flou.Yellow (Offset 0) 49184 Not Used 49185 Harbour Boat 49186 Unimog Hunter 49187 F1 Body Parts Set 49188 Body Set Corvette C5-R - Finished Body (blue) 49189 ????? 49190 Dyna Storm (Re-Release) 49191 Ferrari 312T3 - F103RS 49192 Bus 49193 ????? 49194 TA04 Aluminum Steering Post Blue 49195 TA04 Aluminum Steering Arms - Blue 49196 Short Aluminum Servo Stays - Blue 49197 4mm Turnbuckle Wrench - Blue 49198 TRF Damper Set - Blue 4pcs 49199 TA04 Aluminum Motor Heat Sink - Blue 49200 TA04 Universal Shaft Set 49201 TA04 Rr Universal Shaft Set - Lightweight Assembly 49202 TA04 Aluminum Hub Set for Spur Gear Blue 49203 TA04 Reinforced Gear Case 49204 Dish Wheel (+0, Blue) 49205 Dish Wheel (+0, Magenta) 49206 Body Set HKS Racing Altezza 49207 TA04 PRO Blue Collection 49208 Body Set HKS Racing Altezza - Carbon 49209 Tiger I Early Production Photo Etched Grille Set 49210 ????? 49211 1 / 12 Smart Cabrio (Red) 49212 1 / 12 Smart Cabrio (Blue) 49213 1 / 12 New Mini Cooper (Yellow) 49214 1 / 12 New Mini Cooper (Blue) 49215 Power Loader 49216 Power Shovel 49217 1 / 12 Smart Cabrio (Grey) 49218 1 / 12 New Mini Cooper (Green) 49219 TRF414M2 Chassis 49220 TRF414M Champion Memorial Chassis Kit ????? 49221 ????? 49222 Lotus 79 Body Parts Set (Re-Release) 49223 Ferrari F40 GT Body (200mm) Body Parts Set 49224 Car Maintenance Stand - Blue 49225 Camber Gauge - Black 49226 Height Gauge (Blue) 49227 Wheel Wrench - Blue 49228 Pinion Gear Holder (Blue) 49229 TRF Sticker B - Blue/Yellow 49230 Hard Coated 0.6 Alumium Pinion Gear (27T/TA-04) 49231 Hard Coated 0.6 Alumium Pinion Gear (22T/TB-01) 49232 Hard Coated 0.6 Alumium Pinion Gear (19T/TL-01) 49233 Hard Coated 0.4 Aluminum Pinion 39T/TA04 49234 Hard Coated 0.4 Alumium Pinion Gear (35T/TB-01) 49235 Hard 0.6 Spur Gear - (83T/TA04) 49236 Hard 0.6 Spur Gear - (55T/TB-01, F201) 49237 Hard 0.4 Spur Gear - (120T/TA04) 49238 Hard 0.4 Spur Gear - (88T) TB01 49239 TRF Sticker B Gold/Silver 49240 Matched Spring Set - Soft 4pcs 49241 Matched Spring Set - Medium 4pcs 49242 Matched Spring Set - Hard 4pcs 49243 Aluminum Stabilizer End Blue 4pc 49244 5mm Aluminum Ball Nuts - Blue 10pcs 49245 TRF Special Damper Retainer - Blue 4pcs 49246 TRF Sticker B - Blue/Pink 49247 Super Stock Motor Type S 49248 Pit Bag w/3 Box (Navy Blue) 49249 TB Evolution II Suspension Setting Parts 49250 Datsun 280ZX Body Parts Set (Reissue) 49251 Mercedes Trailer Truck (Red) 49252 ????? 49253 ????? 49254 TRF 2002 ESC 49255 TRF414M World Champion Replica Chassis Kit 49256 ????? 49257 ????? 49258 TRF414 Front Stabilizer - World Champion Replica 49259 Tire Warmer 49260 Super Stock Motor Type RR 49261 1 / 12 Mercedes-Benz SL500 (Silver) 49262 1 / 12 Mercedes-Benz SL500 (Black) 49263 Body Set 360 Modena - Ltd Carbon 49264 Body Set Skyline R34 - Ltd Carbon 49265 Body Set Toyota MR-S - Ltd Lightweight 49266 TRF Setting Board - Ltd 49267 TRF Tool Set - Ltd 49268 7.2v Racing Pack RC2400SP Zapped Type 49269 TRF414M Lightweight Front Bulkhead 49270 TRF414M Lightweight Rear Bulkhead 49271 TRF414M Lightweight Motor Plate 49272 TRF414M SSG Carbon Upper Deck 49273 TRF414M SSG Carbon Lower Deck - Ltd 49274 TRF414M SSG Carbon Front Damper Stay 49275 TRF414M SSG Carbon Rr Damper - Ltd 49276 Body Set Raybrig NSX 2002 - Ltd Lightweight 49277 Body Set Nissan 350Z - Ltd Carbon Pattern 49278 TA04 TRF - Ltd 49279 Body Set Raybrig NSX 2002 - Ltd Carbon Pattern 49280 Body Set Toyota MR-S - Ltd Carbon Pattern 49281 ????? 49282 ????? 49283 TB-Evo.3 Surikarn Ltd. - Ltd 49284 ????? 49285 ????? 49286 ????? 49287 Sport Tuned Mortor for XB Cars 49288 Super Stock Motor Type RR (Gun Metal Case) 49289 ????? 49290 Setting Board (Red) 49291 Maintenance Stand (Red) 49292 TRF Tool Set (Red) 49293 TRF Damper Set - Fluorine Coated Blue 49294 TRF Damper Set - Fluorine Coated Red 49295 Toyota Celica GT-FOUR RC Body 49296 Subaru Brat Body 49297 TA04R Tuned Chassis Kit - Ltd 49298 RD F-1 Spoke Wheel Set 3630F/3645R (Black) 49299 Ball Diff Spring 49300 620 Ball Thrust Bearing (2pcs). 49301 ????? 49302 Matched Spring Soft (2 Pcs.) 49503 Matched Spring Medium (2 Pcs.) 49304 Matched Spring Hard (2 Pcs.) 49305 Matched Spring Extra-Hard (2 Pcs.) 49306 TRF Sticker B (Red Tone) 49307 TRF Sticker B (Blue Tone) 49308 TRF Damper Aluminum Top End (Blue) 49309 TRF Damper Cylinder Cap Set Blue 49310 TRF Damper Cylinder Nut (Blue) 49311 TRF Damper Aluminum Retainer (Blue) 49312 TRF Damper Aluminum Top End - Red 49313 TRF Damper Cylinder Cap - Red 49314 TRF Damper Cylinder Nut - Red 49315 TRF Damper Aluminum Retainer - Red 49316 3x18mm Aluminum Turnbuckle Shafts Blue 49317 3x23mm Aluminum Turnbuckle Shafts Blue 49318 3x32mm Aluminum Turnbuckle Shafts Blue 49319 3x35mm Aluminum Turnbuckle Shafts Blue 49320 LW Aluminum Servo Stay - Blue 49321 5mm Aluminum End Cap for Body Mount Blue 49322 6mm Aluminum End Cap for Body Mount Blue 49323 3x18mm Aluminum Turnbuckle Shafts Red 49324 Alum Turnbuckle Shafts - 3x23mm Red 2pcs 49325 Alum Turnbuckle Shafts - 3x32mm Red 2pcs 49326 3x35mm Aluminum Turnbuckle Shafts Red 49327 LW Aluminum Servo Stay - Red 49328 5mm Aluminum End Cap for Body Mount Red 49329 6mm Aluminum End Cap for Body Mount Red 49330 1 / 12 Mercedes-Benz ML55 AMG (Red) 49331 1 / 12 Mercedes-Benz ML55 AMG (Silver) 49332 1 / 12 BMW Z8 (Red) 49333 1 / 12 BMW Z8 (Yellow) 49334 1 / 12 Opel Speedster (Silver) 49335 TB Evo III Conversion Parts - Blue 49336 F201 Tuned Chassis Kit - F201 49337 Wild Willy 2 - Metallic Special 49338 ????? 49339 Body Set Raybrig NSX 2003 - Lightweight 49340 Body Set Xanavi Nismo GT-R - Lightweight 49341 TRF415 Lower Deck - for Stick Type Battery 49342 TRF415 Motor Mount Bulkhead Heat Sink Type 49343 TRF415 Belt Stabilizer 49344 TRF415 Heat Sink Beam 49345 TB Evo IV Titanium Screws 49346 TRF415 LW Suspension Set - Reversible 49347 Transpeed MS Motor 9T 49348 TB-02R Chassis Kit 49349 TRF415MS Chassis Kit LE - Limited Edition 49350 2x25mm Cap Screw - w/2mm Lock Nut 49351 TRF415MS World Champ Parts 49352 Impreza WRC 2004 - TL01RA 49353 TB Evolution IV MS - TBEVOIV 49354 Tamiya Pit Case - Blue 49355 TRF Damper Special Blue 49356 TB Evolution IV Aluminum Center Post 49357 TB Evolution IV Seperate Motor Mount MS 49358 TRF415 Front Direct Coupling (Spool) 49359 TB Evo IV Front Direct Coupling (Spool) 49360 TA05 Titanium Screw Set 49361 6-Spoke Setting Wheels (Blue) 49362 TB Evo IV Gear Cover - Smoke 2pcs 49363 TB Evo IV Gear Cover - Clear Blue 2pcs 49364 TB-02R Front Carbon Brace Set 49365 TB-02R Rear Carbon Brace Set 49366 TB02R Battery Plate 49367 TB-02 Aluminum Racing Steering Set (Blue) 49368 TB-02 Aluminum Motor Mount (Blue) 49369 TB-02R LW Aluminum Propeller Shaft Blue TB02 49370 F201 Aluminum Racing Steering 49371 F201 7mm Ball Connector - 2pcs Titanium 49372 TB Evo IV Gear Cover - Red 2pcs ????? 49373 TNX Pro-Line Special 49374 Body Set Subaru Legacy B4 - Lightweight 49375 Body Set Xanavi NISMO Z - Lightweight 49376 Body Set Raybrig NSX 2004 - Lightweight 49377 TA03F Pro Drift Spec Chassis Kit 49378 TRF415MSX Up-Grade Parts 49379 Antenna Pipes Fluor. Blue 49380 7mm Snap Pin Blue 5pc 49381 TRF415MSX 49382 On Road Tuned Hard Spring Set White 49383 TA05 Stabilizer Set F/R Black 49384 TRF415MSX Screw Set Titanium & Aluminum 49385 TRF415MSX Lower Deck - for Stick Type Battery 49386 Transpeed MS Motor 10T 49387 Porsche 911 GT2 Body Parts Set 49388 TA05 Carbon Reinforced Damper Stay 49389 On Road Tuned Hard Spring Set Milky Blue 49390 TA05 Bulkhead Clear Blue 49391 TA05 Upper Brace F R (Clear Blue) 49392 TB Evolution 5 Stabilizer Rod Set 49393 TB Evolution 5 Screw Set (Titanium & Aluminum). 49394 TRF415MSX Marc Rheinard Ed. 49395 TB Evolution 5 Stabilizer Rod Set Black 49396 TB Evolution 5 Gear Cover Clear Blue 49397 TB Evolution 5 Gear Cover Clear Smoke 49398 TB Evolution 5 Bumper Clear Blue 49399 TB Evolution 5 Bumper Clear Smoke 49400 Porsche Turbo RSR Type 934 - TA05 49401 TRF501X 49402 MN 6-Spoke Wheel Clear - +2 49403 Medium Narrow 6 Spoke Wheels Clear Blue 49404 MN 6-Spoke Wheel Smoke - +2 49405 Medium Narrow Dish Wheels Clear Offset O 49406 MN Dish Wheel Clear Blue - +/-0 49407 MN Dish Wheel Smoke - +/-0 49408 MN Mesh Wheel Clear - +2 49409 Medium Narrow Mesh Wheels Blue Offset +2 49410 Medium Narrow Mesh Wheels Smoke Offset +2 49411 MN 18-Spoke Clear - +/-0 49412 MN 18-Spoke Clear Blue - +/-0 49413 MN 18-Spoke Smoke - +/-0 49414 TA05 Stabilizer Set F/R Milky Blue 49415 Body Set Mobil 1 SC430 LW 49416 Carbon Bumper Support - TRF415 49417 M-03R Chassis Kit - M03 49418 TA05-R Chassis Kit - TA05 49419 TRF415MSXX 49420 Body Set Suzuki Swift - Lightweight 49421 Medium Narrow Dish Wheels - Fluorescent Yellow/0 Degrees 49422 Medium Narrow Dish Wheels - Fluorescent Pink/+2 Degrees 49423 Fluorescent Orange Medium Narrow Wheels 49424 Medium Narrow Mesh Wheels - Blue Plated/+2 Degrees 49425 TA05 Aluminum Differential Joint Blue 49426 TRF415 Aluminum Diff Joint - Blue 49427 TA05 Battery Plate Set (Blue) 49428 TA05 Center Plate Blue 49429 TRF415MSXX Upper Deck (Blue) 49430 TRF415MSXX Lower Deck (Blue) 49431 DF03 Setting Spring White 49432 DF03 Propeller Shaft - Blue 49433 DF03 Gearbox Plate Blue 49434 DF03 Gear Cover - Smoke 49435 DF03 Damper Cylinder Blue DF-03 49436 TRF415MSXX Lower Deck Set - For Stick Type Battery 49437 1/16 Panther G Grille Set - Photo Etched Grille 49438 Body Set NISMO R34 - Lightweight 49439 Body Set NISMO Silvia - Lightweight Coppermix 49440 TA05 Aluminum Center Plate (Blue) 49441 Aluminum Front Upright Blue M03 M04 FF02 49442 Aluminum Rear Upright Blue M03 M04 49443 M03R Aluminum Servo Mount - Blue 49444 M03R Aluminum Heat Sink Blue 49445 AM Crystal Set for Expec (01) 49446 AM Crystal Set for Expec (02) 49447 AM Crystal Set for Expec (03) 49448 AM Crystal Set for Expec (04) 49449 AM Crystal Set for Expec (05) 49450 AM Crystal Set for Expec (06) 49451 AM Crystal Set for Expec (07) 49452 AM Crystal Set for Expec (08) 49453 AM Crystal Set for Expec (09) 49454 AM Crystal Set for Expec (10) 49455 AM Crystal Set for Expec (11) 49456 AM Crystal Set for Expec (12) 49457 Toyota Hilux 4x4 Pick Up Body Parts Set 49458 TB02 Drift Spec Chassis Kit 49459 Lunch Box Gold Edition 49460 RTR TNX 5.2R Gold Ed. - TGM04 4x4 Custom Monster Truck 49461 M-Chassis 11-Spoke Wheels - 4pcs Black 49462 TA05 Urethane Bumper Black - Ltd 49463 TRF415 Urethane Bumper - Ltd Black 49464 GB01 Setting Spring Set - White 49465 TT Setting Spring Set - White/Short 49466 M03 Blue Plated Frame Set 49467 M-Chassis 11-Spoke Wheels - 4pcs Blue 49468 M-Chassis 11-Spoke Wheels - 4pcs Silver 49469 M-Chassis 11-Spoke Wheels - 4pcs Fluorescent Yellow 49470 M-Chassis 11-Spoke Wheels - 4pcs Fluorescent Orange 49471 TA05 One-Way Pulley 36T - Ltd Wide Pitch Black 49472 TA05 Diff Pulley 36T - Ltd Wide Pitch Black 49473 06 Module Pinion Gear (22T) - Ltd Hard Coated Aluminum 49474 3mm Countersunk Washer - Ltd 10pcs Blue 49475 DT-02 MS - DT02 49476 DF03 Gear Cover - Ltd Blue 49477 TA05 Body Mount Set - Ltd Blue 49478 TA05 Body Mount Set - Ltd Smoke 49479 TA05 Body Mount Set - Ltd Clear 49480 TRF415 Body Mount Set - Ltd Blue 49481 TRF415 Body Mount Set - Ltd Smoke 49482 TRF415 Body Mount Set - Ltd Clear 49483 Body Set Mini Cooper Racing - Ltd Lightweight 49484 Body Set Mazda RX-7 - Ltd Lightweight 49485 Body Set EBBRO 350R - Ltd Lightweight 49486 NISMO Coppermix Silvia - TB02 Drift Spec 49488 TRF416 Titanium Screw Set - Ltd Very Early Limited Edition Parts 49500 Not Used 49501 The Grasshopper II Super G 49502-49507 Not Used 49508 ????? 49509 Manta Ray QD Black Special Ltd Edition 49510 German Flakpanzer Gepard Kit 49511-49532 Not Used 49533 ????? 49534 Flourescent Color Cable 7.2V Connector Set 49535 Fluorescent Silicone Insulated Wires (Green & Yellow) 49536-49538 ????? 49539 RD Flourescent Green 70T Plastic Gear 49540 RD Fluorescent Pink 70T Plastic Gear Set 49541 RD Yellow 0.4 Spur Gear Set 94T, 104T 49542 ???? 49543 TA01 Flourescent Yellow Suspension Arm 49544 Tamiya Touring/Rally Car Flourescent Green Suspension Arm 49545 Tamiya Fluorescent Green Adjuster Set 49546 Tamiya Fluorescent Pink Adjuster Set 49547-49550 ????? 49551 Manta Ray TA01 Flourescent Orange Chassis 49552 Manta Ray TA01 Flourescent Green Chassis 49553 ????? 49554 ????? 49555 4WD Rally Car Flourescent Orange Damper Spring 49556 ????? 49557 4WD Rally Car Flourescent Yellow Damper Spring 49558 4WD Rally Car Flourescent Pink Damper Spring 49559 ????? 49560 4WD/FWD Touring & Rally Car Plated Spoke Wheels 49561-49566 ????? 49567 Acto-Power TRF Tuned Motor 49568-49572 ????? 49573 TA02 Chassis White Suspension Arms (F & R). 49574 FWD Touring Car White Suspension Arms (F & R) 49575 Manta Ray White Suspension Arms (F & R) 49576 Castrol Celica Chrome Plated Wheel 4pc 49577 CVA Mini Shock Unit Set II White 49578 ????? 49579 ????? 49580-49591 Not Used 49592 Sauber C12 `94 Tamiya All Japan Champion Special 4593-49594 Not Used 49595 ????? Rare Limited Edition Event Parts 92179 Mini Cooper Racing Union Jack Sticker 94003 RD Mesh Wheel Set Silver 94023 Mazda 787B Silver Wheel Set 94025 2WD Front Star-Dish Wheels (1 Pair) (Silver) 94027 6029 Rear Star-Dish Wheels (1 Pair) (Silver) 94102 Alfa Romeo 155 Silver Spoke Wheels 94148 Opel Calibra Chrome Wheels Limited Edition Parts (New 42xxx Part Number Series) 42101 RC Pit Bag L - w/3 Inner Boxes 42102 TRF Special Damper Set - Hard Black Coating 42103 TA05MS Chassis Kit 42104 TRF415 MSXX - Marc Rheinard Edition 2007 42105 TRF501X World Championship - World Championship Edition 42106 TRF416 Chassis Kit If any one can fill in the missing ones, please let me know and I'll edit the list. I believe part numbers 49001-49020 were the Coloured (Red, Yellow & White?) Oval Block and Pin Spike Tyres?? There is a complete list of the above in Tamiya's 30th Perfect Album, but it's all in Japanese (Edited 18/10/07 12.45pm) 2 1 Share this post Link to post Share on other sites
djmcnz 754 Posted October 18, 2007 ^^^ = Legend Thank you. Share this post Link to post Share on other sites
bjr250 23 Posted October 18, 2007 I will see if I can get the other half to do some translation on the missing ones but it will take a few days untill she has time. This one I can do. 49051 Nylon Band with Metal Hook (Orange) Share this post Link to post Share on other sites
94eg! 834 Posted October 18, 2007 49535 = Fluorescent Silicone Insulated Wires (Green & Yellow Acto Power color) PS: That's an awesome list man. Thanks!!! Share this post Link to post Share on other sites
OCD 514 Posted October 18, 2007 Thanks so much Tony - (Sorry, no more beer smiley) Once this list is near completion it should be permanently posted somewhere on the site. This is indispensable information for Tamiya collectors! -Steve Share this post Link to post Share on other sites
OCD 514 Posted October 18, 2007 - ..and so many limiteds I didn't know about! I'd love to know the release dates as well - gotta get me that book! I thought I had seen all of the TA03 series hop-ups, but I noticed a few I haven't. Have yet to come across the 49069 blue dampers. -49117 Clear Silicon Damper Seals: Never knew about these -- Would look lovely with the transparent CVAs! and what's with the 49251 Mercedes Trailer Truck (Red) Wasn't aware of this - A limited Semi truck!?!? -S Share this post Link to post Share on other sites
OCD 514 Posted October 18, 2007 - And this: 49295 Toyota Celica GT-FOUR RC Body Limited? Tamiya's parts numbering system is nuts OK - I gotta go to bed now -S Share this post Link to post Share on other sites
Singapore_959 18 Posted October 18, 2007 This is a F A N A S T I C addition to TC. THANK YOU! Share this post Link to post Share on other sites
Singapore_959 18 Posted October 18, 2007 .... and now I know NINE emoticons are the max in any one post Share this post Link to post Share on other sites
peejay 0 Posted October 18, 2007 I can't remember where I got this from, but credit to whomsoever it is due Tamiya_49xxx_parts.pdf Share this post Link to post Share on other sites
europro975 75 Posted October 18, 2007 Cheers Guys, it's taken me 6 months of research to get the near complete list I have updated it with the extra ones. For those that have the Perfect Album, it also gives you the release date of the Limited Edition parts Share this post Link to post Share on other sites
bjr250 23 Posted October 22, 2007 This is the above list with translations form the Tamiya RC 30 Years Perfect Album in blue. I have my fiance to thank for doing this; I now owe her a huge favour. Tamiya 49xxx Limited Edition Parts 49001 2WD Front Tyre (Red) 49002 2WD Front Tyre (Yellow) 49003 2WD Front Tyre (White) 49004 Oval Block Tyre Front (Red) 49005 Oval Block Tyre Front (Yellow) 49006 Oval Block Tyre Front (White) 49007 Oval Block Tyre Rear (Red) 49008 Oval Block Tyre Rear (Yellow) 49009 Oval Block Tyre Rear (White) 49010 Pin Spike Tyre Front (Red) 49011 Pin Spike Tyre Front (Red) 49012 Pin Spike Tyre Front (Yellow) 49013 Pin Spike Tyre Front (White) 49014 Pin Spike Tyre Rear (Red) 49015 Pin Spike Tyre Rear (Yellow) 49016 Pin Spike Tyre Rear (White) 49017 2WD Wheel Set Front and Rear (White) 49018 2WD Wheel Set Front and Rear (Silver) 49019 4WD Wheel Set Front and Rear (White) 49020 4WD Wheel Set Front and Rear (Silver) 49021 2WD FRONT Day Glow Wheel Set (Red) 49022 2WD FRONT Day Glow Wheel Set (Yellow) 49023 2WD Front Day-Glow Wheel Set (Green) 49024 2WD Rear Day-Glow Wheel Set (Red) 49025 2WD Rear Day-Glow Wheel Set (Yellow) 49026 2WD Rear Day-Glow Wheel Set (Green) 49027 1 Piece Racing Spoke Wheel (Gold plated) 49028 1 Piece Racing Spoke Wheel (Silver plated) 49029 1 Piece Racing Spoke Wheel (Blue plated) 49030 RC Parts Case 49031 RCC Wing Duct Set 49032 M Chassis 60D Super Grip White Wall Tyre 49033 Flexible Sticker (Carbon) 49034 Flexible Sticker (Smoke) 49035 Flexible Sticker (Transparent) 49036 Fluorescent High Torque Servo Saver (Orange) 49037 Low Friction Aluminum Damper (Blue 1 Pair) 49038 One Piece 5 Spoke Wheel Black 1 Pair 49039 M-Chassis Heat Sink (Blue) 49040 Mini Cooper Wheels Yellow 49041 Mini Cooper Wheels Red 49042 Mini Cooper Wheel Set Blue 49043 Mini Cooper Wheels (White, 1 Pair) 49044 M-Chassis A Parts (Moss Green) 49045 M-Chassis B Parts (Moss Green) 49046 5mm Adjuster Red 49047 M Chassis Number Sticker Mini Cooper 49048 Nylon Band with Metal Hook (Blue) 49049 Nylon Band with Metal Hook (Yellow) 49050 Nylon Band with Metal Hook (Green) 49051 Nylon Band with Metal Hook (Orange) 49052 Nylon Band with Metal Hook (Dark Red) 49053 2ch 1ESC 1 Servo (Wheel Control) Radio Set 49054 2ch 1ESC 2 Servo (Stick)Radio Set 49055 2ch 2 Servo (Yacht-Use) Radio Set 49056 4ch 1ESC 2 Servo Radio Set 49057 Stainless Snap Pin (Large) 49058 Stainless Snap Pin (Small) 49059 No. 900 Damper Oil (9cc) 49060 Colour Antenna Pipe (Red) 49061 Colour Antenna Pipe (Blue) 49062 Colour Antenna Pipe (Black) 49063 Colour Antenna Pipe (Purple) 49064 RC Yacht Use 2Ch 2 Servo Radio Set 49065 1/8 Engine RC Car-Use 2ch 2 Servo Radio Set 49066 C.V.A Damper Mini (II) White 49067 Aluminium King Pins (Red) 49068 Aluminium King Pins (Blue) 49069 TA03 Super Low Friction Damper (Blue) 49070 TA03 Super Low Friction Damper (Purple) 49071 5mm Alu. Ball Connector (Red) 49072 5mm Alu. Ball Connector (Blue) 49073 TA03 Aluminum Pulley (Blue, 16T) 49074 TA03 Aluminum Pulley (Red, 16T) 49075 Carbon Reinforced 1-piece 5-spoke Wheel 49076 Tamiya Lancia Rally Body Parts Set (Re-Issue) 49077 Porsche Boxster Front Carbon-Reinforced Wheel 49078 Porsche Boxster Rear Carbon-Reinforced Wheel 49079 CVA Mini Shock II - Transparent 49080 Not Used 49081 Not Used 49082 Rover Mini Cooper Complete Kit 49083 Fiat Abarth 1000TCR Berlina Corsa Complete Kit 49084 Honda S-MX Lowdown Complete Kit 49085 Porsche Boxster Complete Kit - M02L 49086 Mercedes-Benz SLK Complete Kit 49087 CVA Mini Shock Unit II - Transparent 49088 CVA Super Mini Shock Unit Set Transparent 49089 TA03 Super Low Friction Damper - Metallic Black 49090 5mm Aluminum Ball Connector - Purple 49091 TA03 Lightweight Drive Shaft Purple 49092 Aluminum Servo Stay Blue 49093 Aluminum Servo Stay Purple 49094 4mm Alum Flange Lock Nuts - Red/Blue (2pcs each) 49095 Countach LP500S Re-issue 1/10 Body Parts Set (White). 49096 Aluminum Servo Stay - Pink 49097 TA03 Alum Front Hub Carrier - Blue 49098 TA03 Universal Drive Shaft - Pink 49099 TA03 Low Friction Damper - Silver/Blue 49100 TA03 Low Friction Damper - Silver/Pink 49101 Aluminum King Pins Pink 49102 Aramid Fiber Drive Belt - TA03F/R Blue 49103 TA03FS & RS Reinforced Drive Belt Red 49104 Glass Tape Blue 49105 Glass Tape Red 49106 Glass Tape Black 49107 Antenna Pipe (black) 49108 TA03 Carbon Reinforcing Plate - Blue 49109 TA03 Carbon Reinforcing Plate Black 49110 TA03 A Parts (Gear Case) - Black 49111 TA03 B Parts (Rr Gear Case) - Black 49112 TA03 D Parts (Sus Arm) - Black 49113 1/12 Celica LB Turbo GR.5 Body Set 49114 Damper oil #900 2 set 49115 TA03 Pully Stopper 49116 Piston Set for 53280????? 49117 Clear Silicon Damper Seals (???) 49118 Reynard 97D Prepainted white 49119 RC Tyre Carrying Case 49120 Lightweight Aluminum Wheel Hub 49121 TA03 Stabilizer Stopper Set 49122 Damper Air Remover 49123 Damper Tune-up Set 49124 Mobil 1NSX Lightweight Body Set 49125 Mercedes CLK Lightweight Body Set 49126 Porsche 911 GT1 Lwt Body Set 49127 TRF Original Sticker 49128 AO-5005 King Tiger DMD Turret Traversing Unit 49129 Johnson Motor 49130 Stealth Box 49131 AO-5006 Low Friction Use O Ring & Spacer Set 49132 TRF414 Chassis Kit 49133 Mini Cooper Monte Carlo Completed Product [for export] 49134 RCC Porche 911 Carrera Completed Product (Silver) [for export] 49135 RCC Porche 911 Carrera Completed Product (Blue) [for export] 49136 RCC Porche 911 Carrera Completed Product (Yellow) [for export] 49137 RCC Porche 911 Carrera Completed Product (Red) [for export] 49138 Tyrrell P34 Six Wheelser Body Parts Set 49139 TA03R-S TRF Special Chassis Kit w/Lightweight Body 49140 Aluminum Setting Wheel 49141 Super Low Friction Damper II 49142 Lt Wgt Alum Wheel Hub - Thick 49143 Damper Air Remover (Smoke) 49144 Camber Gauge 49145 Impreza WRC Body - Painted 49146 Calsonic Skyline GT-R (R34) Lightweight Body Parts Set 49147 Bag 49148 Subaru Impreza WRC (Fully Assembled w/RC Unit) - TGX 49149 TGX-Mk.1 SUBARU IMPREZA WRC Complete Kit 49150 AO-5008 TG10 SLK White Wheel 49151 Toyota bB Completed Product White 49152 Honda City Turbo Spare Body 49153 Toyota bB Completed Product Black 49154 Tyrrell P34 Six Wheeler Kit 49155 NiMH (Nickel metal hydride) Battery 3000MH 49156 3x8 Round Hex Head Screw 49157 3x10 Round Hex Head Screw 49158 3x12 Round Hex Head Screw 49159 3x14 Round Hex Head Screw 49160 3x8 Countersunk Hex Screw 49161 3x10 Countersunk Hex Screw 49162 3x16 Countersunk Hex Screw 49163 Countersunk Washer for Hex Screw 49164 Hex Wrench Driver - 1.5, 2mm 49165 Screw Case 49166 Juggernaut 2 Frame Blue 49167 Juggernaut 2 Anodized Chassis Frame Set (Red) 49168 Juggernaut 2 Bumper Blue 49169 Juggernaut 2 Bumper Red 49170 Esso Ultron Tiger Supra Kit - TGX 49171 7.2V Racing Pack 1700MP Battery 49172 TG10 Mk.1 PRO Racing - Long Suspension w/Body Kit 49173 TRF414M Custom Pack M 49174 Mad Bull Special Complete Kit 49175 TRF414M Chassis Kit 49176 Subaru WRC 2001- TG10 49177 Ferrari 312T3 Body Parts Set 49178 Locktite GT-R (R34) Lightweight Body Set 49179 Body Set Ferrari Modena - Light Weight Body Set 49180 GP Body Set CLK DTM 2000 - Original Teile Finished Body 49181 Unimog U300 Complete Kit (Orange) 49182 Unimog U300 Complete Kit (Green) 49183 Med.Narrow Dish Wheels - Flou.Yellow (Offset 0) 49184 Not Used 49185 Harbour Boat 49186 Unimog Hunter 49187 F1 Body Parts Set 49188 Body Set Corvette C5-R - Finished Body (blue) 49189 AO-5009 Nissan 300ZX IMSA GTS Spare Body 49190 Dyna Storm (Re-Release 49191 Ferrari 312T3 - F103RS 49192 Bus 49193 M4 Sheman & Photo Collection 49194 TA04 Aluminum Steering Post Blue 49195 TA04 Alum Steering Arms - Blue 49196 Short Alum Servo Stays - Blue 49197 4mm Turnbuckle Wrench - Blue 49198 TRF Damper Set - Blue 4pcs 49199 TA04 Alum Motor Heat Sink - Blue 49200 TA04 Universal Shaft Set 49201 TA04 Rear Universal Shaft Set - Lightweight Assembly 49202 TA04 Aluminium Hub Set for Spur Gear Blue 49203 TA04 Reinforced Gear Case 49204 Dish Wheel (+0, Blue) 49205 Dish Wheel (+0, Magenta) 49206 Body Set HKS Racing Altezza 49207 TA04 PRO Blue Collection 49208 Body Set HKS Racing Altezza - Carbon 49209 Tiger I Early Production Photo Etched Grille Set 49210 AO-5010 6-Spoke Wheel White (Offset+2) Set of four 49211 1 / 12 Smart Cabrio (Red) 49212 1 / 12 Smart Cabrio (Blue) 49213 1 / 12 New Mini Cooper (Yellow) 49214 1 / 12 New Mini Cooper (Blue) 49215 Power Loader 49216 Power Shovel 49217 1 / 12 Smart Cabrio (Grey) 49218 1 / 12 New Mini Cooper (Green) 49219 TRF414M2 Chassis 49220 TRF414M Champion Memorial Chassis Kit 49221 Lamborghini Contach LP500S Body (Black) 49222 Lotus 79 Body Parts Set (Re-Release) 49223 Ferrari F40 GT Body (200mm) Body Parts Set 49224 Car Maintenance Stand - Blue 49225 Camber Gauge - Black 49226 Height Gauge (Blue) 49227 Wheel Wrench - Blue 49228 Pinion Gear Holder (Blue) 49229 TRF Sticker B - Blue/Yellow 49230 Hard Coated 0.6 Alumium Pinion Gear (27T/TA-04) 49231 Hard Coated 0.6 Alumium Pinion Gear (22T/TB-01) 49232 0.6 Alum Pinion Gear - Hard Coated (19T/TL-01) 49233 Hard Coated 0.4 Aluminum Pinion 39T/TA04 49234 Hard Coated 0.4 Alumium Pinion Gear (35T/TB-01) 49235 Hard 0.6 Spur Gear (83T/TA04) 49236 0.6 Hard Spur Gear - (55T/TB-01, F201) 49237 0.4 Hard Spur Gear - (120T/TA04) 49238 Hard 0.4 Spur Gear (88T) TB01 49239 TRF Sticker B Gold/Silver 49241 Matched Spring Set - Medium 4pcs 49242 Matched Spring Set - Hard 4pcs 49243 Aluminum Stabilizer End Blue 4pc 49244 5mm Alum Ball Nuts - Blue 10pcs 49245 TRF Special Damper Retainer - Blue 4pcs 49246 TRF Sticker B - Blue/Pink 49247 Super Stock Motor Type S 49248 Pit Bag w/3 Box (Navy Blue) 49249 TB Evolution II Suspension Setting Parts 49250 Datsun 280ZX Body Parts Set (Reissue) 49251 Mercedes Trailer Truck (Red) 49252 1/12 Audi TT Roadster (Silver) 49253 1/12 Porsche 911 Turbo (Yellow) 49254 TRF 2002 ESC 49255 TRF414M World Champion Replica Chassis Kit 49256 Mercedes Benz C11 Spare Body 49257 Idemitsu Motion Mugen Civic Spare Body 49258 TRF414 Front Stabilizer - World Champion Replica 49259 Tire Warmer 49260 Super Stock Motor Type RR 49261 1 / 12 Mercedes-Benz SL500 (Silver) 49262 1 / 12 Mercedes-Benz SL500 (Black) 49263 Body Set 360 Modena - Ltd Carbon 49264 Body Set Skyline R34 - Ltd Carbon 49265 Body Set Toyota MR-S - Ltd Lightweight 49266 TRF Setting Board - Ltd 49267 TRF Tool Set - Ltd 49268 7.2v Racing Pack RC2400SP Zapped Type 49269 TRF414M Lightweight Front Bulkhead 49270 TRF414M Lightweight Rear Bulkhead 49271 TRF414M Lightweight Motor Plate 49272 TRF414M SSG Carbon Upper Deck 49273 TRF414M SSG Carbon Lower Deck - Ltd 49274 TRF414M SSG Carbon Front Damper Stay 49275 TRF414M SSG Carbon Rr Damper - Ltd 49276 Body Set Raybrig NSX 2002 - Ltd Lightweight 49277 Body Set Nissan 350Z - Ltd Carbon Pattern 49278 TA04 TRF - Ltd 49279 Body Set Raybrig NSX 2002 - Ltd Carbon Pattern 49280 Body Set Toyota MR-S - Ltd Carbon Pattern 49281 1/10 Ferrari 312T3 Tyre R 49282 1/10 Ferrari 312T3 Plated Wheel 49283 TB-Evo.3 Surikarn Ltd. - Ltd 49284 Nissan R91CP Spare Body 49285 Jaguar XJR-12 Spare Body 49286 Skyline GT-R (R32) Carbon Print Body 49287 Sport Tuned Mortor for XB Cars 49288 Super Stock Motor Type RR (Gun Metal Case) 49289 Enzo Ferrari Carbon Print Body 49290 Setting Board (Red) 49291 Maintenance Stand (Red) 49292 TRF Tool Set (Red) 49293 TRF Damper Set - Fluorine Coated Blue 49294 TRF Damper Set - Fluorine Coated Red 49295 Toyota Celica GT-FOUR RC Body 49296 Subaru Brat Body 49297 TA04R Tuned Chassis Kit - Ltd 49298 RD F-1 Spoke Wheel Set 3630F/3645R (Black) 49299 Ball Diff Spring 49300 620 Ball Thrust Bearing (2pcs). 49301 Fiat Abarth Corsa Body Parts 49302 Matched Springs (Soft 2 Pieces) 49503 Matched Springs (Medium 2 pieces) 49304 Matched Springs (Hard 2 pieces) 49305 Matched Springs (Extra Hard 2 pieces) 49306 TRF Sticker B (Red Tone) 49307 TRF Sticker B (Blue Tone) 49308 TRF Damper Aluminum Top End (Blue) 49309 TRF Damper Cylinder Cap Set Blue 49310 TRF Damper Cylinder Nut (Blue) 49311 TRF Damper Aluminum Retainer (Blue) 49312 TRF Damper Alum Top End - Red 49313 TRF Damper Cylinder Cap - Red 49314 TRF Damper Cylinder Nut - Red 49315 TRF Damper Alum Retainer - Red 49316 3x18mm Aluminum Turnbuckle Shafts Blue 49317 3x23mm Aluminum Turnbuckle Shafts Blue 49318 3x32mm Aluminum Turnbuckle Shafts Blue 49319 3x35mm Aluminum Turnbuckle Shafts Blue 49320 LW Alum Servo Stay - Blue 49321 5mm Aluminum End Cap for Body Mount Blue 49322 6mm Aluminum End Cap for Body Mount Blue 49323 3x18mm Aluminum Turnbuckle Shafts Red 49324 Alum Turnbuckle Shafts - 3x23mm Red 2pcs 49325 Alum Turnbuckle Shafts - 3x32mm Red 2pcs 49326 3x35mm Aluminum Turnbuckle Shafts Red 49327 LW Alum Servo Stay - Red 49328 5mm Alum End Cap - Red For Body Mount 49329 6mm Aluminum End Cap for Body Mount Red 49330 1 / 12 Mercedes-Benz ML55 AMG (Red) 49331 1 / 12 Mercedes-Benz ML55 AMG (Silver) 49332 1 / 12 BMW Z8 (Red) 49333 1 / 12 BMW Z8 (Yellow) 49334 1 / 12 Opel Speedster (Silver) 49335 TB Evo III Conversion Parts - Blue 49336 F201 Tuned Chassis Kit - F201 49337 Wild Willy 2 - Metallic Special 49338 Alpine A110 Spare Body 49339 Body Set Raybrig NSX 2003 - Lightweight 49340 Body Set Xanavi Nismo GT-R - Lightweight 49341 TRF415 Lower Deck - for Stick Type Battery 49342 TRF415 Motor Mount Bulkhead Heat Sink Type 49343 TRF415 Belt Stabilizer 49344 TRF415 Heat Sink Beam 49345 TB Evo IV Titanium Screws 49346 TRF415 LW Suspension Set - Reversible 49347 Transpeed MS Motor 9T 49348 TB-02R Chassis Kit 49349 TRF415MS Chassis Kit LE - Limited Edition 49350 2x25mm Cap Screw - w/2mm Lock Nut 49351 TRF415MS World Champ Parts 49352 Impreza WRC 2004 - TL01RA 49353 TB Evolution IV MS - TBEVOIV 49354 Tamiya Pit Case - Blue 49355 TRF Damper Special Blue 49356 TB Evolution IV Aluminum Center Post 49357 TB Evolution IV Seperate Motor Mount MS 49358 TRF415 Front Direct Coupling (Spool) 49359 TB Evo IV Front Direct Coupling (Spool) 49360 TA05 Titanium Screw Set 49361 6-Spoke Setting Wheels (Blue) 49362 TB Evo IV Gear Cover - Smoke 2pcs 49363 TB Evo IV Gear Cover - Clear Blue 2pcs 49364 TB-02R Front Carbon Brace Set 49365 TB-02R Rear Carbon Brace Set 49366 TB02R Battery Plate 49367 TB-02 Aluminum Racing Steering Set (Blue) 49368 TB-02 Aluminum Motor Mount (Blue) 49369 TB-02R LW Alu Propeller Shaft Blue TB02 49370 F201 Aluminum Racing Steering 49371 F201 7mm Ball Connector - 2pcs Titanium 49372 TB Evo IV Gear Cover - Red 2pcs ????? 49373 TNX Pro-Line Special 49374 Body Set Subaru Legacy B4 - Lightweight 49375 Body Set Xanavi NISMO Z - Lightweight 49376 Body Set Raybrig NSX 2004 - Lightweight 49377 TA03F Pro Drift Spec Chassis Kit 49378 TRF415MSX Up-Grade Parts 49379 Antenna Pipes Fluor. Blue 49380 7mm Snap Pin Blue 5pc 49381 TRF415MSX 49382 On Road Tuned Hard Spring Set White 49383 TA05 Stabilizer Set F/R Black 49384 TRF415MSX Screw Set Titanium & Aluminum 49385 TRF415MSX Lower Deck - for Stick Type Battery 49386 Transpeed MS Motor 10T 49387 Porsche 911 GT2 Body Parts Set 49388 TA05 Carbon Reinforced Damper Stay 49389 On Road Tuned Hard Spring Set Milky Blue 49390 TA05 Bulkhead Clear Blue 49391 TA05 Upper Brace F R (Clear Blue) 49392 TB Evolution 5 Stabilizer Rod Set 49393 TB Evolution 5 Screw Set (Titanium & Aluminum). 49394 TRF415MSX Marc Rheinard Ed. 49395 TB Evolution 5 Stabilizer Rod Set Black 49396 TB Evolution 5 Gear Cover Clear Blue 49397 TB Evolution 5 Gear Cover Clear Smoke 49398 TB Evolution 5 Bumper Clear Blue 49399 TB Evolution 5 Bumper Clear Smoke 49400 Porsche Turbo RSR Type 934 - TA05 49401 TRF501X 49402 MN 6-Spoke Wheel Clear - +2 49403 Medium Narrow 6 Spoke Wheels Clear Blue 49404 MN 6-Spoke Wheel Smoke - +2 49405 Medium Narrow Dish Wheels Clear Offset O 49406 MN Dish Wheel Clear Blue - +/-0 49407 MN Dish Wheel Smoke - +/-0 49408 MN Mesh Wheel Clear - +2 49409 Medium Narrow Mesh Wheels Blue Offset +2 49410 Medium Narrow Mesh Wheels Smoke Offset +2 49411 MN 18-Spoke Clear - +/-0 49412 MN 18-Spoke Clear Blue - +/-0 49413 MN 18-Spoke Smoke - +/-0 49414 TA05 Stabilizer Set F/R Milky Blue 49415 Body Set Mobil 1 SC430 LW 49416 Carbon Bumper Support - TRF415 49417 M-03R Chassis Kit - M03 49418 TA05-R Chassis Kit - TA05 49419 TRF415MSXX 49420 Body Set Suzuki Swift - Lightweight 49421 Medium Narrow Dish Wheels - Fluorescent Yellow/0 Degrees 49422 Medium Narrow Dish Wheels - Fluorescent Pink/+2 Degrees 49423 Fluorescent Orange Medium Narrow Wheels 49424 Medium Narrow Mesh Wheels - Blue Plated/+2 Degrees 49425 TA05 Aluminum Differential Joint Blue 49426 TRF415 Alum Diff Joint - Blue 49427 TA05 Battery Plate Set (Blue) 49428 TA05 Center Plate Blue 49429 TRF415MSXX Upper Deck (Blue) 49430 TRF415MSXX Lower Deck (Blue) 49431 DF03 Setting Spring White 49432 DF03 Propeller Shaft - Blue 49433 DF03 Gearbox Plate Blue 49434 DF03 Gear Cover - Smoke 49435 DF03 Damper Cylinder Blue DF-03 49436 TRF415MSXX Lower Deck Set - For Stick Type Battery 49437 1/16 Panther G Grille Set - Photo Etched Grille 49438 Body Set NISMO R34 - Lightweight 49439 Body Set NISMO Silvia - Lightweight Coppermix 49440 TA05 Aluminum Center Plate (Blue) 49441 Aluminum Front Upright Blue M03 M04 FF02 49442 Aluminum Rear Upright Blue M03 M04 49443 M03R Alum Servo Mount - Blue 49444 M03 Aluminum Heat Sink Blue 49445 AM Crystal Set for Expec (01) 49446 AM Crystal Set for Expec (02) 49447 AM Crystal Set for Expec (03) 49448 AM Crystal Set for Expec (04) 49449 AM Crystal Set for Expec (05) 49450 AM Crystal Set for Expec (06) 49451 AM Crystal Set for Expec (07) 49452 AM Crystal Set for Expec (08) 49453 AM Crystal Set for Expec (09) 49454 AM Crystal Set for Expec (10) 49455 AM Crystal Set for Expec (11) 49456 AM Crystal Set for Expec (12) 49457 Toyota Hilux 4x4 Pick Up Body Parts Set 49458 TB02 Drift Spec Chassis Kit 49459 Lunch Box Gold Edition 49460 RTR TNX 5.2R Gold Ed. - TGM04 4x4 Custom Monster Truck 49461 M-Chassis 11-Spoke Wheels - 4pcs Black 49462 TA05 Urethane Bumper Black - Ltd 49463 TRF415 Urethane Bumper - Ltd Black 49464 GB01 Setting Spring Set - White 49465 TT Setting Spring Set - White/Short 49466 M03 Blue Plated Frame Set 49467 M-Chassis 11-Spoke Wheels - 4pcs Blue 49468 M-Chassis 11-Spoke Wheels - 4pcs Silver 49469 M-Chassis 11-Spoke Wheels - 4pcs Fluorescent Yellow 49470 M-Chassis 11-Spoke Wheels - 4pcs Fluorescent Orange 49471 TA05 One-Way Pulley 36T - Ltd Wide Pitch Black 49472 TA05 Diff Pulley 36T - Ltd Wide Pitch Black 49473 06 Module Pinion Gear (22T) - Ltd Hard Coated Aluminum 49474 3mm Countersunk Washer - Ltd 10pcs Blue 49475 DT-02 MS - DT02 49476 DF03 Gear Cover - Ltd Blue 49477 TA05 Body Mount Set - Ltd Blue 49478 TA05 Body Mount Set - Ltd Smoke 49479 TA05 Body Mount Set - Ltd Clear 49480 TRF415 Body Mount Set - Ltd Blue 49481 TRF415 Body Mount Set - Ltd Smoke 49482 TRF415 Body Mount Set - Ltd Clear 49483 Body Set Mini Cooper Racing - Ltd Lightweight 49484 Body Set Mazda RX-7 - Ltd Lightweight 49485 Body Set EBBRO 350R - Ltd Lightweight Very Early Limited Edition Parts 49500 Not Used 49501 The Grasshopper II Super G 49502-49507 Not Used 49508 MacLaren MP4/5B Body Part 49509 Manta Ray QD Black Special Ltd Edition 49510 German Flakpanzer Gepard Kit 49511-49532 Not Used 49533 1/35 R/C Type-74 ??? 49534 Fluorescent Colour Cable 7.2V Connector Set 49535 Fluorescent Silicon Wire 49536 Fluorescent Nylon Band Small Set (Yellow) 49537 Fluorescent Nylon Band Small Set (Orange) 49538 Fluorescent Nylon Band Small Set (Green) 49539 RD Fluorescent Green 70T Plastic Gear 49540 RD Fluorescent Pink 70T Plastic Gear Set 49541 RD Yellow 0.4 Spur Gear Set 94T, 104T 49542 RD Pink 0.4 Spur Gear 49543 TA01 Fluorescent Yellow Suspension Arm 49544 Tamiya Touring/Rally Car Fluorescent Green Suspension Arm 49545 Tamiya Fluorescent Green Adjuster Set 49546 Tamiya Fluorescent Pink Adjuster Set 49547 4WD Fluorescent Gear Case (Yellow) 49548 4WD Fluorescent Gear Case (Green) 49549 4WD Fluorescent Gear Case (Pink) 49550 Manta Ray TA01 Fluorescent Yellow Chassis 49551 Manta Ray TA01 Flourescent Orange Chassis 49552 Man Ray TA01 Flourescent Green Chassis 49553 Fluorescent High Torque Servo Saver Set (Yellow) 49554 Fluorescent High Torque Servo Saver Set (Green) 49555 4WD FF Touring Car Fluorescent Orange Damper Spring 49556 4WD FF Touring Car Fluorescent Green Damper Spring 49557 4WD Rally Car Flourescent Yellow Damper Spring 49558 4WD Rally Car Flourescent Pink Damper Spring 49559 4WD/FF Plated Mesh Wheels 49560 4WD/FF Plated Spoke Wheels 49561-49566 Not Used 49567 Acto-Power TRF Tuned Motor 49568-49572 Not Used 49573 TA02 Chassis White Suspension Arms (F & R). 49574 FWD Touring Car White Suspension Arms (F & R) 49575 Manta Ray White Suspension Arms (F & R) 49576 Castrol Celica Chrome Plated Wheel 4pc 49577 CVA Mini Shock Unit Set II White 49578 TA02 FF White Chassis 49579 TA02 FF Fluorescent chassis (Orange) (1 unit limited) 49580-49591 Not Used 49592 Sauber C12 `94 Tamiya All Japan Champion Special 4593-49594 Not Used 49595 RC Mini Cooper Plated Wheel Rare Limited Edition Event Parts 92179 Mini Cooper Racing Union Jack Sticker 94003 RD Mesh Wheel Set Silver 94023 Mazda 787B Silver Wheel Set 94025 2WD Front Star-Dish Wheels (1 Pair) (Silver) 94027 6029 Rear Star-Dish Wheels (1 Pair) (Silver) 94102 Alfa Romeo 155 Silver Spoke Wheels 94148 Opel Calibra Chrome Wheels Limited Edition Parts (New 42xxx Part Number Series) 42101 RC Pit Bag L - w/3 Inner Boxes 42102 TRF Special Damper Set - Hard Black Coating 42103 TA05MS Chassis Kit 42104 TRF415 MSXX - Marc Rheinard Edition 2007 42105 TRF501X World Championship - World Championship Edition 42106 TRF416 Chassis Kit 1 Share this post Link to post Share on other sites
Vin87 0 Posted December 5, 2007 Anyone knows what was so special about for example this item: 49083 Fiat Abarth 1000TCR Berlina Corsa Complete Kit Was it an RTR? Share this post Link to post Share on other sites
europro975 75 Posted December 5, 2007 Anyone knows what was so special about for example this item:49083 Fiat Abarth 1000TCR Berlina Corsa Complete Kit Was it an RTR? Yes, it came with Tamiya Adspec Radio Gear. I believe only sold in Japan?? Antony Share this post Link to post Share on other sites
RichieRich 685 Posted December 5, 2007 This is really great information to have. It needs to be in a spreadsheet. Share this post Link to post Share on other sites
europro975 75 Posted December 5, 2007 This is really great information to have. It needs to be in a spreadsheet. PM me, I have it all on an Excel Spread Sheet Antony Share this post Link to post Share on other sites
europro975 75 Posted April 9, 2008 Updated 09/04/2008. 49001 2WD Front Tyre (Red) 49002 2WD Front Tyre (Yellow) 49003 2WD Front Tyre (White) 49004 Oval Block Tyre Front (Red) 49005 Oval Block Tyre Front (Yellow) 49006 Oval Block Tyre Front (White) 49007 Oval Block Tyre Rear (Red) 49008 Oval Block Tyre Rear (Yellow) 49009 Oval Block Tyre Rear (White) 49010 Pin Spike Tyre Front (Red) 49011 Pin Spike Tyre Front (Red) 49012 Pin Spike Tyre Front (Yellow) 49013 Pin Spike Tyre Front (White) 49014 Pin Spike Tyre Rear (Red) 49015 Pin Spike Tyre Rear (Yellow) 49016 Pin Spike Tyre Rear (White) 49017 2WD Wheel Set Front and Rear (White) 49018 2WD Wheel Set Front and Rear (Silver) 49019 4WD Wheel Set Front and Rear (White) 49020 4WD Wheel Set Front and Rear (Silver) 49021 2WD FRONT Day Glow Wheel Set (Red) 49022 2WD FRONT Day Glow Wheel Set (Yellow) 49023 2WD Front Day-Glow Wheel Set (Green) 49024 2WD Rear Day-Glow Wheel Set (Red) 49025 2WD Rear Day-Glow Wheel Set (Yellow) 49026 2WD Rear Day-Glow Wheel Set (Green) 49027 1 Piece Racing Spoke Wheel (Gold Plated) 49028 1 Piece Racing Spoke Wheel (Silver Plated) 49029 1 Piece Racing Spoke Wheel (Blue Plated) 49030 RC Parts Case 49031 RCC Wing Duct Set 49032 M Chassis 60D Super Grip White Wall Tyre 49033 Flexible Sticker (Carbon) 49034 Flexible Sticker (Smoke) 49035 Flexible Sticker (Transparent) 49036 Fluorescent High Torque Servo Saver (Orange) 49037 Low Friction Aluminum Damper (Blue 1 Pair) 49038 One Piece 5 Spoke Wheel Black 1 Pair 49039 M-Chassis Heat Sink (Blue) 49040 Mini Cooper Wheels Yellow 49041 Mini Cooper Wheels Red 49042 Mini Cooper Wheel Set Blue 49043 Mini Cooper Wheels (White, 1 Pair) 49044 M-Chassis A Parts (Moss Green) 49045 M-Chassis B Parts (Moss Green) 49046 5mm Adjuster Red 49047 M Chassis Number Sticker Mini Cooper 49048 Nylon Band with Metal Hook (Blue) 49049 Nylon Band with Metal Hook (Yellow) 49050 Nylon Band with Metal Hook (Green) 49051 Nylon Band with Metal Hook (Orange) 49052 Nylon Band with Metal Hook (Dark Red) 49053 2ch 1ESC 1 Servo (Wheel Control) Radio Set 49054 2ch 1ESC 2 Servo (Stick)Radio Set 49055 2ch 2 Servo (Yacht-Use) Radio Set 49056 4ch 1ESC 2 Servo Radio Set 49057 Stainless Snap Pin (Large) 49058 Stainless Snap Pin (Small) 49059 No. 900 Damper Oil (9cc) 49060 Colour Antenna Pipe (Red) 49061 Colour Antenna Pipe (Blue) 49062 Colour Antenna Pipe (Black) 49063 Colour Antenna Pipe (Purple) 49064 RC Yacht Use 2Ch 2 Servo Radio Set 49065 1/8 Engine RC Car-Use 2ch 2 Servo Radio Set 49066 C.V.A Damper Mini (II) White 49067 Aluminium King Pins (Red) 49068 Aluminum King Pins Blue 49069 TA03 Super Low Friction Damper Blue 49070 TA03 Super Low Friction Damper Purple 49071 5mm Alu. Ball Connector (Red) 49072 5mm Alu. Ball Connector (Blue) 49073 TA03 Aluminum Pulley (Blue, 16T) 49074 TA03 Aluminum Pulley (Red, 16T) 49075 Carbon Reinforced 1-piece 5-spoke Wheel 49076 Lancia Rally Body Parts Set (Re-Issue) 49077 Porsche Boxster Front Carbon-Reinforced Wheel 49078 Porsche Boxster Rear Carbon-Reinforced Wheel 49079 CVA Mini Shock II - Transparent 49080 Not Used 49081 Not Used 49082 Rover Mini Cooper Complete Kit 49083 Fiat Abarth 1000TCR Berlina Corsa Complete Kit 49084 Honda S-MX Lowdown Complete Kit 49085 Porsche Boxster Complete Kit - M02L 49086 Mercedes-Benz SLK Complete Kit 49087 CVA Mini Shock Unit II - Transparent 49088 CVA Super Mini Shock Unit Set Transparent 49089 TA03 Super Low Friction Damper - Metallic Black 49090 5mm Aluminum Ball Connector - Purple 49091 TA03 Lightweight Drive Shaft Purple 49092 Aluminum Servo Stay Blue 49093 Aluminum Servo Stay Purple 49094 4mm Alum Flange Lock Nuts - Red/Blue (2pcs each) 49095 Countach LP500S Re-issue 1/10 Body Parts Set (White). 49096 Aluminum Servo Stay - Pink 49097 TA03 Alum Front Hub Carrier - Blue 49098 TA03 Universal Drive Shaft - Pink 49099 TA03 Low Friction Damper - Silver/Blue 49100 TA03 Low Friction Damper - Silver/Pink 49101 Aluminum King Pins Pink 49102 Aramid Fiber Drive Belt - TA03F/R Blue 49103 TA03FS & RS Reinforced Drive Belt Red 49104 Glass Tape Blue 49105 Glass Tape Red 49106 Glass Tape Black 49107 Antenna Pipe (black) 49108 TA03 Carbon Reinforcing Plate - Blue 49109 TA03 Carbon Reinforcing Plate Black 49110 TA03 A Parts (Gear Case) - Black 49111 TA03 B Parts (Rr Gear Case) - Black 49112 TA03 D Parts (Sus Arm) - Black 49113 1/12 Celica LB Turbo GR.5 Body Set 49114 Damper oil #900 2 set 49115 TA03 Pully Stopper 49116 Piston Set for 53280????? 49117 Clear Silicon Damper Seals (???) 49118 Reynard 97D Prepainted white 49119 RC Tyre Carrying Case 49120 Lightweight Aluminum Wheel Hub 49121 TA03 Stabilizer Stopper Set 49122 Damper Air Remover 49123 Damper Tune-up Set 49124 Mobil 1 NSX Lightweight Body Set 49125 Mercedes-Benz CLK Lightweight Body Set 49126 Porsche 911 GT1 Lightweight Body Set 49127 TRF Original Sticker 49128 AO-5005 King Tiger DMD Turret Traversing Unit 49129 Johnson Motor 49130 Stealth Box 49131 AO-5006 Low Friction Use O Ring & Spacer Set 49132 TRF414 Chassis Kit 49133 Mini Cooper Monte Carlo Completed Product [for export] 49134 Porsche 911 Carrera Completed Product (Silver) [for export] 49135 Porsche 911 Carrera Completed Product (Blue) [for export] 49136 Porsche 911 Carrera Completed Product (Yellow) [for export] 49137 Porsche 911 Carrera Completed Product (Red) [for export] 49138 Tyrrell P34 Six Wheelser Body Parts Set 49139 TA03R-S TRF Special Chassis Kit w/Lightweight Body 49140 Aluminum Setting Wheel 49141 TA04 TRF Pro Special Damper (1 Pair) 49142 Lt Wgt Alum Wheel Hub - Thick 49143 Damper Air Remover (Smoke) 49144 Camber Gauge 49145 Impreza WRC Body - Painted 49146 Calsonic Skyline GT-R (R34) Lightweight Body Parts Set 49147 Bag 49148 Subaru Impreza WRC (Fully Assembled w/RC Unit) - TGX 49149 TGX-Mk.1 SUBARU IMPREZA WRC Complete Kit 49150 AO-5008 TG10 SLK White Wheel 49151 Toyota bB Completed Product White 49152 Honda City Turbo Spare Body 49153 Toyota bB Completed Product Black 49154 Tyrrell P34 Six Wheeler Kit 49155 NiMH (Nickel metal hydride) Battery 3000MH 49156 3x8 Round Hex Head Screw 49157 3x10 Round Hex Head Screw 49158 3x12 Round Hex Head Screw 49159 3x14 Round Hex Head Screw 49160 3x8 Countersunk Hex Screw 49161 3x10 Countersunk Hex Screw 49162 3x16 Countersunk Hex Screw 49163 Countersunk Washer for Hex Screw 49164 Hex Wrench Driver - 1.5, 2mm 49165 Screw Case 49166 Juggernaut 2 Frame Blue 49167 Juggernaut 2 Anodized Chassis Frame Set (Red) 49168 Juggernaut 2 Bumper Blue 49169 Juggernaut 2 Bumper Red 49170 Esso Ultron Tiger Supra Kit - TGX 49171 7.2V Racing Pack 1700MP Battery 49172 TG10 Mk.1 PRO Racing - Long Suspension w/Body Kit 49173 TRF414M Custom Pack M 49174 Mad Bull Special Complete Kit 49175 TRF414M Chassis Kit 49176 Subaru WRC 2001- TG10 49177 Ferrari 312T3 Body Parts Set 49178 Loctite GT-R (R34) Lightweight Body Set 49179 Body Set Ferrari Modena - Light Weight Body Set 49180 GP Body Set CLK DTM 2000 - Original Teile Finished Body 49181 Unimog U300 Complete Kit (Orange) 49182 Unimog U300 Complete Kit (Green) 49183 Med.Narrow Dish Wheels - Flou.Yellow (Offset 0) 49184 Not Used 49185 Harbour Boat 49186 Unimog Hunter 49187 F1 Body Parts Set 49188 Body Set Corvette C5-R - Finished Body (blue) 49189 AO-5009 Nissan 300ZX IMSA GTS Spare Body 49190 Dyna Storm (Re-Release 49191 Ferrari 312T3 - F103RS 49192 Bus 49193 M4 Sherman & Photo Collection 49194 TA04 Aluminum Steering Post Blue 49195 TA04 Alum Steering Arms - Blue 49196 Short Alum Servo Stays - Blue 49197 4mm Turnbuckle Wrench - Blue 49198 TRF Damper Set - Blue 4pcs 49199 TA04 Alum Motor Heat Sink - Blue 49200 TA04 Universal Shaft Set 49201 TA04 Rr Universal Shaft Set - Lightweight Assembly 49202 TA04 Aluminum Hub Set for Spur Gear Blue 49203 TA04 Reinforced Gear Case 49204 Dish Wheel (+0, Blue) 49205 Dish Wheel (+0, Magenta) 49206 Body Set HKS Racing Altezza 49207 TA04 PRO Blue Collection 49208 Body Set HKS Racing Altezza - Carbon 49209 Tiger I Early Production Photo Etched Grille Set 49210 AO-5010 6-Spoke Wheel White (Offset+2) Set of four 49211 1 / 12 Smart Cabrio (Red) 49212 1 / 12 Smart Cabrio (Blue) 49213 1 / 12 New Mini Cooper (Yellow) 49214 1 / 12 New Mini Cooper (Blue) 49215 Power Loader 49216 Power Shovel 49217 1 / 12 Smart Cabrio (Grey) 49218 1 / 12 New Mini Cooper (Green) 49219 TRF414M2 Chassis 49220 TRF414M Champion Memorial Chassis Kit ????? 49221 Lamborghini Contach LP500S Body (Black) 49222 Lotus 79 Body Parts Set (Re-Release) 49223 Ferrari F40 GT Body (200mm) Body Parts Set 49224 Car Maintenance Stand - Blue 49225 Camber Gauge - Black 49226 Height Gauge (Blue) 49227 Wheel Wrench - Blue 49228 Pinion Gear Holder (Blue) 49229 TRF Sticker B - Blue/Yellow 49230 Hard Coated 0.6 Alumium Pinion Gear (27T/TA-04) 49231 Hard Coated 0.6 Alumium Pinion Gear (22T/TB-01) 49232 0.6 Alum Pinion Gear - Hard Coated (19T/TL-01) 49233 Hard Coated 0.4 Aluminum Pinion 39T/TA04 49234 Hard Coated 0.4 Alumium Pinion Gear (35T/TB-01) 49235 Hard 0.6 Spur Gear (83T/TA04) 49236 0.6 Hard Spur Gear - (55T/TB-01, F201) 49237 0.4 Hard Spur Gear - (120T/TA04) 49238 Hard 0.4 Spur Gear (88T) TB01 49239 TRF Sticker B Gold/Silver 49240 Matched Spring Set - Soft 4pcs 49241 Matched Spring Set - Medium 4pcs 49242 Matched Spring Set - Hard 4pcs 49243 Aluminum Stabilizer End Blue 4pc 49244 5mm Alum Ball Nuts - Blue 10pcs 49245 TRF Special Damper Retainer - Blue 4pcs 49246 TRF Sticker B - Blue/Pink 49247 Super Stock Motor Type S 49248 Pit Bag w/3 Box (Navy Blue) 49249 TB Evolution II Suspension Setting Parts 49250 Datsun 280ZX Body Parts Set (Reissue) 49251 Mercedes Trailer Truck (Red) 49252 1/12 Audi TT Roadster (Silver) 49253 1/12 Porsche 911 Turbo (Yellow) 49254 TRF 2002 ESC 49255 TRF414M World Champion Replica Chassis Kit 49256 Mercedes Benz C11 Spare Body 49257 Idemitsu Motion Mugen Civic Spare Body 49258 TRF414 Front Stabilizer - World Champion Replica 49259 Tire Warmer 49260 Super Stock Motor Type RR 49261 1 / 12 Mercedes-Benz SL500 (Silver) 49262 1 / 12 Mercedes-Benz SL500 (Black) 49263 Body Set 360 Modena - Ltd Carbon 49264 Body Set Skyline R34 - Ltd Carbon 49265 Body Set Toyota MR-S - Ltd Lightweight 49266 TRF Setting Board - Ltd 49267 TRF Tool Set - Ltd 49268 7.2v Racing Pack RC2400SP Zapped Type 49269 TRF414M Lightweight Front Bulkhead 49270 TRF414M Lightweight Rear Bulkhead 49271 TRF414M Lightweight Motor Plate 49272 TRF414M SSG Carbon Upper Deck 49273 TRF414M SSG Carbon Lower Deck - Ltd 49274 TRF414M SSG Carbon Front Damper Stay 49275 TRF414M SSG Carbon Rr Damper - Ltd 49276 Body Set Raybrig NSX 2002 - Ltd Lightweight 49277 Body Set Nissan 350Z - Ltd Carbon Pattern 49278 TA04 TRF - Ltd 49279 Body Set Raybrig NSX 2002 - Ltd Carbon Pattern 49280 Body Set Toyota MR-S - Ltd Carbon Pattern 49281 1/10 Ferrari 312T3 Tyre Rear 49282 1/10 Ferrari 312T3 Plated Wheel 49283 TB-Evo.3 Surikarn Ltd. - Ltd 49284 Nissan R91CP Spare Body 49285 Jaguar XJR-12 Spare Body 49286 Skyline GT-R (R32) Carbon Print Body 49287 Sport Tuned Mortor for XB Cars 49288 Super Stock Motor Type RR (Gun Metal Case) 49289 Enzo Ferrari Carbon Print Body 49290 Setting Board (Red) 49291 Maintenance Stand (Red) 49292 TRF Tool Set (Red) 49293 TRF Damper Set - Fluorine Coated Blue 49294 TRF Damper Set - Fluorine Coated Red 49295 Toyota Celica GT-FOUR RC Body 49296 Subaru Brat Body 49297 TA04R Tuned Chassis Kit - Ltd 49298 RD F-1 Spoke Wheel Set 3630F/3645R (Black) 49299 Ball Diff Spring 49300 620 Ball Thrust Bearing (2pcs). 49301 Fiat Abarth Corsa Body Parts 49302 Matched Spring Soft (2 Pcs.) 49503 Matched Spring Medium (2 Pcs.) 49304 Matched Spring Hard (2 Pcs.) 49305 Matched Spring Extra-Hard (2 Pcs.) 49306 TRF Sticker B (Red Tone) 49307 TRF Sticker B (Blue Tone) 49308 TRF Damper Aluminum Top End (Blue) 49309 TRF Damper Cylinder Cap Set Blue 49310 TRF Damper Cylinder Nut (Blue) 49311 TRF Damper Aluminum Retainer (Blue) 49312 TRF Damper Alum Top End - Red 49313 TRF Damper Cylinder Cap - Red 49314 TRF Damper Cylinder Nut - Red 49315 TRF Damper Alum Retainer - Red 49316 3x18mm Aluminum Turnbuckle Shafts Blue 49317 3x23mm Aluminum Turnbuckle Shafts Blue 49318 3x32mm Aluminum Turnbuckle Shafts Blue 49319 3x35mm Aluminum Turnbuckle Shafts Blue 49320 LW Alum Servo Stay - Blue 49321 5mm Aluminum End Cap for Body Mount Blue 49322 6mm Aluminum End Cap for Body Mount Blue 49323 3x18mm Aluminum Turnbuckle Shafts Red 49324 Alum Turnbuckle Shafts - 3x23mm Red 2pcs 49325 Alum Turnbuckle Shafts - 3x32mm Red 2pcs 49326 3x35mm Aluminum Turnbuckle Shafts Red 49327 LW Alum Servo Stay - Red 49328 5mm Alum End Cap - Red For Body Mount 49329 6mm Aluminum End Cap for Body Mount Red 49330 1 / 12 Mercedes-Benz ML55 AMG (Red) 49331 1 / 12 Mercedes-Benz ML55 AMG (Silver) 49332 1 / 12 BMW Z8 (Red) 49333 1 / 12 BMW Z8 (Yellow) 49334 1 / 12 Opel Speedster (Silver) 49335 TB Evo III Conversion Parts - Blue 49336 F201 Tuned Chassis Kit - F201 49337 Wild Willy 2 - Metallic Special 49338 Alpine A110 Spare Body 49339 Body Set Raybrig NSX 2003 - Lightweight 49340 Body Set Xanavi Nismo GT-R - Lightweight 49341 TRF415 Lower Deck - for Stick Type Battery 49342 TRF415 Motor Mount Bulkhead Heat Sink Type 49343 TRF415 Belt Stabilizer 49344 TRF415 Heat Sink Beam 49345 TB Evo IV Titanium Screws 49346 TRF415 LW Suspension Set - Reversible 49347 Transpeed MS Motor 9T 49348 TB-02R Chassis Kit 49349 TRF415MS Chassis Kit LE - Limited Edition 49350 2x25mm Cap Screw - w/2mm Lock Nut 49351 TRF415MS World Champ Parts 49352 Impreza WRC 2004 - TL01RA 49353 TB Evolution IV MS - TBEVOIV 49354 Tamiya Pit Case - Blue 49355 TRF Damper Special Blue 49356 TB Evolution IV Aluminum Center Post 49357 TB Evolution IV Seperate Motor Mount MS 49358 TRF415 Front Direct Coupling (Spool) 49359 TB Evo IV Front Direct Coupling (Spool) 49360 TA05 Titanium Screw Set 49361 6-Spoke Setting Wheels (Blue) 49362 TB Evo IV Gear Cover - Smoke 2pcs 49363 TB Evo IV Gear Cover - Clear Blue 2pcs 49364 TB-02R Front Carbon Brace Set 49365 TB-02R Rear Carbon Brace Set 49366 TB02R Battery Plate 49367 TB-02 Aluminum Racing Steering Set (Blue) 49368 TB-02 Aluminum Motor Mount (Blue) 49369 TB-02R LW Alu Propeller Shaft Blue TB02 49370 F201 Aluminum Racing Steering 49371 F201 7mm Ball Connector - 2pcs Titanium 49372 TB Evo IV Gear Cover - Red 2pcs ????? 49373 TNX Pro-Line Special 49374 Body Set Subaru Legacy B4 - Lightweight 49375 Body Set Xanavi NISMO Z - Lightweight 49376 Body Set Raybrig NSX 2004 - Lightweight 49377 TA03F Pro Drift Spec Chassis Kit 49378 TRF415MSX Up-Grade Parts 49379 Antenna Pipes Fluor. Blue 49380 7mm Snap Pin Blue 5pc 49381 TRF415MSX 49382 On Road Tuned Hard Spring Set White 49383 TA05 Stabilizer Set F/R Black 49384 TRF415MSX Screw Set Titanium & Aluminum 49385 TRF415MSX Lower Deck - for Stick Type Battery 49386 Transpeed MS Motor 10T 49387 Porsche 911 GT2 Body Parts Set 49388 TA05 Carbon Reinforced Damper Stay 49389 On Road Tuned Hard Spring Set Milky Blue 49390 TA05 Bulkhead Clear Blue 49391 TA05 Upper Brace F R (Clear Blue) 49392 TB Evolution 5 Stabilizer Rod Set 49393 TB Evolution 5 Screw Set (Titanium & Aluminum). 49394 TRF415MSX Marc Rheinard Ed. 49395 TB Evolution 5 Stabilizer Rod Set Black 49396 TB Evolution 5 Gear Cover Clear Blue 49397 TB Evolution 5 Gear Cover Clear Smoke 49398 TB Evolution 5 Bumper Clear Blue 49399 TB Evolution 5 Bumper Clear Smoke 49400 Porsche Turbo RSR Type 934 - TA05 49401 TRF501X 49402 MN 6-Spoke Wheel Clear - +2 49403 Medium Narrow 6 Spoke Wheels Clear Blue 49404 MN 6-Spoke Wheel Smoke - +2 49405 Medium Narrow Dish Wheels Clear Offset O 49406 MN Dish Wheel Clear Blue - +/-0 49407 MN Dish Wheel Smoke - +/-0 49408 MN Mesh Wheel Clear - +2 49409 Medium Narrow Mesh Wheels Blue Offset +2 49410 Medium Narrow Mesh Wheels Smoke Offset +2 49411 MN 18-Spoke Clear - +/-0 49412 MN 18-Spoke Clear Blue - +/-0 49413 MN 18-Spoke Smoke - +/-0 49414 TA05 Stabilizer Set F/R Milky Blue 49415 Body Set Mobil 1 SC430 LW 49416 Carbon Bumper Support - TRF415 49417 M-03R Chassis Kit - M03 49418 TA05-R Chassis Kit - TA05 49419 TRF415MSXX 49420 Body Set Suzuki Swift - Lightweight 49421 Medium Narrow Dish Wheels - Fluorescent Yellow/0 Degrees 49422 Medium Narrow Dish Wheels - Fluorescent Pink/+2 Degrees 49423 Fluorescent Orange Medium Narrow Wheels 49424 Medium Narrow Mesh Wheels - Blue Plated/+2 Degrees 49425 TA05 Aluminum Differential Joint Blue 49426 TRF415 Alum Diff Joint - Blue 49427 TA05 Battery Plate Set (Blue) 49428 TA05 Center Plate Blue 49429 TRF415MSXX Upper Deck (Blue) 49430 TRF415MSXX Lower Deck (Blue) 49431 DF03 Setting Spring White 49432 DF03 Propeller Shaft - Blue 49433 DF03 Gearbox Plate Blue 49434 DF03 Gear Cover - Smoke 49435 DF03 Damper Cylinder Blue DF-03 49436 TRF415MSXX Lower Deck Set - For Stick Type Battery 49437 1/16 Panther G Grille Set - Photo Etched Grille 49438 Body Set NISMO R34 - Lightweight 49439 Body Set NISMO Silvia - Lightweight Coppermix 49440 TA05 Aluminum Center Plate (Blue) 49441 Aluminum Front Upright Blue M03 M04 FF02 49442 Aluminum Rear Upright Blue M03 M04 49443 M03R Alum Servo Mount - Blue 49444 M03 Aluminum Heat Sink Blue 49445 AM Crystal Set for Expec (01) 49446 AM Crystal Set for Expec (02) 49447 AM Crystal Set for Expec (03) 49448 AM Crystal Set for Expec (04) 49449 AM Crystal Set for Expec (05) 49450 AM Crystal Set for Expec (06) 49451 AM Crystal Set for Expec (07) 49452 AM Crystal Set for Expec (08) 49453 AM Crystal Set for Expec (09) 49454 AM Crystal Set for Expec (10) 49455 AM Crystal Set for Expec (11) 49456 AM Crystal Set for Expec (12) 49457 Toyota Hilux 4x4 Pick Up Body Parts Set 49458 TB02 Drift Spec Chassis Kit 49459 Lunch Box Gold Edition 49460 RTR TNX 5.2R Gold Ed. - TGM04 4x4 Custom Monster Truck 49461 M-Chassis 11-Spoke Wheels - 4pcs Black 49462 TA05 Urethane Bumper Black - Ltd 49463 TRF415 Urethane Bumper - Ltd Black 49464 GB01 Setting Spring Set - White 49465 TT Setting Spring Set - White/Short 49466 M03 Blue Plated Frame Set 49467 M-Chassis 11-Spoke Wheels - 4pcs Blue 49468 M-Chassis 11-Spoke Wheels - 4pcs Silver 49469 M-Chassis 11-Spoke Wheels - 4pcs Fluorescent Yellow 49470 M-Chassis 11-Spoke Wheels - 4pcs Fluorescent Orange 49471 TA05 One-Way Pulley 36T - Ltd Wide Pitch Black 49472 TA05 Diff Pulley 36T - Ltd Wide Pitch Black 49473 06 Module Pinion Gear (22T) - Ltd Hard Coated Aluminum 49474 3mm Countersunk Washer - Ltd 10pcs Blue 49475 DT-02 MS - DT02 49476 DF03 Gear Cover - Ltd Blue 49477 TA05 Body Mount Set - Ltd Blue 49478 TA05 Body Mount Set - Ltd Smoke 49479 TA05 Body Mount Set - Ltd Clear 49480 TRF415 Body Mount Set - Ltd Blue 49481 TRF415 Body Mount Set - Ltd Smoke 49482 TRF415 Body Mount Set - Ltd Clear 49483 Body Set Mini Cooper Racing - Ltd Lightweight 49484 Body Set Mazda RX-7 - Ltd Lightweight 49485 Body Set EBBRO 350R - Ltd Lightweight 49486 NISMO Coppermix Silvia - TB02 Drift Spec 49487 GB03 Titanium Screw Set - Ltd 49488 TRF416 Titanium Screw Set - Ltd 49489 WIillcom Advan Vemac 408R - TA05IFS 49490 Mitsubishi Pajero - Metaltop Wide 49491 TA05IFS-R Chassis Kit 49492 TRF416 Center One-Way Set 49493 TRF416 Front Direct Coupling 49494 49495 49496 49497 49498 F103RM Chassis Kit 49499 Very Early Limited Edition Parts 49500 Not Used 49501 The Grasshopper II Super G 49502-49507 Not Used 49508 McLaren MP4/5B Body Part 49509 Manta Ray QD Black Special Ltd Edition 49510 German Flakpanzer Gepard Kit 49511-49532 Not Used 49533 1/35 R/C Type-74 49534 Flourescent Color Cable 7.2V Connector Set 49535 Fluorescent Silicone Insulated Wires (Green & Yellow) 49536 Fluorescent Nylon Band Small Set (Yellow) 49537 Fluorescent Nylon Band Small Set (Orange) 49538 Fluorescent Nylon Band Small Set (Green) 49539 RD Flourescent Green 70T Plastic Gear 49540 RD Fluorescent Pink 70T Plastic Gear Set 49541 RD Yellow 0.4 Spur Gear Set 94T, 104T 49542 RD Pink 0.4 Spur Gear Set 94T, 104T 49543 TA01 Flourescent Yellow Suspension Arm 49544 Touring/Rally Car Flourescent Green Suspension Arm 49545 Fluorescent Green Adjuster Set 49546 Fluorescent Pink Adjuster Set 49547 4WD Fluorescent Gear Case (Yellow) 49548 4WD Fluorescent Gear Case (Green) 49549 4WD Fluorescent Gear Case (Pink) 49550 Manta Ray TA01 Fluorescent Yellow Chassis 49551 Manta Ray TA01 Flourescent Orange Chassis 49552 Manta Ray TA01 Flourescent Green Chassis 49553 Fluorescent High Torque Servo Saver Set (Yellow) 49554 Fluorescent High Torque Servo Saver Set (Green) 49555 4WD FF Touring Car Fluorescent Orange Damper Spring 49556 4WD FF Touring Car Fluorescent Green Damper Spring 49557 4WD Rally Car Flourescent Yellow Damper Spring 49558 4WD Rally Car Flourescent Pink Damper Spring 49559 4WD/FWD Touring & Rally Car Plated Mesh Wheels 49560 4WD/FWD Touring & Rally Car Plated Spoke Wheels 49561-49566 Not Used 49567 Acto-Power TRF Tuned Motor 49568-49572 Not used 49573 TA02 Chassis White Suspension Arms (F & R). 49574 FWD Touring Car White Suspension Arms (F & R) 49575 Manta Ray White Suspension Arms (F & R) 49576 Castrol Celica Chrome Plated Wheel 4pc 49577 CVA Mini Shock Unit Set II White 49578 TA02 FF White Chassis 49579 TA02 FF Fluorescent chassis (Orange) (1 unit limited) 49580-49591 Not Used 49592 Sauber C12 `94 Tamiya All Japan Champion Special 4593-49594 Not Used 49595 RC Mini Cooper Plated Wheel Rare Limited Edition Event Parts 92179 Mini Cooper Racing Union Jack Sticker 94003 RD Mesh Wheel Set Silver 94023 Mazda 787B Silver Wheel Set 94025 2WD Front Star-Dish Wheels (1 Pair) (Silver) 94027 6029 Rear Star-Dish Wheels (1 Pair) (Silver) 94102 Alfa Romeo 155 Silver Spoke Wheels 94148 Opel Calibra Chrome Wheels Limited Edition Parts (New 42xxx Part Number Series) 42101 RC Pit Bag L - w/3 Inner Boxes 42102 TRF Special Damper Set - Hard Black Coating 42103 TA05MS Chassis Kit 42104 TRF415 MSXX - Marc Rheinard Edition 2007 42105 TRF501X World Championship - World Championship Edition 42106 TRF416 Chassis Kit 42107 42108 630 Teflon Sealed Bearings (2 Pcs) 42109 840 Teflon Sealed Bearings (2 Pcs) 42110 840 Flange Teflon Sealed Bearings (2 Pcs) 42111 850 Teflon Sealed Bearings (2 Pcs) 42112 950 Teflon Sealed Bearings (2 Pcs) 42113 1050 Teflon Sealed Bearings (2 Pcs) 42114 1150 Teflon Sealed Bearings (2 Pcs) 42115 1510 Teflon Sealed Bearings (2 Pcs) 84024 F103 Clear Body Parts Set (Type M ) Share this post Link to post Share on other sites
Singapore_959 18 Posted April 9, 2008 :-P Do you have any photos or descriptions of the following? 49013 Pin Spike Tyre Front (White) 49016 Pin Spike Tyre Rear (White) 49130 Stealth Box 49147 Bag 49165 Screw Case 49185 Harbour Boat 49298 RD F-1 Spoke Wheel Set 3630F/3645R (Black) 94003 RD Mesh Wheel Set Silver and for my own 'to remember' list... :-D 49336 F201 Tuned Chassis Kit - F201 49370 F201 Aluminum Racing Steering 49371 F201 7mm Ball Connector - 2pcs Titanium 49592 Sauber C12 `94 Tamiya All Japan Champion Special 49064 RC Yacht Use 2Ch 2 Servo Radio Set :-) Share this post Link to post Share on other sites
94eg! 834 Posted April 10, 2008 White Pin Spikes can be found on eBay quite regularly. These ones are on there right now: BTW: The F201 Tuned chassis was extra-special because it came with limited "blue" versions of all the standard F201 hop-ups... Share this post Link to post Share on other sites
