salvine 125 Posted August 1, 2014 Just realized that the sway bar would need to be a different length as the rear control arms are different since they are TA01. Did Tamiya make an official set for this chassis? Basically a sway set for the TA01. I don't see it listed as a hop up in the TA02SW manual. I have other bars that would work but just curious if there was on official release. Share this post Link to post Share on other sites
kontemax 1723 Posted August 1, 2014 Tamiya never made a rear sway bar kit for the TA01 so you must buy a TA02 kit and make the bar yourself. The work is very easy. Buy a 2 mm steel wire, usually they are sold in the hobby shops or in the DIY shops. The 2 mm of diamter is identical to the original Tamiya bar. Cut it at the needed lenght with a dremel and a cutting disk and bend it with the help of a table clamp. If the bar is too long you can shorten it with the dremel. Mount your bar with all Tamiya TA02 sway bar kit and keep the original bar away for the future. Et voilĂ , the job is done. For a better finish you can polish it. Max Share this post Link to post Share on other sites
