mongoose1983 3335 Posted April 12, 2012 Well, it happened that when I wanted to give my old Black Foot truck a spin days ago, I come up with this problem. I just don't know a thing about these ESCs. I bought the truck years ago, and the previous owner had this ESC hooked to the Futaba (BEC-ready) receiver, and the truck worked perfectly. Time passed by, and I dismantled the truck to clean and service it a bit, and never seen anything connected to the receiver's "batt" plug. Well, when I wanted to use it again days ago, the truck did not worked. I presume there must be something to do with it, but the ESC has no other cable to match the receiver, and now I am clueless as to what to do. Plus, I don't have a manual or any way to check the model of the ESC (SEE PIC BELOW). What I am trying to do now is to find any info about this FWD-only LRP ESC, and/or the problem I am facing now with my Black Foot not working anymore. Would be great if someone could explain me a bit or share some link to a manual. You all have a great Thursday! Share this post Link to post Share on other sites
bromvw 744 Posted April 12, 2012 CONSIDER IT DONE http://www.rctube.eu/download/rc/instructi...port_Manual.pdf Share this post Link to post Share on other sites
mongoose1983 3335 Posted April 12, 2012 CONSIDER IT DONE lowclasscc.net/.../l/lrp/IPC%20Sport%20Series%20Manual.pdf/ Thanks, brownvw! Even though the link did not worked, I happened to get a manual from that site. Been reading it, but it doesn't say anything about BEC receivers, instead it mentions problems with receiver's battery in the troubleshooting section. I remember running this truck without ever using cells for the receiver. Matter of fact, the only RC car that had the older battery that I have ever ran set up was my Super Champ. Am I crazy or there must have been a way my Black Foot worked without having anything connected to the receiver??? Share this post Link to post Share on other sites
bromvw 744 Posted April 12, 2012 dont know . I'am having enough problems trying to figure out how to do the electrics on my Ford GPA Seep project . Waterproof , two motors running independent of each other+ rudder linked to the steering servo ect ect . WHY OH WHY do i do this ???????????? Share this post Link to post Share on other sites
TA-Mark 195 Posted April 12, 2012 Disconnect the motor wires (you don't want a runaway model). Unplug the ESC's 3 pin receiver plug from the receiver. Plug in a battery to the ESC, then turn on the ESC switch. Check the voltage output of the ESC's receiver plug (red +ve wire and black -ve wire - the white wire is signal). If there is no power at the red/black wires then you have an issue with the ESC itself, or possibly even at the low amp Tamiya battery connector I see in the picture, or in the ESC's on/off switch. If there is power in the red/black wires, plug it back into the receiver CH2 slot and then test the corresponding pins (red/black) at CH1 for the same voltage (6.0v). It may be that the receiver you're using isn't getting power from CH2 like it would have with the old Futaba receiver. Change to a different receiver. Share this post Link to post Share on other sites
WillyChang 1814 Posted April 12, 2012 those little bitty switches get gunked up with dirt & stop working too every LRP i've accumulated came with their switches amputated, solder/short the 2 switch leads for 'on' permanently = plug-n-go Or neater still bridge it at the PCB & remove wires. Share this post Link to post Share on other sites
tonysmini 19 Posted April 13, 2012 as willy said, I have three LRP ESC's, all have the switches removed after they started playing up. Share this post Link to post Share on other sites
mongoose1983 3335 Posted April 14, 2012 Thank you guys. Your help is excellent (as always). I hope to give it another try sometime this weekend. Share this post Link to post Share on other sites
