Sign in to follow this
phunki101
Wanted: Top Force Alloy C-Hubs
Can any one help with these please.....
'Asia Tees' are Out of Stock, 'RC Mart' are Out of Stock, can't find much on eBay either :(
Just wondered if anyone might have some spare in a pit box, un-used???? ......a long shot I know :unsure:
Paul
post-43472-0-96858200-1414794187_thumb.j
Must they be silver?
http://www.rcmart.com/yeah-racing-ta01005bu-alum-bearing-chub-ta01ta02-p-27479.html?cPath=595_744_712
Top Force, Manta Ray, Hummer, DF01, Ta01, TA02, TA02W, TA02T, FF01 -- All use the the same part.
Alternatively, you could use the CC01 hub as well, which also carries the same dimensions/geometry:
http://www.rcmart.com/alloy-chub-silver-p-39392.html?cPath=595_744_1426
*CORRECTION: As Dutch_rc has so kindly pointed out, the CC01 hubs use much larger diameter hinge pins, so they would NOT be compatible!
Fortuna Racing
CC-01 parts are not an exact match - the holes for the shafts are 1mm larger.
Ah yes, thank you for the correction! I forget that the CC01 use those silly steel weights for lower hinges! :ph34r:
I only know because I ordered some for my DF-01 at some point (I wanted black). :rolleyes:
They can be used though, with some 4mm OD / 3mm ID tubing. :)
Does it matter that the mounting hole for the tie rod is on the top as opposed to the side as per kit hubs???? :unsure:
And YES, they do have to be silver as I've got the Knuckles in silver and would like the Hubs to match!!! :D
Nah, the pivot point center is still the same; I think it's just a matter of design aesthetics.
After having a quick search for the part in question, I'm a bit surprised there isn't more inventory to choose from... A ball-raced c-hub is a pretty standard choice among hop-ups for this chassis. Why resellers aren't capitalizing on this is beyond me :blink:
If like me, somebody wants a set of these, found them on ebay from a seller in Hong Kong called RCWorld,
post-43472-0-19147100-1415376167_thumb.j
