Terz1 745 Posted December 13, 2014 Hi all. I've only recently returned to the hobby so sorry for this really basic question. Years back when I was a kid I loved the tamiya rc's, the building, painting and driving. I always remember being disappointed by the run times though, I always wanted to drive it for longer. They seemed to last for 5 or 10 minutes max. So I'd just like to know what good quality, long lasting batteries are out there? I've had a good look but it's a sea of different makes and like anything you have good and bad versions. I'm not really going for speed/racing it's more run time I'd like. It will be powering a mix of tamiya sport and torque tuned motors. I know lipo are probably better performers but I've recently bought a NiMH charger and want to stick with NiMH. Everything's moved on in leaps and bounds since I was last in the hobby 20+ years ago. After a search I found this turnigy 5000mah battery and the price seems amazing. Is this a decent make of battery and what run times could I expect from it powering my tamiya torque tuned and sport tuned motors? Thanks for any help and any recommendations welcome. http://www.hobbyking.co.uk/hobbyking/store/__56159__Turnigy_SC_7_2V_5000mAh_High_Power_Series_NiMH_Stick_Pack.html Share this post Link to post Share on other sites
berman 5315 Posted December 13, 2014 I have only had experience with their lipos which are ok. Depends on the vehicle, but i would expect an average of +/- 45 mins with a silvercan. 1 Share this post Link to post Share on other sites
Terz1 745 Posted December 13, 2014 Thanks berman. 45 minutes would be plenty. Probably slightly less with my sport tuned and torque tuned motors, they're not very high performance after all. I plan on buying a few of these if people recommend them. Share this post Link to post Share on other sites
SteveU30 1011 Posted December 13, 2014 Just bear in mind that high capacity NiMhs weigh a fair bit. 1 Share this post Link to post Share on other sites
SB_Aust 42 Posted December 13, 2014 I have used the above Turnigy 5000mah Nimh since August 2014. Maybe done 20 or so cycles. No complaints so far. Great for the price. Similiar mah battery at my LHS is $70 or more. Turnigy about $30 including postage. Sports tuned i have been getting 40min to 1hour, depending on the terrain. I also have a few of the other types 2000mah and 4200mah also. Good Quality! 1 Share this post Link to post Share on other sites
Terz1 745 Posted December 13, 2014 Thanks steve. I'll bear that in mind. I'll buy some lower capacity NiMh too so I can see the difference the increased weight makes. Thanks SB_Aust . That's sounds pretty good to me. I think I'll give this a go. Share this post Link to post Share on other sites
GregM 1109 Posted December 13, 2014 I've been using Carson 4500mAh NiMH packs and was satisfied with the runtime. Please keep in mind what Steve said about the weight and also the overall dimensions of high capacity NiMH packs. They won't fit into some battery compartments or clash with battery stoppers, e.g. DT-01 and TT-01E. 1 Share this post Link to post Share on other sites
Terz1 745 Posted December 13, 2014 I've been using Carson 4500mAh NiMH packs and was satisfied with the runtime. Please keep in mind what Steve said about the weight and also the overall dimensions of high capacity NiMH packs. They won't fit into some battery compartments or clash with battery stoppers, e.g. DT-01 and TT-01E. I had a little trouble getting a larger pack into my vintage blackfoot. I had to loosen the screws on the battery stopper. I remember it being tight on my hornet too. Thanks for that I'll get some dimensions of my compartments and holders. Share this post Link to post Share on other sites
SteveU30 1011 Posted December 13, 2014 A couple of brass 850 size bushings are good for spacing the back battery stop on models like the ORV chassis and the TL-01 style. 1 Share this post Link to post Share on other sites
Terz1 745 Posted December 13, 2014 That's much better than the plan I had. I was going to cut down some plastic mounts to place between the chassis and the end plate. I'll have a look at getting a set of these. Where did you get yours from steve? Share this post Link to post Share on other sites
SteveU30 1011 Posted December 13, 2014 They came out of RCs that I've upgraded the bushings to bearings, mostly used in gearboxes. However you can buy them cheaply in packs of 10 here: http://www.ebay.co.uk/itm/161393843513?redirect=mobile 1 Share this post Link to post Share on other sites
Terz1 745 Posted December 14, 2014 Thanks for the link. I think I'll have a set of these. Share this post Link to post Share on other sites
Chapel 5 Posted December 18, 2014 When going from NiCD to NiMH, do I need to do anything with the ESC? I would need to build a hump pack for mine as I have a Super Champ 45 minutes on a silver can would be lovely! Share this post Link to post Share on other sites
Terz1 745 Posted December 18, 2014 I don't think any changes are required. I just tested my clodbuster the other day and have a couple of very old batteries. Ones a 2100 NiMH and the other was a 1600 NiCD. Both ran fine with my msc and they were fine in my esc hornet. I think there needs to be some changes to the esc if you go lipo. I'm still learning about everything at the moment but as far as I know it'll be fine. I'm sure someone more knowledgeable will come along soon to help. Share this post Link to post Share on other sites
SteveU30 1011 Posted December 18, 2014 Nope you should be good, the main time for concern is when going from Nickel to Lithium based technology. 1 Share this post Link to post Share on other sites
Chapel 5 Posted December 18, 2014 I'm torn between going to LiPo. I don't want to turn my SRB gearbox to fine powder Share this post Link to post Share on other sites
SteveU30 1011 Posted December 18, 2014 Going LiPo won't put any additional stress on the car, that is down to what motor you use. LiPo just means longer run times, reduced weight and more usable power for longer. Yes you get an extra 0.2v but that's not earth shattering in terms of additional power. Share this post Link to post Share on other sites
Chapel 5 Posted December 18, 2014 yeah, so I could go LiPo with an XL5 ESC and my existing brushed motor no problem, yeah? Share this post Link to post Share on other sites
SteveU30 1011 Posted December 18, 2014 Yep, the XL5 has built in LiPo support so it's essentially plug and play Share this post Link to post Share on other sites
Chapel 5 Posted December 19, 2014 lovely. now I just need to find a cheapo XL5 Share this post Link to post Share on other sites
SteveU30 1011 Posted December 19, 2014 Any reason in particular you're after an XL5? Only reason I ask is that the Hobbywing Quicrun 1060 is similar spec for a fraction of the price. Loads of people on here run them and they're are great value. http://pages.ebay.com/link/?nav=item.view&alt=web&id=261652646194 Share this post Link to post Share on other sites
Chapel 5 Posted December 19, 2014 only because I don't know of anything else my friend told me the XL5 was usable with Nickel and Lithium batteries and had a trainer for my kid I was thinking about this motor/ESC combo but I'm afraid it'll turn the old SRB gearbox to fine white powder http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idproduct=40281 Share this post Link to post Share on other sites
Chapel 5 Posted December 20, 2014 ended up getting an XL5 for about $13 now to find a LiPo that fits Share this post Link to post Share on other sites
