Car list updating ( need help guys )
Started by Stefan(2), May 08 2007 04:25 PM
191 replies to this topic
#151
Posted 29 July 2011 - 09:01 PM
Cheers James
The database is a nightmare to edit, so the error will there for a while, but it will be sorted eventually
To add once more specs available then;
84214: RTR Lotus Type 79 (RC Less Type)
84228: HKS Opel Vectra JTCC FF03
84213: Ferrari F60 Kit (F104) Black OP Special
FOR AVATAR INFO CLICK HERE FOR HOW TO ENTER PHOTO COMPS CLICK HERE
FOR PHOTOS IN FORUMS CLICK HERE
#154
Posted 15 November 2011 - 10:52 PM
Big update needed
42205: TRF417X Chassis Kit
44051: GP Raybrig Honda HSV-010 - 1/10 TG-10 Mk.2 SZ Chassis
57818: RTR Ford Bronco 1973 - CC01
57819: RTR SUMO POWER GT NISSAN GT-R (TT-01 TYPE-E CHASSIS)
57820: RTR Mugen CR-X PRO - M05
57821: RTR Audi R8LMS Nürburgrintg (TT-01 Type-E)
57822: RTR VW Scirocco GT24-CNG (TT-01 TYPE-E)
57823: RTR Ferrari 599XX (TT-01TYPE-E)
57826: RTR 1/12 VW Type 2 (T1) Willy
57828: RTR Attack Buggy
58004: XR311 Combat Buggy
58503: Honda Ballade Sports Mugen - M05 CR-X PRO
58504: Audi R8 LMS 24H Nurburgring - TT01E
58505: Volkswagen Scirocco GT24 - FF03
58506: Ferrari 599XX - TA06
58507: Middle Class Shaft Buggy DB02(Tom's Body)
58508: VW Scirocco GT24-CNG (TT-01 TYPE-E)
58509: Toyota Tom's 84C - RM01
58510: Ferrari 599XX (TT-01 TYPE-E)
58512: 1/12 VW Type゚2 (T1) Willy
58513: Celica LB Turbo Gr.5 (TT-01 TYPE-E)
58514: Mud Blaster II
58516: BMW 318iSTW (TT-0 TYPE-E)
58517: XB Ferrari 599XX (TT-01TYPE-E)
58522: Dune Buggy Street (DT02/380)
84237: Subaru Brat Metallic Sp.
84255: TA05 M-Four Chassis Kit - TA05 M-Four
84262: F104WGP (Inc Body)
84263: Tyrell P34 1977 Monaco GP Type
84264: Nissan R91CP(92 Daytona Champion)
84265: Hotshot (2007) Metallic Special
84266: Toyota GT-One TS020(F103RS Chassis)
84270: Avante (2011)Black Special
92228: M05 S Limited Chassis Kit - S-Spec (Silver Style)
Antony
Antony
#155
Posted 25 January 2012 - 07:49 PM
Big update needed
Finally done 'em, still gotta do;
#157
Posted 17 February 2012 - 01:43 PM
Added - Cheers Steve
#160
Posted 05 March 2012 - 07:12 PM
Do you have the specs?
The more of 'em you got the better, but anything's a help - can't find anything on the interweb about it!
model number
model name
released
category
drive
susspension
chassis
body
motor
original price
width
length
height
wheel base
tread front
tread rear
ground clearance
weight
gear ratio
scale
front tire
rear tire
model number
model name
released
category
drive
susspension
chassis
body
motor
original price
width
length
height
wheel base
tread front
tread rear
ground clearance
weight
gear ratio
scale
front tire
rear tire
#161
Posted 05 March 2012 - 07:53 PM
model number
model name
released
category
drive
susspension
chassis
body
motor
original price
width
length
height
wheel base
tread front
tread rear
ground clearance
weight
gear ratio
scale
front tire
rear tire
Umm
Creative front motor touring car until it is totally different form and first launched, it not like others who are even Tamiya TA03F got that embody femininity, such as machine and popularity.
Overflowing 気gatsuke touring evolve rapidly became violent, like same machine company after that.
Born just before touring car heading to the same direction the TA03F is the companies each theory and is representative of Tamiya had put out the machines in the development of a variety of machines.
TA03F is also the drift machine weight balance and front motor with drifting user's eye, and still have enthusiastic support.
Facts, even once, Tamiya drift tire set past, has limited sales as a drift "TA03F PRO spec".
This person who knows know Kit drifted "TA03F PRO Pack" is revived as Tokai model limited original Kit.
[Dedicated tire in good バランスシャーシ of drift for] set is assembled chassis kits for r/c car drifting and thrilling fun. PRO chassis Kit and front motor 4WD belt TA03F into dedicated drift tires. Increased stability with motor and the weight of the front end, to demonstrate the more responsive due to braking load movement against, prone to drifting car body configuration is attractive. In addition, tire with rubber based special resin, adopted its own shape. It is possible to give it a reasonable grip while long distance driving.
Don't miss the enrichment equipment [fun running 】 enhancement equipment body configurations. Lightweight and adopted a high-rigidity FRP deck frame. Delivers highly efficient drivetrain furbearing specifications and equipped with aluminum die cast made ball differential back and forth, additionally place the drive shaft straight. There's 4-wheel double wishbone suspension with oil damper suspension. In addition, motor thermal standard equipment aluminum motor mount prevents anyone. With your favorite body, enjoy the brilliant driving.
[Basic specifications] ● 387.5 mm ● 183 mm wingspan ● 144.5 mm • 806 g of body weight = ● wheelbase = 257 mm-driven method = ベルトドライブフロントモーターフル 4WD time ● ball diff gear for f/R covariance = def ● steering tie rod = 3 split ● double suspension f/R covariance = Wishbone ● damper = f/R co C... V... A... ダンパーミニ II • gear ratio =7.34:1 ● tire = f/R both width / diameter / 26 mm/65 mm
From http://www.hs-tamtam...item-60034.html
#162
Posted 05 March 2012 - 08:51 PM
Cheers James
#163
Posted 08 March 2012 - 05:30 AM
Umm
Oh wow,
I didn't know that we need these details, next time i will try to get them ;-) I have assumed that it's the same as 58177 which is printed on the manual.
Thanks!!
#164
Posted 08 March 2012 - 10:06 AM
The details are only needed if the kit's not on Tamiya's site - just saves editing the entry later on
92229's been added
92229's been added
#166
Posted 10 April 2012 - 05:42 AM
Good morning!
The mothership has landed:
58527 The Hornet by Jun Watanabe
Release date: Apr 1, 2012
400mm length, 150mm height, 230mm width
"Jun Watanabe (Creative Director): Mr. Watanabe oversees the design department of on-line fashion shopping site ZOZOTOWN. His range of work ranges from website design to branding and TV advertising. In addition to being involved in the design of collaborative fashion projects, he is also known as a movie and video creator. His distinct use of color has been critically acclaimed by both Japanese and international media. A Tamiya fan from an early age, he remains an avid admirer of R/C models."
#167
Posted 10 April 2012 - 07:58 AM
#168
Posted 11 April 2012 - 10:35 AM
Sorted; http://www.tamiyaclu...car.asp?id=1272
Thank you sir!
Any chance that you would have a use for the associated manual? I have it already scanned and ready to go... And no, it's not the same as the regular release version.
#169
Posted 11 April 2012 - 10:41 AM
No worries Steve
You'd have to ask Chris about the manual, they're not something I've ever gotten involved with, sorry.
If you need his contact details, please PM me
#171
Posted 05 June 2012 - 01:41 AM
#174
Posted 09 September 2012 - 06:07 AM
Not sure if you wait for something official from Tamiya but these are 'fairly' official.
58533 1/10 RC Volkswagen Golf 24 (TT-01 chassis TYPE-E)
58534 F-104 PRO version II
58536 Super Fighter GR Violet Racer
58541 1/10 RC BMW M3 E30 SPORT EVO Jagermeister (TT-01 TYPE-E)
58543 1/10 RC Subaru BRZ R & D Sports (TT-01 chassis TYPE-E)
58545 1/10 RC Subaru BRZ (TT-01 chassis TYPE-E)
J
J
#175
Posted 09 September 2012 - 09:07 PM
No, that's as 'official' as it gets chap, many thanks
The only delay is whilst I wait for them to appear on Tamiya's site so that I can copy the description and specs
Once I start adding them I delete 'em from the above quote
EDIT;
Backtomyroots; your post has been moved here http://www.tamiyaclu...=61440&hl=gmade
Reply to this topic
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
