Mark all as read
Lexan Bodies
11 replies to this topic
#1 Drjack
Drjack
    Newbie
  • Members
  • Pip
  • 61 posts
Posted 24 June 2007 - 03:44 AM
Hi all,
I want one of those FJ40 Landcruiser bodies but i've never been keen on the "shorty" type body and since nobody (that I can find) makes a ute body, then i'll have to make one up. What is the best glue and/or technique to cut and shut a lexan body? Thanks in advance,
Chris
#2 Taman
Taman
    Member
  • Members
  • PipPipPip
  • 462 posts
  • Gender:Male
Posted 30 June 2007 - 09:52 AM
Hi Chris,
I did a quick search on Google and came up with the following (this is not my quote, its just a cut paste):
"I checked with Regal Plastics and Laird Plastics about adhesives to glue Lexan (Polycarbonate). Both companies recommend getting THF (Tetrahydrofuran) to attach lexan. The THF is supposed to melt the Lexan's surface and then when you put two pieces together they fuse together"
I honestly dont know if this will work but you could always give it a go on some test pieces. You would also have to try and find some Tetrahydrofuran, Hope this may help :)
#3 Blacque Jacque
Blacque Jacque
    Advanced Member
  • Members
  • PipPipPipPipPip
  • 2700 posts
  • Gender:Male
Posted 30 June 2007 - 10:06 AM
We use THF where I work, yes it will bond lexan, it will bond virtually any plastic including polypropylene which is notoriously difficult to bond.
The biggest problem you're likely to have is getting hold of some, it's an organic solvent & you won't be able to buy it on the high street, if at all, without some kind of chemical manufacturing licence. ;)
I'm sure there must be commercial products to bond lexan :)
#4 Helen
Helen
    Member
  • Members
  • PipPipPip
  • 462 posts
  • Gender:Female
Posted 30 June 2007 - 01:15 PM
Maybe you could sell him some?
#5 Blacque Jacque
Blacque Jacque
    Advanced Member
  • Members
  • PipPipPipPipPip
  • 2700 posts
  • Gender:Male
Posted 30 June 2007 - 01:55 PM
While I'd love to help a member out, I'd have to sign it out from stores & as soon as I do that people start asking questions as to why I want THF for corporate IT purposes :)
THF is NOT NICE STUFF. you don't want to be messing with it without knowing all the risks.
You're more than welcome to get a quote from our sales team though ;) :
http://www.sigmaaldr...ail/SIGMA/T5267
Seriously though, you're better off contacting a decent plastics supplier & asking them about suitable polycarbonate adhesives.
These guys are pretty helpful & knowledgeable, give them a call:
Engineering & Design Plastics
#6 monster_beetle
monster_beetle
    Member
  • Members
  • PipPipPip
  • 1040 posts
  • Gender:Male
Posted 30 June 2007 - 01:56 PM
I used a kinda power glue from loctite. Don't know the number any, I will search for it.
Modern hop-ups for your vintage Tamiya?
www.tamiyaresource.com
#7 Helen
Helen
    Member
  • Members
  • PipPipPip
  • 462 posts
  • Gender:Female
Posted 30 June 2007 - 02:16 PM
Oh I see what you mean
#8 terry.sc
terry.sc
    Advanced Member
  • Members
  • PipPipPipPipPip
  • 6619 posts
  • Gender:Male
Posted 30 June 2007 - 03:08 PM
Firstly cutting and just gluing a polycarbonate shell won't be that strong, the small surface area makes a very weak joint. Usually anyone cutting and shutting a body bolts it together with a strip of plastic behind to reinforce the joint For gluing and reinforcing bodies the best stuff was Racers Choice FenderMender but that has stopped production. Both these methods still leave a visible gap on the outside of the body.
To just glue it together the most common non industrial method of gluing polycarbonate is to use methylene chloride, also known as dichloromethane. This can be found at industrial car paint suppliers, but you will need to buy a large quantity. As you just need a small amount look for Palstruct Plastic Weld, available from hobby shops everywhere.
Posted Image
#9 Blacque Jacque
Blacque Jacque
    Advanced Member
  • Members
  • PipPipPipPipPip
  • 2700 posts
  • Gender:Male
Posted 30 June 2007 - 03:13 PM
We use & sell that too, it's no better for you than THF :) although probably more easily available.
#10 homerboi
homerboi
    Member
  • Members
  • PipPipPip
  • 245 posts
  • Gender:Male
Posted 30 June 2007 - 04:47 PM
Here's a wikipedia definition (more layman) of Tetrahydrofuran - http://en.wikipedia....Tetrahydrofuran
The dichloromethane that Blacque Jacque mentions can be purchased under the name "poly weld" thru a UK company called StarLoc in Liverpool, or on fleabay - http://cgi.ebay.co.u...item=5995545026
I've used this myself on lexan repairs an it works well.
#11 monster_beetle
monster_beetle
    Member
  • Members
  • PipPipPip
  • 1040 posts
  • Gender:Male
Posted 30 June 2007 - 04:50 PM
That loctite I mentioned is nr. 401
#12 thorsteenster
thorsteenster
    Newbie
  • Members
  • Pip
  • 98 posts
Posted 07 July 2007 - 10:10 PM
i did this to a bushwacker, the FJ knock off.
http://www.scale4x4r...amp;postcount=1
i used plastruct bondene. it worked pretty well but before i run it i'll back the joint with shoe goo.
Reply to this topic
