Sign in to follow this
backtomyroots
Dual Motor Wiring Guide For Mt's. (batteries Too).
Okay. Dual motors in your Monster (Wild Dagger/Twin Detonator, Clodbuster/Super Clodbuster, TXT-1/Juggernaut) ?
If you find that the tires are not all going in the "right" direction, simply reverse the positive & negative wires on the motor going in the "wrong direction".
MT's with independent gearboxes such as the Clodbuster & Twin Detonator use motors with "0" degree timing. (TXT, Juggy, E-Maxx this is not req'd).
Hope this is useful. Also, how to set-up dual packs. (this is all obsolete if you have an esc such as the Traxxas EVX, Novak Super Duty as those are plug & go). Cheers.
Finally a guide that doesn't tell you to buy a special "duel motor" esc. As long as the turn limit is low enough, a regular esc will be fine - it doesnt know 2 motors are fitted does it :D
Nice info!
Finally a guide that doesn't tell you to buy a special "duel motor" esc. As long as the turn limit is low enough, a regular esc will be fine - it doesnt know 2 motors are fitted does it B)
Nice info!
Tis what i'm intending to do. Preferably a no limit, but if not something like an 11turn Mtroniks and stick a couple of 23 turn motors on
Two 23 turn motors will be pushing the limit of an RV 11. I remember when i ran my TXT-1 with a single RV 11 and standard motors; the esc would still heat up but obviously didn't mind 27 turn sliver cans.
Following advice on the club, i'm now running my truck with 2 RV 11's connected via a Y lead - powering two 21 turn motors B)
An RV max shouldnt have many problems running two 23 turn motors though.
