Mark all as read
Removing Spray / Paint From A Polycarbonate Shell
9 replies to this topic
#1 Malakite
Malakite
    Member
  • Members
  • PipPipPip
  • 424 posts
  • Gender:Male
Posted 18 May 2008 - 03:40 PM
Is this possible? If so what's the best stuff to use without damaging the shell?
Thanks!
#2 HunterZero
HunterZero
    Advanced Member
  • Members
  • PipPipPipPipPip
  • 2735 posts
Posted 19 May 2008 - 01:21 AM
Forum search is your friend! This has been discussed many times before.
Nitro fuel or methylated spirits/white spirits seem to be the only way to go. Acetone and caustic soda will damage the lexan. But it will take a bit of time and elbow grease, and if the paint is Tamiya PS paint, it may not shift at all. You may be better off just buying a new shell, unless it's a hard to find vintage shell.
There's a graffiti remover that some have reported success with, called Delta Activator, but haven't seen it discussed for a while.
- James
#3 lucasan
lucasan
    Member
  • Members
  • PipPipPip
  • 401 posts
  • Gender:Male
Posted 19 May 2008 - 01:40 AM
Hmm, this is a good question, although I haven't needed to do it yet, I'm about to do some masking on a Durga shell, and if I mess up, I'll be searching this topic. On another tip, what is the difference between Lexan and Poly-Carbonate? Is one preferable to the other, or they the exact same thing, under different names?
#4 taliesin
taliesin
    Advanced Member
  • Members
  • PipPipPipPipPip
  • 2602 posts
  • Gender:Male
Posted 19 May 2008 - 02:27 AM
lexan is the most common brand of polycarbonate, so the two have become synonymous. like calling a copier a xerox whether it is or not. the other body choice is abs and i don't know what the letters stand for, but i believe it is a resin based plastic - similar to styrene maybe. then there is the acrylic like the old windshields are made of for the lunchboxes and such. people call it plexiglass, but again that is a brand name not the compound material.
oh yeah, lexan is usually clear, but in the manufacturing world it sometimes it comes in white, either translucent or opaque, but in the rc world it almost always [never seen otherwise] refers to clear bodies.
cheers. :)
Friends don't let friends drive with Tamiya pinions!
#5 Tamland67
Tamland67
    Newbie
  • Members
  • Pip
  • 59 posts
Posted 19 May 2008 - 06:04 AM
[Hi, what also works is Mr. Muscle ovencleaner. Have stripped several vintage shells with this and works great!
And it does not cloud the shell.
Rgds
Tamland67
#6 HunterZero
HunterZero
    Advanced Member
  • Members
  • PipPipPipPipPip
  • 2735 posts
Posted 19 May 2008 - 07:22 AM
Rgds
Tamland67
Oven cleaners contain caustic soda, which will attack/cloud polycarbonate if left on long enough.
- James
#7 Origineelreclamebord
    Advanced Member
  • Members
  • PipPipPipPipPip
  • 3254 posts
  • Gender:Male
Posted 19 May 2008 - 07:59 AM
Interesting topic :) I still had questions about this myself.
I heard someone say graffiti remover? It may work. I happen to know people that are into graffiti, and I heard that the sprays are made to stick on virtually anything, and like tamiya sprays could prove impossible to remove.
Now I also happen to know that graffiti remover can clean off ink from a ballpoint (which is quite a nasty, almost unremoveable ink) and they use it at our school. I needed to clean my table (and floor) once because my ballpoint had leaked, and amazingly enough it worked. I ended up being dizzy all day, but the floor was almost perfectly clean, the table was like new and both surfaces survived the Graffiti remover ;)
And they say Nitro fuel works, but since there are different mixes of Nitro fuel I still wonder what's best to use. For example, Tornado has 6%, 10%, 16% and 25% fuels. Which would be the best (and relatively safe) choice for removing paint on lexan bodies...?
#8 HunterZero
HunterZero
    Advanced Member
  • Members
  • PipPipPipPipPip
  • 2735 posts
Posted 20 May 2008 - 01:43 AM
Now I also happen to know that graffiti remover can clean off ink from a ballpoint (which is quite a nasty, almost unremoveable ink) and they use it at our school. I needed to clean my table (and floor) once because my ballpoint had leaked, and amazingly enough it worked. I ended up being dizzy all day, but the floor was almost perfectly clean, the table was like new and both surfaces survived the Graffiti remover :)
I would be interested to see this tried on Tamiya PS paint! Mineral spirits/turps is about the only other thing, but it's slow going.
All are safe for polycarbonate, and the higher the percentage of nitro, the better it will work. Under 10% nitro isn't really very good for removing paint.
- James
#9 Origineelreclamebord
    Advanced Member
  • Members
  • PipPipPipPipPip
  • 3254 posts
  • Gender:Male
Posted 20 May 2008 - 05:20 PM
- James
I think I am going to ask the janitor where they buy the graffiti remover, I wanna try it out (I still have a mint but bad painted Alpine shell that needs removing. If it turns out it works on spare pieces of lexan I have laying around for these sorts of experiments, I'll strip it with that completely) :)
#10 terry.sc
terry.sc
    Advanced Member
  • Members
  • PipPipPipPipPip
  • 6619 posts
  • Gender:Male
Posted 20 May 2008 - 08:15 PM
Depends on the graffiti remover. I've tried 'safe' ones that do nothing to Tamiya paint and strong ones that remove the paint but also removes parts of the body.
I can confidently say that Swarfega graffiti remover is the fastest way I've ever seen to turn a body into a soggy dripping mess on the floor :)
Posted Image
Reply to this topic
