I've read and thoroughly enjoyed many build threads on our great forums. I've always planned to do one myself someday, but I always figured it'd be something normal, like a 3-speed Jeep. Well, when I first saw the Pro-Line Helios body, I began making plans to build something with that body. I finally got enough mad money together to start the build, so here it is: I'm building a scale version of the M12 Warthog LRV from the Halo videogame trilogy.
My goals with this project are too build a Warthog based off the Pro-Line Helios body (already ordered and received), as mentioned. My plan is to base it off of a Losi Mini LST (just won on eBay). Now, I think the MLST is the best option for this build, but it's not perfect. The width is about 2" too wide, but I discovered that just about every 1/18 chassis has about the same width. Thus, the suspension will be a bit beefier than on a true Warthog, hence the title: "Lifted" Warthog. I also am working on a fully furnished interior. I want to try my hand at making backlit dispays along with head-and tail lights, and that is one of the spots where I'll need you help! I will also have an authentic Halo driver figure, the Master Chief. However, I could use some input on who will occupy the passenger seat.
Master Chief (center) will have the wheel, but should another SPARTAN (like himself) ride shotgun, or one of his Elite allies (left and right)
So far, I haven't done much. All I've done is make a cardboard mock-up of the interior, that will later be copied in stiff plastic. It is also subject to change when actually mounted on the chassis (sorry for my sorry photography, and yes the center console is missing one side!):
The real Warthog cockpit looks like this:
So, as I wait for the MLST to arrive, I have a few questions for all you savvy scratch-builders:
-- The Warthog has a very distinctive color. I was planning to start with metallic green and work for their, but does anyone have a way to nail the color a bit more directly (maybe a layer of metallic green covered by a layer of olive green)?
-- Should the LED bulbs be wired parallel or in a series (I'm guessing series), and how many volts should I use?
-- What type of paint should I use to paint the displays, allowing for backlight?
-- finally, and maybe this would be be better asked on a Halo forum, but would you prefer a Marine like Master Chief in shotgun, or an alien Elite compatriot (as I already mentioned)?
More questions will surface as a go on, so I hope you'll stay tuned. I also hope you'll enjoy reading this thread as much as I'll like updating it!
EDIT: Freeimagehosting.net is finicky. Some image might not appear all the time. I'm looking for a new hosting service.
