To make a picture appear here which has been hosted in your TCPhotos section, read on.
Ok, the terminology;
Image coding - bit of special interweb wordage to make a TCPhoto visible here
Image title - what the image is 'called' in TCPhotos
Image tags - internet speak for code that makes the picture visible
Assuming you want the large (800 pixels wide) picture to show up, the image coding is;
http ://www.tcphotos.com/pc_userimages/
(please note: there's a space after http that I've put there to make all this legible - you don't need to use the space - it won't work if you do!)
Then you need your own TC membership number (mine's 169)
http ://www.tcphotos.com/pc_userimages/169/
Then, you need the image title.
This is all the text from "img" onwards in the address bar when you're looking at the large pic.
Here's the web address of the pic below;
http ://www.tcphotos.com/getuserimage.asp?t=n&id=img169_15102004222250_6.jpg
So, copy "img" onwards and paste in on the end of the coding
http ://www.tcphotos.com/pc_userimages/169/img169_15102004222250_6.jpg
Once you got all that, add the front and end image tags and it should show up as a picture;
[img]http://www.tcphotos.com/pc_userimages/169/img169_15102004222250_6.jpg[/img]
