Mark all as read
Tell Me About 2.4ghz Stick Radios!
43 replies to this topic
#26 Percymon
Percymon
    Advanced Member
  • Members
  • PipPipPipPipPip
  • 4177 posts
  • Gender:Male
Posted 30 January 2012 - 06:36 PM
ever had any import duty problems from Hobbyking ?
Once, and as it happened it was the package with the rado system in it, along with brushless motors, lipo's etc - i think i got stung for about £24 including handling fee. Hobbyking allow you to set the declaration value as a percentage of the real value. Last package i had was Saturday, value $26, which was 30% of the true retail value. Soem of their radio sets are available from their German warehouse now, so avoids all chance of import suties :)
Visit My Showroom
#27 Live Steam Mad
Live Steam Mad
    Advanced Member
  • Members
  • PipPipPipPipPip
  • 3016 posts
  • Gender:Male
Posted 31 January 2012 - 11:58 PM
I've been using a a Core Code 2.4Ghz stick system for a while - seems excellent - lots of functions if you want them, 15 model memory, and fits into your price requirement.
Posted Image
Available from Modelsport for £84 Modelsport Core Code CR138
Please can you tell me how far apart the centres of the two sticks are in mm?
I like the Futaba Attack-R / Hitec Ranger Sky / Acoms AP227 MK1/2/3 sized control where the sticks are 90mm apart (Attack-R) and 93mm apart (Ranger III / Ranger 3 FM Sky 40MHz) and 92.5mm apart (Acoms MK3).
The Futaba T6XS has the sticks 103mm apart, I assume it's the same measurement on the 4YF, 4VWD, etc, which feels significantly less comfortable for me personally as I have smaller hands.
Cheers,
Alistair G.
in NW & want to recreate vintage FUN races? Contact me!
Posted Image
#28 Live Steam Mad
Live Steam Mad
    Advanced Member
  • Members
  • PipPipPipPipPip
  • 3016 posts
  • Gender:Male
Posted 01 February 2012 - 12:01 AM
You only need to bind the radio to the receiver once.
Ahh, many thanks for that, I wasn't aware of that (also confirmed in a forums search).
Once I find a comfortable and affordable 2.4GHz sticks set I will go for one I think.
Need to find one where the sticks are around 90mm apart, as the aeroplane / Heli 6+ channel sets have the sticks too far apart for me to be really comfortable using it. That's why I like the old 2 channel AM ones such as Attack-R, Ranger III, Acoms MK3 etc (well Ranger is FM not AM) where the sticks are closer together.
Cheers,
Alistair G.
Posted Image
#29 sosidge
sosidge
    Member
  • Members
  • PipPipPip
  • 1267 posts
Posted 01 February 2012 - 10:06 AM
Cheers,
Alistair G.
I can't measure one because I don't own one, but they are small, the casing is probably smaller than many Acoms/Futaba 2-channel sets.
Personally speaking I hate the feel in the hand, but I have large hands and I'm used to a 3VC.
I suspect that the distance between the sticks is less important than the relative dimensions, weight and balance point of the case.
#30 Live Steam Mad
Live Steam Mad
    Advanced Member
  • Members
  • PipPipPipPipPip
  • 3016 posts
  • Gender:Male
Posted 01 February 2012 - 05:14 PM
Could be LOL. I got this reply back from ModelSport when I asked them about the "CR151 Core RC Code 2.4GHz 3-Channel FHSS LCD Stick Combo" that they sell ;-
"Wouldn't it be the distance between the edge of the transmitter to the stick that matters, as this is where your hands will be holding it, rather than the distance between the 2 sticks?
Anyway, it's 100mm."
LOL
Cheers,
Alistair G.
Posted Image
#31 Singleseven
Singleseven
    Member
  • Members
  • PipPipPip
  • 265 posts
  • Gender:Male
Posted 18 February 2012 - 09:14 PM
Hi All,
I have an Acoms AP2402 2.4ghz set, which comes with a GR-24 receiver. Please can someone tell me that, if I buy another GR-24 receiver and place it in a second car, I can use the same handset to control either car? I've noticed that some transmitters refer to multi- model memory, i.e. as mentioned earlier in this thread, and the AP2402 doesn't appear to have one so I'm not sure if that means I can only use one transmitter to one reciever.
Check out the Rough Rider Buggy Champ SIG
Posted Image
http://www.tamiyaclu...mber.asp?id=231
#32 wolfdogstinkus
wolfdogstinkus
    Member
  • Members
  • PipPipPip
  • 1680 posts
  • Gender:Male
Posted 18 February 2012 - 09:18 PM
Hi All,
@SingleSeven. Yes you can use the same transmitter, just got this set myself and picked up an extra receiver for £23 posted which I thought was really good. You just switch on the transmitter and then the car of your choice and you are ready to go. (after intial receiver set up, which only needs done once :D )
#33 Singleseven
Singleseven
    Member
  • Members
  • PipPipPip
  • 265 posts
  • Gender:Male
Posted 18 February 2012 - 10:15 PM
@SingleSeven. Yes you can use the same transmitter, just got this set myself and picked up an extra receiver for £23 posted which I thought was really good. You just switch on the transmitter and then the car of your choice and you are ready to go. (after intial receiver set up, which only needs done once :) )
That great! Thanks very much wolfdogstinkus :D
Posted Image
#34 wolfdogstinkus
wolfdogstinkus
    Member
  • Members
  • PipPipPip
  • 1680 posts
  • Gender:Male
Posted 18 February 2012 - 10:21 PM
No problem,It worked out cheaper than buying the 27Mhz system. This seems to be a good budget 2.4 system :)
#35 Live Steam Mad
Live Steam Mad
    Advanced Member
  • Members
  • PipPipPipPipPip
  • 3016 posts
  • Gender:Male
Posted 19 February 2012 - 12:53 AM
Hi All,
Hi, can you tell me the distance between the centres of the 2 sticks please? And how wide the Transmitter (TX) is in total?
Also, does the TX have any special features like EPA (ATV) etc? I assume it at least has 2 servo reversers, one per channel.
What power cells / battery does the TX use?
Cheers,
Alistair G.
Posted Image
#36 wolfdogstinkus
wolfdogstinkus
    Member
  • Members
  • PipPipPip
  • 1680 posts
  • Gender:Male
Posted 19 February 2012 - 01:33 AM
@LiveSteamMad, The transmitter takes 4 AA batteries, I will get the measurements for you tomorrow. :angry: , Oh and just the servo reverse on both sides and a digital trim. Another feature I thought was cool is that you can change the sticks over from left to right so the throttle would be on the right and steering on the left. It tells you how to do it in the instructions.
Edit2Add: fuzzy photo, sorry bout the quality of this picture,
Posted Image
Here's my other receiver :D
Posted Image
Sorry again about the quality of this,
Posted Image
#37 sosidge
sosidge
    Member
  • Members
  • PipPipPip
  • 1267 posts
Posted 19 February 2012 - 11:32 AM
Hi All,
Although you can bind a transmitter easily to multiple receivers - since that transmitter does not have a model memory, you will be resetting the trims (and any other settings you may have changed) every time you switch to a different model. This can be a bit of a nuisance.
#38 wolfdogstinkus
wolfdogstinkus
    Member
  • Members
  • PipPipPip
  • 1680 posts
  • Gender:Male
Posted 19 February 2012 - 01:25 PM
Thanks Sosidge, I wondered what the model memory was for. :angry: This system only has the trims and servo reverse, so not much to set up when you change cars.
#39 wolfdogstinkus
wolfdogstinkus
    Member
  • Members
  • PipPipPip
  • 1680 posts
  • Gender:Male
Posted 19 February 2012 - 04:40 PM
Cheers,
Alistair G.
90mm between sticks from centre to centre. and around 170mm at widest part of transmitter, hope that helps. ;)
#40 Singleseven
Singleseven
    Member
  • Members
  • PipPipPip
  • 265 posts
  • Gender:Male
Posted 19 February 2012 - 09:04 PM
Good point! thanks for your reply ;)
Posted Image
#41 bromvw
bromvw
    Advanced Member
  • Members
  • PipPipPipPipPip
  • 2656 posts
  • Gender:Male
Posted 19 February 2012 - 09:31 PM
I'am in the oposite position . Having just bought my first 2.4 Gig wheel set i'am having to learn to drive all over again . So far i think i actually perfer it to sticks.PS i have hands like builders shovels but its fine ;)
#42 wolfdogstinkus
wolfdogstinkus
    Member
  • Members
  • PipPipPip
  • 1680 posts
  • Gender:Male
Posted 19 February 2012 - 09:41 PM
What system have you got Bromvw?
#43 bromvw
bromvw
    Advanced Member
  • Members
  • PipPipPipPipPip
  • 2656 posts
  • Gender:Male
Posted 19 February 2012 - 09:48 PM
Ansmann W5 . Its just a budget system but works well with the Etronix brushless 4370kv and 60amp Esc .
#44 Live Steam Mad
Live Steam Mad
    Advanced Member
  • Members
  • PipPipPipPipPip
  • 3016 posts
  • Gender:Male
Posted 16 March 2012 - 12:50 AM
Are there any of these 2.4GHz stick radios that I can order from a more affordable source like Hong Kong ? Anyone got some links?
MUST be 2 axis only (left stick throttle, can't be moved left right, and right stick steering, can't be moved up/down) or if someone has steering / throttle gates available that would also be fine.
Cheers,
ARG
Posted Image
Reply to this topic
