Mark all as read
Velineon Traxxas Vxl3's On Df03ra
17 replies to this topic
#1 maherbeemer
maherbeemer
    Newbie
  • Members
  • Pip
  • 14 posts
Posted 29 September 2010 - 03:09 PM
Gents,
I ordered the velineon traxxas vxl3's brushless system; I called a hobby shop and was told that it should work with no problems??? but now I am afraid I spent 160 dollars I still didnt recieve it yet, so I thought this is the best place to get some info on the installing the ESC and the brushless motor on the DF03RA, does it fit with no problems???? any feedback is very good. Thanks.
#2 Mud-Plugger
Mud-Plugger
    Member
  • Members
  • PipPipPip
  • 429 posts
  • Gender:Male
Posted 29 September 2010 - 06:03 PM
It will fit with no problems.
#3 maherbeemer
maherbeemer
    Newbie
  • Members
  • Pip
  • 14 posts
Posted 29 September 2010 - 06:38 PM
Ok thanks are you suuuure? i keep getting different answers??? do I have to mod something on the DF03RA????
#4 Mud-Plugger
Mud-Plugger
    Member
  • Members
  • PipPipPip
  • 429 posts
  • Gender:Male
Posted 29 September 2010 - 07:31 PM
I can see where your queery lies. I have just had a look at their website and it shows the motor with a plastic end cap and the wires going back towards the output shaft. This is strange as I bought mine new and I have no cap and the wires come out in normal fashion away from the motor. Have wiggled it in and the motor mounting screws line up o.k.
If they're all as in the picture on their website I would think you would have problems as there is no space fo the wires to return across the chassis.
Mud
#5 maherbeemer
maherbeemer
    Newbie
  • Members
  • Pip
  • 14 posts
Posted 29 September 2010 - 07:51 PM
Mud
**** man??? anyone installed it on here??? is there any hope????? I guess money went down the drain I should have bought the tamiya brushless motor.
#6 kaiser
kaiser
    Member
  • Members
  • PipPipPip
  • 1097 posts
  • Gender:Male
Posted 29 September 2010 - 08:16 PM
no you should have bought a hobbywing system. :huh:
best value in brushless by far.
but hey, it's on it's way right? wait until it get there and try it out. you may have to extend the wires or something.
#7 stu22
stu22
    Member
  • Members
  • PipPipPip
  • 505 posts
  • Gender:Male
Posted 30 September 2010 - 04:25 AM
You may be in some trouble here. I tried mounting a spare Velineon 10T in an Associated B4 and the thing would not line up correctly. The holes for the mounting screws are farther appart than on a 540 sized motor. This in turn made it impossible to get the pinion to mesh with the spur gear correctly. Taking a quick look at my DF03 and the Velineon motor I think the 550 sized can will be too big and even if it was not, you will not be able to mount the thing to the gearbox.
#8 maherbeemer
maherbeemer
    Newbie
  • Members
  • Pip
  • 14 posts
Posted 30 September 2010 - 04:40 AM
I guess i'll wait until it arrives and see what I can do; do you think its only because the wires go the opposite way? as for the cap it can be removed from the motor.
#9 maherbeemer
maherbeemer
    Newbie
  • Members
  • Pip
  • 14 posts
Posted 30 September 2010 - 04:46 AM
Check this out:
#10 maherbeemer
maherbeemer
    Newbie
  • Members
  • Pip
  • 14 posts
Posted 30 September 2010 - 12:43 PM
According to the specs of the 3500 motor its a 540.
#11 bossgrabber1970
bossgrabber1970
    Member
  • Members
  • PipPipPip
  • 119 posts
  • Gender:Male
Posted 30 September 2010 - 02:08 PM
i had a traxxas velineon and from what i saw it has the standard mounting holes as a 540 size motor. as for the black cover, it's removeable but it will take a little prying to get it off. as for the wire length, you should be fine with no problems if you are using the traxxas speed control, those wires are pretty long. the esc and motor combo you ordered, is it the waterproof version?
#12 maherbeemer
maherbeemer
    Newbie
  • Members
  • Pip
  • 14 posts
Posted 30 September 2010 - 03:52 PM
Yes it is.
#13 bossgrabber1970
bossgrabber1970
    Member
  • Members
  • PipPipPip
  • 119 posts
  • Gender:Male
Posted 30 September 2010 - 04:00 PM
there shouldn't be any issue mounting it to the chassis, just routing the wires so it won't contact the driveshaft to the front diff. the motor have 6 mounting holes so the motor can be positioned where you need it. one thing i learned about the esc is that it DOESN'T like excessive heat. i burned 2 of them out because of it. the cooling fan i had bought for it only did so much. just be careful on the gearing and watch the motor temp.
#14 maherbeemer
maherbeemer
    Newbie
  • Members
  • Pip
  • 14 posts
Posted 30 September 2010 - 04:04 PM
You can see all the PDF files for specs from here.
http://www.traxxas.c...s_vxl3s_h2o.htm
#15 stu22
stu22
    Member
  • Members
  • PipPipPip
  • 505 posts
  • Gender:Male
Posted 30 September 2010 - 04:09 PM
You're right, my problems with the B4 were with the Titan 12T and not the Velineon 10T. Sorry everyone
#16 maherbeemer
maherbeemer
    Newbie
  • Members
  • Pip
  • 14 posts
Posted 30 September 2010 - 04:34 PM
Hey guys, found someone who did it, but it looks like its needs moding.
you can see the pics from here:
http://www.rctech.ne...366-post10.html
"I was making my DF03ra into a waterproof runner. To make the Velineon system fit I had to re-solder the motor connection on the opposite side, remove the end cap and make a spacer to extend the motor so I didn't have to modify the chassis. I also had to cut the ears off of the Velineon ESC so it would fit flush in the chassis. The Velineon system is simply too much for the car. It has so much torque that I think you could easily destroy the drive-train if you weren't careful.
I've since pulled out that system and put it in my Hyper 10SC. So now I'm gonna just put a Mamba Max w/4600kv combo in there and call it a day."
#17 bossgrabber1970
bossgrabber1970
    Member
  • Members
  • PipPipPip
  • 119 posts
  • Gender:Male
Posted 30 September 2010 - 08:26 PM
[/quote]
the mamba max 4600kv has more power than the traxxas 3500kv. so, in my somewhat "logical" thinking, wouldn't he have to worry more about drivetrain reliability??????? any ideas on this one???? :D
#18 maherbeemer
maherbeemer
    Newbie
  • Members
  • Pip
  • 14 posts
Posted 01 October 2010 - 01:41 PM
the mamba max 4600kv has more power than the traxxas 3500kv. so, in my somewhat "logical" thinking, wouldn't he have to worry more about drivetrain reliability??????? any ideas on this one???? :P
True the VXL is only 3500kV, but it's also a long can 540 motor. More like a 550 motor. A side effect of the longer can makes the motor have much more torque. Also, the lower the kV the more torque a motor has. The higher the kV the higher the RPM which equals more speed.
Reply to this topic
