Mark all as read
Holiday Buggy Appreciation Society
265 replies to this topic
#151 Kencocat
Kencocat
    Newbie
  • Members
  • Pip
  • 28 posts
  • Gender:Male
Posted 15 February 2012 - 02:16 PM
Hi, treated myself to a HB2010 at Xmas which my 6 year old Son has since commandeered as his!
He’s used and abused the buggy, frying the Tamiya esc by driving through puddles, splitting the wheel arch but we’ve both had such a good time and it’s bought back memories of me and my dad back in the 80’s finding areas of woodland to run my falcon, sorry about getting all nostalgic!
I do have a question, I’ve picked up a second HB2010 for me and was wondering if its safe to encase the Tamiya ESC in a balloon for wet weather driving? It will be running a silver can 540.
Neil
#152 taliesin
taliesin
    Advanced Member
  • Members
  • PipPipPipPipPip
  • 2594 posts
  • Gender:Male
Posted 15 February 2012 - 02:56 PM
Neil
Shouldn't hurt with the stock 540 but I wouldn't use a fast motor in this buggy with the ESC enclosed. Glad you & your son are having fun with the HB2010! Pictures are good. :D
Friends don't let friends drive with Tamiya pinions!
#153 mr crispy
mr crispy
    Member
  • Members
  • PipPipPip
  • 929 posts
  • Gender:Male
Posted 15 February 2012 - 03:02 PM
You may have heat issues with the esc in a balloon. The old trick was to connect up you receiver, make sure all the plugs are tight and test it to check its working correctly. Then squeeze the whole receiver into the balloon and secure it with a cable tie. Esc can be tricker but a good method Ive used is to coat them in a thorough layer of silicone sealant (you can get it for bathrooms in DIY stores or better still Halfords sell it in black by the tube) so the only bits that's clear is the heat sink. You'll still be able to see the light flash and you'll need something like a nail to press the reset button. It's best to do this after you've fixed it into the chassis as the silicone doesn't let much stuck to it once it's on.
A day without R/C is like a day without sunshine!
My R/C Cars
#154 Thommo
Thommo
    Member
  • Members
  • PipPipPip
  • 653 posts
  • Gender:Male
Posted 24 March 2012 - 07:46 AM
Well here is my entry into the Holiday Buggy Appreciation Society. This is the first time the body has been fitted. I still have to programme the ESC, mount the switch and charge a battery so it will see dirt for the first time pretty soon. Thanks to everyone on this thread for your help and inspiration guys, (I've got just finished new build stoke right now) ;) I matched the roof with the body and omitted the guard (fender) decals. Painted the jerry cans Dark Sea Grey to match the Sand Viper wheels. Power system is a 4000kv 8.5t EZrun that I will tone down at first. Robinson Racing 17t steel pinion. CVA dampers with soft springs. Sandviper wheels and tyres. 3 Racing front camber links and tie rods. The diff has a whole 3g tub of AW grease packed in there too ;)
I hope you like it guys and I can't wait to drive it. Cheers.
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
#155 Theibault
Theibault
    Member
  • Members
  • PipPipPip
  • 342 posts
  • Gender:Male
Posted 25 March 2012 - 02:46 PM
Great looking buggy! I bet that thing just flies with that esc/motor.
#156 Thommo
Thommo
    Member
  • Members
  • PipPipPip
  • 653 posts
  • Gender:Male
Posted 26 March 2012 - 04:16 AM
Thanks Theibault. Dito for your Super Hotshot mate, looks great. I programmed the ESC last night with the punch setting at 1. (soft) and 0 timing advance and we will see how it goes as it's still untested.
I hope it does fly, just not literally :( Cheers.
#157 GregM
GregM
    Member
  • Members
  • PipPipPip
  • 1003 posts
  • Gender:Male
Posted 26 March 2012 - 07:09 AM
I see that you've mounted the front shocks the normal way. Aren't the caps hitting the body, as the manual suggests the shocks to be mounted upside down, and to shorten the length when using mini CVA oil shocks?
Posted Image
#158 mtbkym01
mtbkym01
    Member
  • Members
  • PipPipPip
  • 1405 posts
  • Gender:Male
Posted 26 March 2012 - 07:24 AM
I put a 3600kv in mine, but went with the bigger pinion :( , it does 2 inch high wheelies at speed, the thing is nuts
Posted Image
Posted Image
Should probably put the 17t pinion in it myself
Well here is my entry into the Holiday Buggy Appreciation Society. This is the first time the body has been fitted. I still have to programme the ESC, mount the switch and charge a battery so it will see dirt for the first time pretty soon. Thanks to everyone on this thread for your help and inspiration guys, (I've got just finished new build stoke right now) :huh: I matched the roof with the body and omitted the guard (fender) decals. Painted the jerry cans Dark Sea Grey to match the Sand Viper wheels. Power system is a 4000kv 8.5t EZrun that I will tone down at first. Robinson Racing 17t steel pinion. CVA dampers with soft springs. Sandviper wheels and tyres. 3 Racing front camber links and tie rods. The diff has a whole 3g tub of AW grease packed in there too :lol:
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Looks great mate, I know mine above is nuts as it is, be interesting how your beast goes for sure, good job
You Name It......And I Want It!
#159 Thommo
Thommo
    Member
  • Members
  • PipPipPip
  • 653 posts
  • Gender:Male
Posted 26 March 2012 - 08:23 AM
They are very close so now I will have another look at them, cheers. The manual calls for 64mm but 65mm is as close as I could get (or they are 64mm and my eyeball / ruler measuring is out) :(
Thanks buddy, your one and BMT's entry influenced this build for sure. I will post up after the shakedown run but I have decided to make a few changes first. I just received a DF03 setting spring set and the ball nuts that I need to fit an adjustable rear camber link so it's back to the workbench.
#160 Thommo
Thommo
    Member
  • Members
  • PipPipPip
  • 653 posts
  • Gender:Male
Posted 01 April 2012 - 02:24 PM
I ran the Holiday Buggy with 8.5t EZ Run brushless first the first time today. It was a great success and I will keep it this way for a while. It absolutely hammers and even with the punch and timing turned right down, it wheelies from about 3/4 throttle at any speed. The DT02 chassis can definately handle the power, I'm just not sure for how long. Handles the jumps pretty well too. Motor temp was fine, I got through a 3800mah 2S pack with only a couple of short breaks to check the temp and all OK. I flipped it a couple of times, nothing broke, the wheels didn't fly off so happy days.
The Holiday Buggy looks awesome at speed and in the air. It's now my favourite runner and the best thing is that the driver looks like Queensland MP, Bob Katter :lol:
#161 mtbkym01
mtbkym01
    Member
  • Members
  • PipPipPip
  • 1405 posts
  • Gender:Male
Posted 02 April 2012 - 07:52 AM
The Holiday Buggy looks awesome at speed and in the air. It's now my favourite runner and the best thing is that the driver looks like Queensland MP, Bob Katter :)
Ha Bob Katter, classic. I like the idea of the AW grease diff, coz I think mine unloads too easily, did yours stay planted?
#162 Thommo
Thommo
    Member
  • Members
  • PipPipPip
  • 653 posts
  • Gender:Male
Posted 02 April 2012 - 08:55 AM
Mate I can just see Bob Katter driving one of these, makes me laugh every time I look at him.
Yeah, the diff has loosened up a bit after the shakedown run but both wheels are spinning up together under power every time. Even coming out of a power slide and hammering it, it would square up beautifully with both wheels roosting dirt and it never spun one wheel only. I packed the diff completely with AW grease, to the point where pushing the drive cups in forced AW grease back out past the shaft.
#163 mtbkym01
mtbkym01
    Member
  • Members
  • PipPipPip
  • 1405 posts
  • Gender:Male
Posted 03 April 2012 - 12:18 AM
Good to know, will try it in mine, gonna take it down to our local bash track this Saturday, might show a few Short Course trucks how it's done HAHA
#164 skip665
skip665
    Member
  • Members
  • PipPipPip
  • 1416 posts
  • Gender:Male
Posted 12 April 2012 - 07:06 PM
Dragged my Holiday Buggy from the loft today and decided to rip the 380 motor out and try a SuperStock RZ on a 17t pinion along with a 3300mah 2S lipo for the first time - whoa the thing hauls now!! Have only tried it on asphalt so far (off-road test is tomorrow) but have nearly shredded the Super Grippers already :lol: Guess I will be on the look out for something better on the rear soon.
Still love this thing and it now has the speed to match the looks ;)
Drive 'em, don't hide 'em!!
#165 bromvw
bromvw
    Advanced Member
  • Members
  • PipPipPipPipPip
  • 2685 posts
  • Gender:Male
Posted 12 April 2012 - 07:09 PM
Best tires i've tried in terms of lasting are the proline dirt dawgs . Good grip on all surfaces
#166 skip665
skip665
    Member
  • Members
  • PipPipPip
  • 1416 posts
  • Gender:Male
Posted 12 April 2012 - 07:11 PM
Thanks for that - even sand though? The BMX track I usually go to is all sand and I assumed I would need something spiky?
#167 bromvw
bromvw
    Advanced Member
  • Members
  • PipPipPipPipPip
  • 2685 posts
  • Gender:Male
Posted 12 April 2012 - 07:12 PM
so long as its not deep soft sand they'll be fine . For deep sand use the sand slingers .
#168 skip665
skip665
    Member
  • Members
  • PipPipPip
  • 1416 posts
  • Gender:Male
Posted 12 April 2012 - 07:13 PM
Cheers - will look them up ;)
#169 Will16
Will16
    Member
  • Members
  • PipPipPip
  • 759 posts
  • Gender:Male
Posted 13 April 2012 - 01:19 PM
Noooo for deep sand you need 2.2" Panther Paddles!!
Yes as bromvw said Proline DIrt Hawgs are great tyres! I''ve got a set, and you will need to glue them the your wheels.
Posted Image Me.
#170 markbt73
markbt73
    Member
  • Members
  • PipPipPip
  • 1508 posts
  • Gender:Male
Posted 19 May 2012 - 01:33 AM
Dug out my HB and started tinkering with it again... trying to turn it into the "perfect" backyard basher. First things first, more ground clearance. Oh, but whoops, bigger tires won't clear the fenders... what to do...
Oh, I know!
Posted Image
Sort of has a class 1-ish look to it now... I really like it. Cuts are ragged, but I'll clean them up eventually.
Posted Image
It does, however, need more power now. I had switched back to the 380 for run times, but with the 2.2s it can't get out of its own way. Where did I put that 17 tooth pinion...?
#171 shenlonco
shenlonco
    Member
  • Members
  • PipPipPip
  • 868 posts
Posted 19 May 2012 - 01:45 AM
That looks neat with the fenders off!I just put a set of blitzer beetle shocks on mine.
Oh, I know!
Posted Image
Posted Image
Catch me if you can!
#172 B.M.T.
B.M.T.
    Member
  • Members
  • PipPipPip
  • 1515 posts
  • Gender:Male
Posted 19 May 2012 - 05:06 AM
<p>Tommo, that looks a lot like what I did. HB body + race propped Desert Gator =
http://www.tamiyaclu...011035910_4.jpg
QUOTE(TWINSET @ May 13 2008, 10:15 AM) View Post
:lol: It probably won't destroy planets either
#173 mr crispy
mr crispy
    Member
  • Members
  • PipPipPip
  • 929 posts
  • Gender:Male
Posted 17 July 2012 - 06:12 AM
What's better than a Sunday morning blast in the sunshine with your favourite runner. Got out to Box Hill this weekend with my brother and his son, we took out HB's and my nephews crawler and entertained the locals with the usual donuts, wheelspins, J turns and a couple of spectacular tumbling wipeouts! Great fun had by all.
Posted Image
My brother getting the perfect photo.
Posted Image
Quick halftime battery change. My chassis cover makes a good body clip holder.
Posted Image
My HB2010 in the Surrey Hills
Posted Image
Letting the mud dry with a fresh coffee.
Posted Image
Always found Box Hill to be pretty RC friendly although we did find a few "dog mines" this trip. They've closed off the main car park and built a tempory TV studio there to report on the Olympic cycles race that's happening at the end of the month.
My R/C Cars
#174 shenlonco
shenlonco
    Member
  • Members
  • PipPipPip
  • 868 posts
Posted 17 July 2012 - 01:24 PM
Looks like you had fun.
I found my HB body is cracking all around those 2 big screws you screw through the hood to hold in the interior in and i only ran mine 2 times and did not beat on it at all it happened from just sitting... I do remember those screws they give you to screw in felt to me to big and hard to screw in the part..... maybe i just over tightened it ... anyones body have hair line cracks around those two screws?
#175 GregM
GregM
    Member
  • Members
  • PipPipPip
  • 1003 posts
  • Gender:Male
Posted 19 July 2012 - 07:03 AM
Well, I can't help you, as I broke the body accidentally right at the first run. :(
As a Mabuchi RS-540 motor is a bit too fast for my needs (I'm in the fear of breaking another lovely bodyset), I wonder if the Tamiya CR-Tuned motor or similar motors would be a good choice for scale running at slightly lower speeds with torque. I haven't tried out the 380 motor yet, but I don't know if the small 380 has enough torque to get this vehicle (the body isn't lightweight) over obstacles and grass.
Posted Image
Reply to this topic
