Mark all as read
Kiddies Motorbike battery
13 replies to this topic
#1 Malakite
Malakite
    Member
  • Members
  • PipPipPip
  • 424 posts
  • Gender:Male
Posted 29 August 2011 - 09:45 PM
Hi Guys, any ideas where I may be able to get a replacement battery like this one at all?? I need it for a childrens motorbike - I purchased the bike second hand but I am afraid the battery has had it!!
Thanks as always,
#2 TA-Mark
TA-Mark
    Advanced Member
  • Members
  • PipPipPipPipPip
  • 5197 posts
  • Gender:Male
Posted 29 August 2011 - 11:08 PM
It's a sealed lead acid 6.0v battery. A battery centre would have something similar. Replacement would need to be 6.0 volt, and have a capacity of 4AH or higher.
Something like this from budgetbatteries.co.uk should make a suitable replacement provided the dimensions fit the battery holder.
#3 3minits
3minits
    Newbie
  • Members
  • Pip
  • 23 posts
Posted 30 August 2011 - 08:51 AM
Or a place that does electric wheel chairs should do stuff like that, and a lot of towns have one of them in them!
#4 Malakite
Malakite
    Member
  • Members
  • PipPipPip
  • 424 posts
  • Gender:Male
Posted 30 August 2011 - 10:08 AM
Thanks guys i'll look into it :D
#5 Percymon
Percymon
    Advanced Member
  • Members
  • PipPipPipPipPip
  • 4277 posts
  • Gender:Male
Posted 30 August 2011 - 11:44 AM
Same thin via ebay..
http://www.ebay.co.u...=item20b725f6eb
Visit My Showroom
#6 Mighty flex
Mighty flex
    Member
  • Members
  • PipPipPip
  • 235 posts
  • Gender:Male
Posted 30 August 2011 - 12:01 PM
Brushless conversion with 6s lipo! do it!
:D
#7 Malakite
Malakite
    Member
  • Members
  • PipPipPip
  • 424 posts
  • Gender:Male
Posted 24 July 2012 - 04:27 PM
Hi guys - ok so I think the internal charger has broken within the bike as the battery is not charging - I have the original from it and also a new replacement I purchased after your help on here!
The question is - what charger can I purchase to see if its the charger? I cannot see what to purchase? Just a cheapo will be fine and overnight is fine - I just cant't seem to find what I need!
#8 wolfdogstinkus
wolfdogstinkus
    Member
  • Members
  • PipPipPip
  • 1694 posts
  • Gender:Male
Posted 24 July 2012 - 08:45 PM
Hi Malakite
Argos do a cheap car battery charger that switches between 6volts for bikes and 12volts for cars, might be worth checking out?. Or any motor parts place should sell something suitable.
#9 Malakite
Malakite
    Member
  • Members
  • PipPipPip
  • 424 posts
  • Gender:Male
Posted 24 July 2012 - 09:01 PM
Hi Malakite
Thanks will check it out - any link at all?
#10 wolfdogstinkus
wolfdogstinkus
    Member
  • Members
  • PipPipPip
  • 1694 posts
  • Gender:Male
Posted 24 July 2012 - 09:31 PM
Something like this might work?.
But you have to make sure the switch is on 6volt.http://www.ebay.co.u...=item1e6c88beafYou are in the U.k?
#11 Malakite
Malakite
    Member
  • Members
  • PipPipPip
  • 424 posts
  • Gender:Male
Posted 24 July 2012 - 11:03 PM
Hi there - yes I am! I do have a Graupner Ultramat 14 charger but I don't think it works with this type of battery!
#12 Malakite
Malakite
    Member
  • Members
  • PipPipPip
  • 424 posts
  • Gender:Male
Posted 25 July 2012 - 09:44 AM
Also I wonder if I make some crocodile clips instead of the standard Tamiya 7.2v battery connector that comes from it to charge my car batteries, if this will work as a charging unit - does anyone know??
#13 TA-Mark
TA-Mark
    Advanced Member
  • Members
  • PipPipPipPipPip
  • 5197 posts
  • Gender:Male
Posted 25 July 2012 - 02:21 PM
The Graupner Ultramat 14 charger unit will charge lead acid batteries (Pb). Be sure to set it up correctly for the 6.0v Pb battery before connecting the charger to the battery. Refer to the manual for programming. The charge specifications should be printed on the battery or with the documentation that came with the battery. It is best to disconnect at least one of the terminals from the car when charging.
Making up a set of leads with alligator clips is no problem. Be cautious to never get the output polarity incorrect when connecting the battery or short the two output clips though as it's easy to get it wrong. A short or reverse polarity will damage the charger.
The Tamiya type molex plug is rated at 7.5Amp and the charger output is 5Amp, so the connector is well within the capability of the charger.
#14 Malakite
Malakite
    Member
  • Members
  • PipPipPip
  • 424 posts
  • Gender:Male
Posted 25 July 2012 - 09:57 PM
Hi Mark - well I charged on usual settings but lowered the ampage slightly and it appears to have charged the battery? I could not find out exactly what charge rate I needed so went for 1.0 amp (I usually have it 2.6Amps on a ni-cad 7.2v??
Reply to this topic
