Power drain
Started by bighair, Nov 05 2011 03:36 PM
11 replies to this topic
#1
Posted 05 November 2011 - 03:36 PM
I have a fighter buggy with Mad Bull wheels. it runs a bigger motor than standard and a Ripmax electronic speed servo. It used to run fine but now the batteries lose their charge almost instantly when I start it up. It seems there must be a power drain. Any ideas?
#7
Posted 05 November 2011 - 07:15 PM
Well, if you have a charger that indicates MAH, and has a discharge feature, you can see if your batteries are really up to it or not.
Then if you don't, go to a friend who has one.
If the batteries are functional, then most likely the problem would either be the motor condition, or binding somewhere in the drivetrain.
Being a mad bull, I doubt it would suddenly develop binding. If so, then it would be something like grass or a piece of string wrapping around the wheel hub, so just take the rear wheels off and check if something has wrapped around the axle near where the shaft comes out.
Then you want to take the motor out, pull the brushes out and have a look at them, take the endbell off and inspect the commutator surface.
If it's discolored/black or pitted, or the brushes are very short and discolored/purple, then that might be a source of a problem.
How old are your batteries though?
#9
Posted 06 November 2011 - 06:48 PM
Could it be the connector?, I had a worn out tamiya connector that did that. The wires and connector was too hot to touch.
#10
Posted 06 November 2011 - 06:56 PM
Bit of an update. Managed to get one of the packs to take a charge. 5 mins or so of running it ended up with battery pack hot, esc heat sink hot and wires between the two VERY hot! Does this suggest that the batt pack is dodgy?
Wires between ESC very hot, too? If not, then it's your ESC that has partly blown a transistor.
#12
Posted 07 November 2011 - 07:15 PM
Unfortunately, the gearing of the DT-01 chassis is not really suited to large diameter wheels like the Mad Bull's Lunchbox tires. The smallest pinion you can fit is 17 tooth, while other Tamiya models with Monster Truck wheels (like the Blackfoot, Lunchbox and Monster Beetle) uses 10 tooth pinions to make up the wheel diameter.I have a fighter buggy with Mad Bull wheels. it runs a bigger motor than standard and a Ripmax electronic speed servo. It used to run fine but now the batteries lose their charge almost instantly when I start it up. It seems there must be a power drain. Any ideas?
Fitting a powerful motor to a Mad Bull can result in motor overheating and thus quick battery drain, especially when running on grass. For brushed motors in a Mad Bull, I would not go faster than a Sport Tuned motor, or use a similar more effecient (and less heat producing) motor. Don't forget to attach a passive motor heat sink or an active motor cooling system. Maybe your motor itself has been damaged recently?
Reply to this topic
