Not allowed to open till fathers day
Bruiser 2012 (spy photo from Nuremberg Toy Fair 2012
Started by RA1028, Jan 31 2012 07:08 AM
1530 replies to this topic
#1327
Posted 05 June 2012 - 12:22 PM
Mine arrived yesterday, scored one with the toothbrush. Thanks Stella, can't believe the lengths they went to with the protective packing!
Yer you can't beat stella for great service & packaging . WOW!! Long way till fathers day
#1329
Posted 03 July 2012 - 03:17 PM
Man....i am bummed that there is no activity in this thread!
After all the years of waiting and wondering, seeems to have gone ppfffffft....
Mine is still in its box, but when I get it out and build I am going to start with body FIRST and then the rest.....not sure what colours but we will see.....I am more concerned that there have been no aftermarket parts made for this, I am sooo interested in something that will allow me to use 12mm hexes, and then rims with a negative offset to narrow the track a little....and then some nice, more scale tires...
I am also looking into a water cooling system for the motor....for no other reason than....I can. Little radiator, little water pump and a boat waterjacket.....
Where are the hopups, where are the bruisers?
#1330
Posted 03 July 2012 - 03:41 PM
We are holding out for the Blazer. A pick up got to be American with a V8 like Ford or Chevy, big and ugly, not like a pretty Toyota with a tiny 4 banger.
For looks you can put dual shocks per side at the rear fender flares, mud flaps etc. For hopups, you may want to consider those brushless motor and try fitting sponge tires to make it a low rider and tear up the track along with the gears????
#1331
Posted 03 July 2012 - 06:44 PM
I know what you are saying about the V8, I own a 2001 Chevy Silverado Stepside, 6" lift and 32" tires.....5.3L Vortec. Aint no replacement for displacement!
I am doubtful we will see the Blazer.....but thats just a hunch I got.....there is a simpler tooling for Tamiya to just bring out the mounty instead....
#1332
Posted 04 July 2012 - 07:42 AM
Hay we didn't think they would bring out the bruiser & look what happened
So i would say it's just a matter of time & it will be in a year or so ?.
Just to get the most out of the bruiser money
#1333
Posted 04 July 2012 - 03:35 PM
my re-re bruiser
#1335
Posted 05 July 2012 - 12:20 PM
Have faith Sirandy !
I'm enjoying the build of mine too much to finish !
Here's the finished body though:
http://www.tamiyaclu...114898&sid=7434
Just working on the transmission now, so photos of the finished project by next weekend
#1336
Posted 05 July 2012 - 04:45 PM
What wheels are you running?
rc channel, but they don't make a correct adapter to fit the bruiser
the rc channel bruiser adapter is 6 hole and the wheel is 5 hole
so I had to drill and tap the adapters to fit the wheels
#1337
Posted 05 July 2012 - 05:25 PM
Here's mine - no hopups as such, just a few extra details - headlights, sidelights, tail lights & cruise lights are turn off-and-onable from the TX, driver is a modified Sand Rover one, paint is Renault Monaco Blue metallic, sleeper cab & rock rails are VW Alpine white
#1338
Posted 06 July 2012 - 05:17 AM
Great work but has weaken my will to wait for the Blazer
Having looked at the photo above and knowing the original has the switch and clips in the same spot for the bed... I was thinking would is be nicer if the clips trench box was covered over by a lid, kind of like a lockable trunk lid within a trunk, in this case the flat bed? And that big witch be do away with all together and use a tiny switch from the receiver which could be located at the frame. In the end will have a nice normal bed like the real 1:1 instead of a box and a big switch at the middle of the bed.
#1339
Posted 16 July 2012 - 02:06 PM
the only reason they needed that switch hump was to accomodate the BEC switch available back in the day
if T was into totally revamping it for proper scale, they'd reaslistically drop the bed further down
which would need a modified radiobox... could be possible to relocate the 2 servos further aft
#1340
Posted 17 July 2012 - 12:32 PM
Surprised that nobody has commented on this... hop up parts for the Bruiser, including an official driver figure. Seems like they finally took the hint.
54412 Bruiser 4×4 Slipper Clutch
54414 Bruiser 4×4 4-Piece Chrome Wheels (2 Pcs.)
54415 Bruiser 4×4 D-Parts (Bumpers, Black)
54416 Bruiser 4×4 Driver Figure
#1341
Posted 17 July 2012 - 01:37 PM
They have , there is a thread about it .
#1343
Posted 18 July 2012 - 06:01 AM
Yes your right on there , But you know how things run hereAh, righto. Surely should have been in this part of the forum but hey-ho.
#1344
Posted 19 July 2012 - 03:19 AM
hey daddy-o, which country's will you be celebrating?
http://en.wikipedia.org/wiki/Father's_Day
#1345
Posted 20 July 2012 - 06:05 AM
More Bruiser goodies
New Bruiser light set #02126 basically what joe Anderson has at his Bruiser build but you can buy it as a set from Tamiya
Set Contents ▼ 53909: Tamiya LED Light Unit (TLU-01) ▼ 53937: Tamiya LED Light Control Unit (TLU-02) ▼ 53912: Tamiya LED Light (Φ3 Orange) ▼ 54009: Tamiya LED Light (Φ3 Red) ▼ 54008: Tamiya LED Light (Φ3 White) ▼ servo extension cord (20cm) x4
And Really awesome new Sanwa (Airtronics) SG-6G 4WD radio it's a 6 channel 2.4ghz designed for Tamiya 3spd, semi trucks and tanks but I don't get it didn't they learn from Futaba's newer 4GWD radio or from Tamiya ?? It has digital trims and will not work with MFU's !
http://sanwa-denshi..../sd-6g_4wd.html
Anyway Still cool to get it for my Bruiser sigh looks like I need to narrow down my collections even more to afford all these thing for the Bruiser.
#1346
Posted 20 July 2012 - 08:35 AM
What's the price on the LED kit ? & what a great idea . As this does make it easier to buy .
#1349
Posted 21 July 2012 - 04:36 PM
These new aftermaket Tamiya Hop Ups are too late, I've comleted my build:
http://www.tamiyaclu...=115311&id=7434
Luckily I have another to build
That new Sanwa radio is just the ticket I've been looking for too !
#1350
Posted 24 July 2012 - 10:11 PM
Got the following prices from time tunnel models in UK, will be special order and come in after Japan release.
54412 Bruiser 4×4 Slipper Clutch @ 47.99
54414 Bruiser 4×4 4-Piece Chrome Wheels (2 Pcs.) - @ 51.99
54415 Bruiser 4×4 D-Parts (Bumpers, Black) - @ 38.99
54416 Bruiser 4×4 Driver Figure - @ 16.50
I think I will wait to see what the wheels look like in pics but for sure get slipper and driver!
Lee.
Latest Bruiser re-re = awesome build! tank or 3spd truck next...................
Lee.
Reply to this topic
