Hinged Tool Box (1 pc)
Removable Spare Axles (2 pcs)
This is the Scale Accessory Assortment #4 for Scale Crawlers.
The Pro-Line Racing Off Roaders Truck Tool Box replicates a realistic truck tool box which you would find on a real 1:1 off Road Truck.
The box contains two very highly detailed Spare axles that are removable. Basic dimensions of the box are 6 Œ wide x 1 5/8 Wide at the lid and 1 deep at the center well.
The lid is hinged for easy opening and closing.
Pro-Lines truck tool box gives your scale truck / rig new - unparalleled realism never seen before in any other scale accessories!
6073-00 | Scale Accessory Assortment #5 - Price: $22.95
Tool Box Tray (1 pc)
Portable Welder (1 pc)
Cordless Impact Gun (1 pc)
Sledge Hammer (1 pc)
This is the Scale Accessory Assortment #5 for Scale Crawlers.
What is any extreme 4X4 support rig without the proper tools? Assortment #5 gives you a very realistic portable welder, as well as a 24V Impact gun with Socket Detail.
The set also includes a Sledge Hammer and a Tool Tray that works with the #6072-00 Tool Box!
Pro-Lines Scale Accessories Assortment #5 Puts the right tools for your Scale 4X4 easily at hand.
6074-00 | Scale Accessory Assortment #6 - Price: $22.95
Dry Cell Batteries (2 pcs)
Battery Mounting Hardware (1 pc)
300K Power Inverter (1 pc)
This is the Scale Accessory Assortment #6 for Scale Crawlers.
Extreme 4x4s call for Extreme Power and our Assortment #6 delivers.
You get two simulated Dry Cell batteries with hardware that allows you to configure either a dual or single battery system.
Backing that up, is a highly detailed replica of a 3000K Power inverter.
With Pro-Lines Scale Accessories Assortment #6 your Scale rig will never be in short supply of electrical power.
6075-00 | Scale Accessory Assortment #7 - Price: $22.95
Water Jug (1 pc)
Plastic Fuel Can (1 pc)
Fire Extinguisher (1 pc)
Trench Shovel (1 pc)
This is the Scale Accessory Assortment #7 for Scale Crawlers.
What would an action packed day of scale 4X4 activity be without the proper support equipment?
Assortment #7 gives your rig the look that its ready to take on the longest of Scale 4x4 excursions with the highly detailed Water and fuel cans, as well as the Trench shovel.
The pack also features a replica Fire extinguisher with an all-purpose mounting bracket, which can be found on all serious Full-Scale Rock Crawling rigs to put out those nasty engine fires.
With Pro-Lines Scale Accessories Assortment #7 your Scale rig will never be lacking the essentials that any scale 4X4 excursion requires.
