Here's a better picture, considering that my motor has the colored wrapping on the stubs:
What I'd like to do is remove those stubs so that I can solder in wires coming in from the other direction.
But I'm not sure if those stubs are themselves soldered in. It doesn't look like solder. They seem to be bolted in, though I might be wrong.
Would it be possible to simply open up the motor and flip that plate around? So that those stubs point *in* rather than away?
Presuming I'm supposed to solder in wires onto those stubs, those stubs+solder+wires sticking out will make the EZrun in a Baldre practically useless considering I won't be able to place the body over it.
In fact, if I'm honest, I already have the wires soldered in and so I have experience of the problem directly. I will have to melt those wires off and try to re-solder them in coming in from the other direction. Maybe I'll need to use flux.
Trying to do a good soldering job and not having the proper equipment, or a third or fourth arm, made soldering the single most difficult and stressful thing I've dealt with since getting back into RC. Very difficult for me.
Would appreciate the help, as usual.
