Mark all as read
More than 1 RX per TX
7 replies to this topic
#1 Yello
Yello
    Member
  • Members
  • PipPipPip
  • 300 posts
Posted 08 March 2012 - 12:58 AM
How do you...
Let's say...
Suppose you have more than 1 receiver that is bound to your transmitter. How does one make it so that only 1 receiver is activated when you turn on your transmitter? Or is this not even an option?
I have the Flysky. I wasn't aware that the model memories weren't exclusive to individual RXs.
My DB01 build and information thread
Why can't Nestles make a Re-Re of this? Best candy bar ever!
#2 Champ85
Champ85
    Member
  • Members
  • PipPipPip
  • 474 posts
  • Gender:Male
Posted 08 March 2012 - 03:52 AM
RX's are bound to the specific TX frequency (or specific TX bind code in the case of 2.4GHz), not to a specific model selected in the TX. The RX listens to the TX and has no idea what a "model memory" is and doesn't care which model memory you've selected. You still have to remember to select the correct model in the TX that goes with the model you are running. Forgetting to do that will mean you could run vehicle #1 with TX model #2's memory settings, for example, so the trim settings could be way off.
There is no way to only activate 1 RX at a time. If both vehicles are powered on and you turn on your TX, both vehicles will move accordingly.
#3 WillyChang
WillyChang
    Advanced Member
  • Members
  • PipPipPipPipPip
  • 8765 posts
Posted 08 March 2012 - 04:28 AM
the newer Spektrums remember what RX is bound to which memory slot,
so you can have several RXes all poweredup in different models and only the
selected model will work; all others stay on failsafe position
or i think the RX actually remembers the TX, as you can bind more than 1 RX
to the same slot & all work simultaneously
#4 bromvw
bromvw
    Advanced Member
  • Members
  • PipPipPipPipPip
  • 2686 posts
  • Gender:Male
Posted 08 March 2012 - 06:13 AM
A lot of large scale rc boat builders use this multi RX function so they can switch and control guns , lights , smoke effects ect ect . With a 10 TX memory on 4 channel that means they can operate up to 40 funtions , and many times that with Y connectors.
#5 WillyChang
WillyChang
    Advanced Member
  • Members
  • PipPipPipPipPip
  • 8765 posts
Posted 08 March 2012 - 07:09 AM
i thought they just had a copilot with a 2nd TX... :D
#6 Champ85
Champ85
    Member
  • Members
  • PipPipPip
  • 474 posts
  • Gender:Male
Posted 08 March 2012 - 02:37 PM
So the newer TX's transmit the model # along with the bind information to the RX when binding? I didn't know that. Learn something new every day.
Forget what I said in my previous post, then. It only applies to ancient AM, FM, PCM and early 2.4GHz systems.
I still live in the dark ages.
#7 stu22
stu22
    Member
  • Members
  • PipPipPip
  • 505 posts
  • Gender:Male
Posted 08 March 2012 - 04:58 PM
How do you...
Let's say...
I've always used the simple solution of only having one model on at a time B) BTW, you should get into the habit of turning on the transmitter first and then the receiver.
#8 markbt73
markbt73
    Member
  • Members
  • PipPipPip
  • 1509 posts
  • Gender:Male
Posted 10 March 2012 - 04:03 AM
I've always wanted to try that...
Reply to this topic
