Mark all as read
D . U .K .W
158 replies to this topic
#26 Percymon
Percymon
    Advanced Member
  • Members
  • PipPipPipPipPip
  • 4179 posts
  • Gender:Male
Posted 28 March 2012 - 10:28 AM
The R1 gearbox and motor mount allows 9T to 19T pinions which gives gear ratios from 53.65 to 25.42. R1 portal axles are geared 2.76.
Visit My Showroom
#27 bromvw
bromvw
    Advanced Member
  • Members
  • PipPipPipPipPip
  • 2663 posts
  • Gender:Male
Posted 28 March 2012 - 02:05 PM
I've managed to find some good ref photo's that will be a big help with the build . The actual Actionman GPA seems fairly true to the original and even has a prop and rudder so hopefully making it funtional won'nt be that hard :unsure: . I can only hope so B) . Most of the stuff i need seems to be available from either after market crawler sites ie RC4WD or scale boat sellers . Hopefully i'll be able to build a real one off .http://www.american-.../43fordGPA.html
#28 bromvw
bromvw
    Advanced Member
  • Members
  • PipPipPipPipPip
  • 2663 posts
  • Gender:Male
Posted 29 March 2012 - 03:28 PM
Postman Pat has left a card through the door while i was sleeping ( night shifts this week) so l'll have the hull/body in the morning when i pick it up from the sorting office on my way home ;) . Then i can make a start and really see whats involved .
#29 bromvw
bromvw
    Advanced Member
  • Members
  • PipPipPipPipPip
  • 2663 posts
  • Gender:Male
Posted 30 March 2012 - 07:30 AM
Well its now here . It actually looks as if this is going to be easier than i'd thought . I'll most likely cut the top 'deck' off to allow access . Then it will be a case of building wheel arches ect ect . My past experiance in building scale boats is going to come in handy ;) . One or two bits missing ie steering wheel and a passanger seat but thats easy to sort out . Not sure how far i'll go in detailing but i'd like it to be as scale looking as possiable .
EDIT 'deck' section cut off and i have a nice 'hull' to work with . I now think that this will be a lot easier then i thought . Even the position of the existing prop is good in terms of mounting a functioning drive .
#30 bromvw
bromvw
    Advanced Member
  • Members
  • PipPipPipPipPip
  • 2663 posts
  • Gender:Male
Posted 31 March 2012 - 07:32 AM
can anyone recomend a suitable glue for use on the soft plastics as used on actionman vehicle's ???Is there anything other than loctite all plastics superglue that i can use as this is rather expensive ?
#31 bromvw
bromvw
    Advanced Member
  • Members
  • PipPipPipPipPip
  • 2663 posts
  • Gender:Male
Posted 31 March 2012 - 08:58 PM
I have a 380 in a scale boat that is ideal size wise ie correct prop and shaft length , question is could i use this on a twin brushed esc without risk of causing damage to the unit ?no idea how many turns it is .
#32 bromvw
bromvw
    Advanced Member
  • Members
  • PipPipPipPipPip
  • 2663 posts
  • Gender:Male
Posted 02 April 2012 - 07:50 PM
I'am still at the drawing board and design stage . Top deck has being removed and i'am now working on the wheel arches ect . I'll start a build thread when i'am a little further along . I'll be adding bulkheads to pervent any water swamping the electrics when entering the ponds/rivers and adding some foam just in case it ever decides to become a submarine :D
#33 bromvw
bromvw
    Advanced Member
  • Members
  • PipPipPipPipPip
  • 2663 posts
  • Gender:Male
Posted 03 April 2012 - 07:15 PM
i've being giving this a lot of thought and i think i'am going to do all the internal mods ie wheel arches , bulkheads ect in a composite of 3mm marine ply and fiber glass epoxy . The plastic molding is a PITA to get anything to bond to so i'll give this a go .
#34 bromvw
bromvw
    Advanced Member
  • Members
  • PipPipPipPipPip
  • 2663 posts
  • Gender:Male
Posted 05 April 2012 - 07:04 PM
I've done a few test pieces and i'am beinging to think that to correct way to go about this is to use the existing 'hull' as a mold . Theres no reason i can'nt have a fiberglass lower section and use the existing deck .
#35 bromvw
bromvw
    Advanced Member
  • Members
  • PipPipPipPipPip
  • 2663 posts
  • Gender:Male
Posted 11 April 2012 - 10:50 AM
This is still very much a work in progress . Obviously i'am having to design and source everything and this is taking time but i'll not give up on it . I have 90% of the running gear figured out so its more a case of fabrication now . Once done i'll be fitting Dragon USMC 1/6 action figures and perhaps a 50cal browning . IMO to get away from its actionman beginings it needs loads of detail to pull it together .
Its a long term project but i'am keeping a good photo record and have a file of all the bits i'am using so i can do a detailed build thread once its further along .
#36 30YrsL8r
30YrsL8r
    Member
  • Members
  • PipPipPip
  • 419 posts
Posted 11 April 2012 - 11:01 AM
There's no shame in it... I think you should install an AM as the driver :lol:
Showroom: here
Build Thread: here
#37 bromvw
bromvw
    Advanced Member
  • Members
  • PipPipPipPipPip
  • 2663 posts
  • Gender:Male
Posted 11 April 2012 - 11:04 AM
i've thought of that but the Dragon action figures are far better detailed . Hopefully i can fit a small servo and having the steering wheel turning through his hands .
#38 bromvw
bromvw
    Advanced Member
  • Members
  • PipPipPipPipPip
  • 2663 posts
  • Gender:Male
Posted 11 April 2012 - 11:05 AM
EDIT while looking for scale parts i've come across this e bay store . OMG if i buy some bits from here it will save me hour and hours of work . ;)
http://stores.ebay.c...sid=p4340.l2563
#39 bromvw
bromvw
    Advanced Member
  • Members
  • PipPipPipPipPip
  • 2663 posts
  • Gender:Male
Posted 11 April 2012 - 01:26 PM
http://stores.ebay.c...sid=p4340.l2563 . Think i've found a great source of jeep parts that will save me many many hours of work . As a example - all i did was enter jeep in the product search .
#40 bromvw
bromvw
    Advanced Member
  • Members
  • PipPipPipPipPip
  • 2663 posts
  • Gender:Male
Posted 11 April 2012 - 01:35 PM
and another item .
#41 30YrsL8r
30YrsL8r
    Member
  • Members
  • PipPipPip
  • 419 posts
Posted 11 April 2012 - 01:44 PM
And you're going to drive all this cool stuff into a pond?
Showroom: here
Build Thread: here
#42 bromvw
bromvw
    Advanced Member
  • Members
  • PipPipPipPipPip
  • 2663 posts
  • Gender:Male
Posted 11 April 2012 - 01:45 PM
Yes :lol: . the more detail the better
#43 bromvw
bromvw
    Advanced Member
  • Members
  • PipPipPipPipPip
  • 2663 posts
  • Gender:Male
Posted 11 April 2012 - 02:27 PM
windscreen is very well detailed. I was getting down hearted over this project but now i can see some light at the end of the tunnel . Ok so it will cost me to finish it but a one off is never as cheap as a bespoke item .
#44 mr crispy
mr crispy
    Member
  • Members
  • PipPipPip
  • 927 posts
  • Gender:Male
Posted 11 April 2012 - 06:17 PM
Check out www.armorpax.com for more 1/6 detail bits. I use to collect 1/6 figures, Dragon are a good company and their line called Dragon in Dreams will give you a lot of great details kit to fill out the jeep.
Got any pics yet?
A day without R/C is like a day without sunshine!
My R/C Cars
#45 bromvw
bromvw
    Advanced Member
  • Members
  • PipPipPipPipPip
  • 2663 posts
  • Gender:Male
Posted 11 April 2012 - 06:27 PM
Some good stuff on that armorpax site but as their white metal i dont think i use them .The 1/4ton 4x4 truck (jeep) from Dragon is a good scorce of parts as its basically a jeep and the jeep shared many parts with the Ford GPA seep . I have to keep the all up weight in mind . No photos as yet because all i have to show is a 'hull' that is very rough and cut about . As soon as i get somewhere i'll post .One design choice i have made is to not have a chassis and to use the hull as the chassis instead . Its very strong and i can simply bolt through it .
#46 bromvw
bromvw
    Advanced Member
  • Members
  • PipPipPipPipPip
  • 2663 posts
  • Gender:Male
Posted 12 April 2012 - 05:39 PM
I hope to start making some real progress on this over the next week or so . I have a lot of parts on order but while they arrive i'am going to start laying up all the internal hull mods and bulkheads in 3 mm marine ply and fiberglass . If anyone happens to know the distance between the leaf spring mounts on rc4wd T Rex 60 Axels that would be a huge help so i can make the wheel arches .I belive their interchangable with the Bruiser ? so if you can measure for me ?
#47 Skottoman
Skottoman
    Member
  • Members
  • PipPipPip
  • 1494 posts
  • Gender:Male
Posted 12 April 2012 - 10:44 PM
Center of leafspring mount to leafspring mount on my T-Rex 60 axle is 82mm.
Cheers,
Skottoman
#48 bromvw
bromvw
    Advanced Member
  • Members
  • PipPipPipPipPip
  • 2663 posts
  • Gender:Male
Posted 13 April 2012 - 04:44 AM
Cheers,
Skottoman
Many Thanks Skotto
Cheers,
Arron
#49 bromvw
bromvw
    Advanced Member
  • Members
  • PipPipPipPipPip
  • 2663 posts
  • Gender:Male
Posted 13 April 2012 - 08:50 PM
i've come up with a very simple way to switch from the wheels drive motor to the prop drive when entering the water . I'am simply going to wire a float valve switch and a relay to the prop drive motor supply so it can only operate once i enter the water and cut the supply to the wheels motor . that way i can use a 2 Channel set . Simple but effective .
#50 30YrsL8r
30YrsL8r
    Member
  • Members
  • PipPipPip
  • 419 posts
Posted 13 April 2012 - 11:27 PM
What about leaving the water? Aren't you relying on the prop to push you far enough up the bank to drop the float and start the wheels?
Showroom: here
Build Thread: here
Reply to this topic
