Upgrades for Midnight pumpkin
Started by asitha09, Mar 26 2012 07:43 AM
7 replies to this topic
#1
Posted 26 March 2012 - 07:43 AM
Hi guys,
Could you suggest the type of upgrades that i could use for my midnight pumpkin. Already got a GT tuned motor. any suggestions about the shocks and the wheels+tires.
And maybe due to the motor (not sure) the front left tire tends to come off from the wheel. Any ideas for this?
Thx,
Thx,
#2
Posted 26 March 2012 - 09:20 AM
If you are running an uprated motor then you should superglue/CA glue the tyres to the rims. I actually use UHU/Evostick impact adhesive since its easier to remove the tyres when they need replacing. Alternatively you ould try putting a flat rubber elastic band in the bottom of the tyre beads on the rim and refuitting the tyres - this might give just enough grip for the tyre not to slip and come loose.
Other upgrades are as per lunchbox (fifth shock absorber, alloy body mounts) - try a search for lunchbox mods.
History for last 32 months.. bought too many, not sold enough - current stable 41.2 EEK
Visit My Showroom
#3
Posted 26 March 2012 - 03:28 PM
Thx, Percymon
For the wheels, rather than gluing them, cant i use beadlock wheels? Do they have beadlock wheels for the pumpkin? I couldn't understand what the following meant. can you please explina on how to do this "Alternatively you ould try putting a flat rubber elastic band in the bottom of the tyre beads on the rim and refuitting the tires"
And any idea where i could find the following? ((fifth shock absorber, alloy body mounts)) I tried searching on ebay and google, couldnt find anything
Thx for your help
#4
Posted 26 March 2012 - 04:01 PM
Alloy body mounts.. http://www.modelbuild.co.uk/
For the rubber band idea - remove the wheel from the truck, remove the tyre and put a flat rubber elastic band around the rim, in the recess that the tyre fits into - then refit the tyre so the tyre bead sits on top of the rubber band - the extra grip of rubber:rubber vs rubber tyre:plastic rim should be sufficient to hold the tyre in place.
you could fit all sorts of wheels - crawler style 1.9" beadlocks and suitable tyres or short course wheels - all depends what look you want. Persoanlly i think the LB/MP wheels are perfect.
Fifth shock - again just search for lunchbox fifth or lunchbox shock
Visit My Showroom
#5
Posted 26 March 2012 - 04:12 PM
Visit My Showroom
#6
Posted 26 March 2012 - 08:11 PM
#8
Posted 26 March 2012 - 10:51 PM
Lunchbox/Pumpkin is ~210mm wheelbase, so regular 1:10 bodies or even most M-Chassis (M & L variants) bodies look huge on them. My plan was to use a M04L Beetle on mine as I wanted the van body for the M04 chassis, but the Beetle body dwarfed it, so I used a 1:14 scale toy truck body on my Lunchbox instead.i really fancy a Lunchbox with a Mk1 Dodge Viper shell, should look into it soon
Kamtec's V12 bodies fit the Lunchbox ok. Polycarb body lasts a bit longer with the inevitable rollovers too.
Reply to this topic
