OK. I still can't tell if any of you others have tried these gear diffs out in a DB-01 yet. I was out trying to tune my DB01 a bit yesterday and both ball diffs started slipping (just rebuilt). I tightened them up, still slipping. Tightented them to where I think the nut-sert started to slip a little and the diff is still slipping. I used super glue on my diff rings this time (vs. shoe goo) thinking they would be bullet proof this time and I wouldn't have to worry about my diffs for a while, I was wrong. I am not sure why they are slipping so bad, I am just guessing the diff rings. I will tear it apart and see. In the meanwhile and out of frustration, I checked rcmart and they had the hop-up gear diffs on sale for $22 USD so I bought one for the front and rear. I will let you guys know how they work out. I do plan to stick with the thicker oil for now for the sake of them not leaking, I just want to drive the @#$^^ thing. LOL
Just a shot in the dark, but did you see the "twist" in the ball diff build instruction? It is claimed that those who install the diff screw etc in the wrong direction would have problems with the diff loosening on its own.
I'm genuinely (morbidly?) curious as to why so many people have such a hard time with their DB01 diffs. I must have really lucked out. I've put my DB01 through countless bash sessions by now and after the initial break-in, my diffs seem to have settled into a nice little stasis. *knocks on wood*
- Also when you tighten the diff, do you use Tamiya's guideline or do you tighten down ALL the way and then back out?
Anyway, Stellamodels has the gear diffs for 20 USD and the next time I pick up stuff from them, I'll probably pick a gear diff up too to replace the rear ball diff, and that just for the heck of it and as a backup in case I ever need it.
Please tell us how you like the gear differentials.
