like to introduce you to my new project. Bought the PZ IVJ 9 months ago and recently started on it.
I will make a model of one of the 6/. reg of the 1. SS LSAH during the Ardennes offensiv in december 1944.
Here you get the idea how it will look
First I worked on the turret doors to make them functional
added "armor to the doors
made the hinges to close the doors
next I worked on the Nahverteidigungswaffe (close combat weapon (CCW)) and the filter. The first is to high and oriented the wrong way, the second is to high (due to its function for the infr red led). Bad points here for Mr Tamiya
the Late version had the filter also closer to the close combat weapon, so I had to cut it out and move it
Original place and height
Cut out the CCW
placed it in the correct angle en at at the correct height, removed the filter
after a lot of sanding this is the correct situation for the Late version
still need to sand it down a little
Next work the cupola of the commander, it requires a revolving hatch instead of the clamshell version
