Mark all as read
Hornet re-re body (best way to fix it?)
8 replies to this topic
#1 mongoose1983
mongoose1983
    Member
  • Members
  • PipPipPip
  • 1970 posts
  • Gender:Male
Posted 01 June 2012 - 06:20 AM
I was thinking in renewing my Hornet's body this Winter (or Summer for you guys in the rich side of the world) and come up with a problem. Of course, it is nothing new with whatever Tamiya's been doing as they rerelease these old cars. The new body is identical to the original, except for one thing: the window/hole for the MSC's resistor.
I thought maybe some fellow TCer have sorted out this particular problem in the past, and so I decided to ask you guys what is the best method to correct the new body and make the hole without ruining it? Anybody in the know?
You all have a good Friday! :)
RR+SS+SC+Brat+FAV+Grasshopper+Hornet+Bruiser+BigWig+BF+MB+CB
The BIGWIG owners & enthusiasts S.I.G.
#2 lindorf
lindorf
    Member
  • Members
  • PipPipPip
  • 151 posts
  • Gender:Male
Posted 01 June 2012 - 01:52 PM
I cut out the holes in the body to match the orig body i was replacing .. i used some paper make the templates of where the holes was needed cut em out .. placed on the body.. marked.. and cut.
#3 mongoose1983
mongoose1983
    Member
  • Members
  • PipPipPip
  • 1970 posts
  • Gender:Male
Posted 01 June 2012 - 09:43 PM
Yes, you can always mark and cut, but the roundy corners you can not cut them with scissors or a knife. That's where my question aimed mainly.
#4 ralphee
ralphee
    Member
  • Members
  • PipPipPip
  • 187 posts
  • Gender:Male
Posted 03 June 2012 - 10:01 AM
Use a bodyreamer in each corner, punch your desired hole, then cut out up to the holes with an Exacto?
lee
#5 taliesin
taliesin
    Advanced Member
  • Members
  • PipPipPipPipPip
  • 2602 posts
  • Gender:Male
Posted 03 June 2012 - 02:44 PM
lee
Yup, just like that. :)
Friends don't let friends drive with Tamiya pinions!
#6 mongoose1983
mongoose1983
    Member
  • Members
  • PipPipPip
  • 1970 posts
  • Gender:Male
Posted 03 June 2012 - 07:24 PM
lee
Yes, sounds like a good idea. I don't have a bodyreamer here, but was thinking on some dremel thing? Anybody used a dremel to get the corners done?
Thanks raplhee and taliesin.
You have a great week! :)
#7 markbt73
markbt73
    Member
  • Members
  • PipPipPip
  • 1533 posts
  • Gender:Male
Posted 03 June 2012 - 08:53 PM
If you don't have a reamer, you can actually ream holes with the tip of an X-Acto knife. I do it all the time. It works great for holes up to 2 or 3 mm; anything bigger than that you should use a drill bit so the hole doesn't get jagged.
#8 mongoose1983
mongoose1983
    Member
  • Members
  • PipPipPip
  • 1970 posts
  • Gender:Male
Posted 03 June 2012 - 09:13 PM
Thanks, Mark. Seems to me the solution would be making four corner-holes with a regular drill (using some piece of wood as backing) and then just use the cutter, that's it. I only hope I won't destroy the shell ;)
#9 HunterZero
HunterZero
    Advanced Member
  • Members
  • PipPipPipPipPip
  • 2735 posts
Posted 04 June 2012 - 01:18 AM
Use the reamer hand tool. Don't use the dremel except on a very low speed, the heat from the friction of a fast dremel bit can destroy the polycarbonate, or cause stress that may cause the body to crack later. Drill will be OK, just use a slow speed.
I actually find that the back of an exacto blade works very well for carving/scraping away fine amounts of polycarbonate when tidying up the cut line.
- James
Reply to this topic
