Mark all as read
car not centering like servo not returning to center
10 replies to this topic
#1 atf300
atf300
    Member
  • Members
  • PipPipPip
  • 563 posts
  • Gender:Male
Posted 07 July 2012 - 06:50 PM
This is happening on my girlfriends tt01e. the car is centered until the first turn , if that is right turn then it drags a bit to the right after centering itself or vice versa if its a left turn.
is it the servo failing ?
#2 wolfdogstinkus
wolfdogstinkus
    Member
  • Members
  • PipPipPip
  • 1684 posts
  • Gender:Male
Posted 07 July 2012 - 08:40 PM
I have a servo that does this as well, I am going to replace it but I would like to hear what others say about this.
#3 TA-Mark
TA-Mark
    Advanced Member
  • Members
  • PipPipPipPipPip
  • 5103 posts
  • Gender:Male
Posted 07 July 2012 - 08:45 PM
Check for something tight in the steering assembly (this is best done with the servo removed). And as mentioned, check the servo horn for wear at the spring.
#4 wolfdogstinkus
wolfdogstinkus
    Member
  • Members
  • PipPipPip
  • 1684 posts
  • Gender:Male
Posted 07 July 2012 - 09:01 PM
Thanks TA-Mark, I have tried this servo in two cars and it does the same thing, it is very old so I was going to replace it anyway, but it may be something tight inside the servo, or it's got moisture or something in there?.
#5 atf300
atf300
    Member
  • Members
  • PipPipPip
  • 563 posts
  • Gender:Male
Posted 07 July 2012 - 10:33 PM
Ta-Mark was right , there was a screw too tight . i didn't build it , the missus did , but its odd that this just happened now since it was too tight since the build months ago. i also noticed that the front tires aren't totally parallel. guess i need to add the turnbuckle set to the shopping list . at least she is happy of every hop up she gets :)
#6 gozone
gozone
    Member
  • Members
  • PipPipPip
  • 1313 posts
  • Gender:Male
Posted 09 July 2012 - 04:52 PM
Kit-supplied servo-savers are also often a reason for cars not centering correct after a turn, especially with "over-tightened" components in the steerig-setup.. Tamiya does a pretty good High Torque servo saver, which can replace most stock savers from their kits, and is a good hop-up also. :)
GO FOR IT!!!
#7 wolfdogstinkus
wolfdogstinkus
    Member
  • Members
  • PipPipPip
  • 1684 posts
  • Gender:Male
Posted 30 July 2012 - 08:10 PM
My transmitter stick is not centering, thats the reason for my car wandering.
#8 atf300
atf300
    Member
  • Members
  • PipPipPip
  • 563 posts
  • Gender:Male
Posted 31 July 2012 - 08:44 PM
today i found a weirded problem
on the blitzer beetle with an acoms as-16 and kimbrough servo saver . car has no dt02 turnbuckle addon yet .
i center the car . its mostly right 05 trimmed , then after a while it goes back to center so i need to trim it to center , then again after a while it goes back to the right 05 trim .
the car also has the bumpsteer mod done.
#9 GregM
GregM
    Member
  • Members
  • PipPipPip
  • 1002 posts
  • Gender:Male
Posted 03 August 2012 - 09:01 AM
1. Do your speed controllers (TEU101/104BK don't) or receivers (most 2.4G receivers don't) feature BEC? If not, this might give your servos more power than they are designed for. This may lead to strange servo behaviour.
2. Have you set up the steering endpoints trim or steering dualrate trim properly? If not, this may lead to hitting steering components hitting arms, C-hubs or other chassis components.
Posted Image
#10 atf300
atf300
    Member
  • Members
  • PipPipPip
  • 563 posts
  • Gender:Male
Posted 03 August 2012 - 10:56 AM
i have the bec covered . i think it might be the servo , but cant try another one atm since the servo saver with an universal mount is still on the way
#11 Percymon
Percymon
    Advanced Member
  • Members
  • PipPipPipPipPip
  • 4180 posts
  • Gender:Male
Posted 03 August 2012 - 01:01 PM
The Acoms AS-16 is a budget servo but even so it should still cope with the larger Blittzer wheels given how light the front of that model is. It sounds like the servo is a bit tired or the internal gears are partly worn - its easy to do this if you land hard on one wheel from a jump or smack the wheel into an obstacle.
Visit My Showroom
Reply to this topic
