shenlonco
Member Since 18 Jul 2005
Online Last Active Today, 12:24 AM
#495498 3Racing oil shocks V2 for DT02 chassis ?
Posted by shenlonco on 15 May 2013 - 04:41 PM
I DID IT!!!
I slightly had to bend the stock fighter springs just a hair at the bottom so it fits tighter on the 3 Racing shock bottom stay and it worked perfectly!!! on the rear because the springs are short and I still wanted to be able to adjust them with the screw down adjuster I used a Tamiya shock clamp clip the kind that a screw goes through to hold your adjusted height in place and it works perfect now. :)
#495169 So, What Have You Done Today?
Posted by shenlonco on 12 May 2013 - 02:06 AM
:D Finished up my fighter GR violet racer.
#494159 TA-Mark's Grasshopper/Hornet Chassis Build Thread
Posted by shenlonco on 01 May 2013 - 10:34 PM
Hmm, what this extra hole at the top for I wonder? The FX10 C Hub only has one hole at the top for the Kingpin but Mark's CAD diagram has an extra hole!?!?!?
Posted Image
Am I warm?
That looks like a screw will go into it to not let the pin come out and hold it down.
#493663 Custom colored radio wheel grips one of a kind
Posted by shenlonco on 27 April 2013 - 01:45 PM
The ones in the foil picture look nice dark red.  The photo of them on a Traxxas transmitter looks pinkish.  But yeah, this monitor is not real good for colours, ASUS VW192T.  It was free.  I usually buy Samsung when I buy one (they're on the other Gaming and the Media PCs).
I got a thing for yellow :P
Hi Mark that grip on the traxxas radio is not a black cherries it was a day glow pink smoke grip.  I have some solid dayglow yellow with black splashed in them that I will post up some time in the near future for you.
#493158 Ok Why is RC so addictive ?
Posted by shenlonco on 23 April 2013 - 03:07 AM
I for one have been non stop in the hobby since I was 12. I love cars, I love building, I love speed, and I love tinkering. I'm a creative type, so I get to express that through my building, painting, driving, shooting video, editing video, and racing ( I'm competitive lol).  I can't imagine a more multi faceted hobby than this one. This hobby has been the one longest constant in my life without my ever losing interest. I thank it for allowing me to become excited about subjects like math, physics, and engineering. Long live this amazing hobby! Probably saved me from a life of crime or drink and drugs lol.
:D What he said!
#490969 OK so here's the deal (tire Wish)
Posted by shenlonco on 06 April 2013 - 02:21 AM
beefmuffin sent me some QD tires :)
I don't know what they are like but i will have to see when i get them.
#490930 So, What Have You Done Today?
Posted by shenlonco on 05 April 2013 - 07:28 PM
:( Well I smacked my lunch box into a wall and the stock servo saver made my servos spline crack right off!
So i got a new servo and a kimbro servo saver and put it in pluse i put the rod ends out further than stock on the servo saver so the rods are more in a straight line....Now she's all good and ready to go again!!!
Posted Image
Posted Image
HAPPY LUNCH BOX!!
Posted Image
#488880 SNOW JUMPEN PUMPKIN!
Posted by shenlonco on 22 March 2013 - 07:50 PM
Enjoy watch in HD full screen!
#487764 TL-01 Wild Willy
Posted by shenlonco on 14 March 2013 - 10:25 PM
He was right about the Super Glue and soda, that's for sure! I just wasted 2 hours of my life fitting, sticking, scraping, washing, reinforcing and rewashing the two halves only for them to crack apart when I applied a little torsion. Not that I doubted Bill, just because I had the Super Glue to hand.
Thanks for all the input, folks. Do you have the brand of the glue you have had some luck with, pastimesteve? Did you mean that you left the JB Weld on AND used epoxy, or failed with the JB Weld and used epoxy instead?
How are your cut-and-shuts holding up, mr crispy? Have they had much of a beating?
Well I am sorry to say this but you muffed up all your work as now the ABS solvents will not work anymore because the parts are now coated in CA glue ... these solvents melt  and fuse the plastic together and it needs to be bare raw plastic to bond the CA will act as a shield not letting it melt the plastic anymore.
best bet now is probably another type of epoxy glue to first glue the chassis together...
and then  your best bet will be to make little plates and bolt the chassis together this will be the strongest method... I would glue the chassis together and make small aluminium plates with 4 screws and nuts on each and then glue tham down and bolt them across the cut to section of chassis to hold the sections together this way.
#487734 TL-01 Wild Willy
Posted by shenlonco on 14 March 2013 - 07:31 PM
Hi you need to try some  liquid solvint for mending plastics together.
This stuff for ABS this will be much stronger than that plastruct model type
http://www.ebay.com/...cement&_sacat=0
and then do what i said with goop glue a thick bead inside or a plastic epoxy
#486971 SAND SCORCHER VIDEO!
Posted by shenlonco on 08 March 2013 - 02:25 PM
:)  Enjoy!
Watch in HD full screen!
#485675 Lesson Learned about Lipos
Posted by shenlonco on 25 February 2013 - 01:52 PM
Back to the storage issue. Tower sells a voltage checker with a buzzer for low volt at 11 dollars each. It seems no matter what you do the voltage will drop at some rate while in storage. I didn't find any amp draw specs on these things but would it be worth it to just leave them attached so you'd at least know you were getting into a problem area?
:o  NO NEVER DO THIS VERY BAD IDEA IT'S LIKE LEAVING A LIPO PLUGGED IN A ESC IT WILL DRAIN AND IF YOU MISS THE BUZZER SOUND .....  NOT GOOD!
#485566 MY WILLY GOT WET!
Posted by shenlonco on 24 February 2013 - 04:40 PM
:D LOL!! Took him out in the melting snow and muddy watered grass with his new 15 Turn motor WHAT A MESS!!
The new motor did not seem much faster than the duratrax 20 turn motor but the arrma 15 turn motor was cool it did nit get hot at all so maybe i can jump up from 18 to the 20 tooth pinion gear?
Posted Image
Posted Image
Posted Image
Posted Image
#485428 Wild willy BIG BLOCK?
Posted by shenlonco on 23 February 2013 - 04:55 AM
You'll never know until you try. Go easy on the trigger at first.
Maybe i will put the 15 turn in in the morning! :D
#485421 Wild willy BIG BLOCK?
Posted by shenlonco on 23 February 2013 - 03:07 AM
Ok since i got my new esc as seen in this video my red willy one of my 3 willy's that all have 20 turn duratrax motors in them  I am thinking in my red one maybe putting in a arrma 15 turn motor but i don't know will it be to much power for him to handel?
