lindorf
Member Since 16 Feb 2007
Offline Last Active Feb 12 2013 10:10 AM
Topics I've Started
Bigwig Help
15 August 2012 - 12:56 PM
Just aquired a Bigwig and need some opinions.
The front gear box is very notchy and jams some times .. and sounds like it grinding... dismantled it and the c clips are there .. i have new c clips ... and will replace with them .. could the gear box sides that hold the bearings be wearing out .. causing the diff cogs to seperate ?
Also the battery cover (chassis support) is missing .. does anyone have one lying about or know of a 3rd party replacement or anyone who makes them ?
Thanks for your time on this :)
Bigwig chassis Support (Battery Cover)
09 August 2012 - 12:26 PM
Looking for the chassis support (battery cover) that goes on top of the chassis from the front to the rear.
not to concerend on condition ie scratches etc as long as it aint broke where it mounts to rear post and front of chassis
Bull Head Steering
12 July 2012 - 05:49 PM
Just aquired a Bull head .. it has a hi torque steering servo.
When i lift wheels off ground all 4 wheels steer, when on ground and moving forward rear wheels turn normally.. front slightly .. in reverse the front wheels turn fully .. the rears hardly... is this normal?
Steering Pin Boomerang
30 June 2012 - 04:23 PM
ok need a little bit of help.
My 2nd aquired boomerang has no servo steering pin, which is in the Ball connector bag on Orig or is part BC10 which is in Screw bag C on Rere.
Does anyone know any other models thats used this system apart the Super Sabre or anything that can be used in replacement.
Thanks for you help on this :)
Falcon R parts (shock towers)
11 May 2012 - 04:43 PM
I need the front shock towers as my right one.. looking front on is broke on the attatch point for shock... does any one have this part.. or have any mod ideas on how fix it.
Also i was thinking of putting on an entire Bear Hawk front end... think this will work ?
