usel;escrapytwit
Member Since 29 Jul 2011
Offline Last Active Feb 25 2012 09:04 PM
Topics I've Started
scorcher shock damper question
24 February 2012 - 11:27 PM
Hi i am running a vintage 1980/2010 re re hybread scorcher and wondered if anyone can help i am running stock vintage shocks dampers and they are shocking. the oil keeps falling out i have turned them upsidedown and re built them but they are obviously worn. Anyway back to my question
Has anyone run originals with crp coil over kits and are they any good and do they leak or am i better to go re re using stock springs. also do re re s leak after a bit. I use the car as a basher but its very competertive indeed and i need to be able to get the edge over the others.
the rough rider is the more stable car so i need the have a good set up to win.
the surfaces we run are varied sand wet and semmi dry,(beach) loose and semi compact sandy dirt mountain bike track, woodland walkway paths and an old slate quarry so shale and smooth ish rock in that one.
I currenly run soft setting at the front and i have weekend the tortion bars at the rear so the suspention works as real suspention should but with out proper damping so its too bouncy(duff dampers/shocks). If i run stock settings the rear is to high and bounces to much effecting the steering and if you run the fonts on the hard setting it just snow plouges. I have tweeked the front springs now so its now soft enough but i am sure it could be better can any one help or ecomend other setups that might give me the egde.
I know its been covered b4 but i cant find any info.
swap or by scorcher stuff
30 January 2012 - 09:47 PM
Hi i am after re-re scorcher stuff for swap or buy 1980 originals.
Wanted new shocks /dampers
new rear spring tortion bars
i have to get rid of 1980 shocks rebuilt (ie will strip easy not seised up) but now leaking oil as i didnt have the correct o rings so used what i had.
Original rear tortion bars.
speed controler
please contact me or call 07795604342
is the rere better sandscorcher
30 January 2012 - 09:04 PM
Hay i am running a 1980 scorcher alongside my boy who has a 2010 re re .
I have watched them play and sat on the sidelines while he has the fun due to breakdowns and flat batterys whilst he smashes badword out of it and has had no mechanical failures at all even servo saver pops and ball joint wheel offs and stearage offs. I have now also gone electronic speed controler after he took the mick as his battery lasts so long this leads me to the only failure
i can see the reverse when going forward takes an age to learn double stick and with only half power its not so good for emergency stops reversing out of the clag and rear end sliding.
i have no more messing about with burning speed controlers
The suspession is softer but this just seems to make it grip more and not rattle the body off. it does scuff the gearbox more tho
the shocks retain there oil and dont fill up with sand
the ball joints on mine pop for a pass time his never have even thoe he is six and just loves to get air when ever he can.
i have gone the speed controler route and am looking for shocks now i have some to swap. I am also looking for rear tortion bars
Dont worry i am keeping my 79 shelfer as just that but re re has to be the way forward well done Tamiya
WHAT DO YOU THINK
anyone had the same experiances.
Elite speed products info needed
13 January 2012 - 08:16 PM
Hi i have some gold maybee up for grabs in the neer furure. Can anyone remember Elite speed product or esp i have some of there late 90s or pos 80s racing motors from the states pos 14 turn x3 modified yokomo tuned and timed with gold brush holders any info would help real old school 540s
any info would be good
Sorry if it sound like a sales thread its not i am just after some history if anyone has any info i would be thankfull i do remember once read about the bloke who ran esp and how he gave up the company in 2000 as it was getting in the way of real work as a computer company but he started in electronics when a kid with rc cars. but i cant remember his name or anything.
How good are these motors and what spec are thay i cant remember at all now i am an oldy..
Help please
Does anyone know about elite speed products
13 January 2012 - 08:15 PM
Sorry if it sound like a sales thread its not i am just after some history if anyone has any info i would be thankfull i doi once read about the bloke who ran esp and how he gave up the company in 2000 as it was getting in the way of real work as a computer company but he started in electronics when a kid with rc cars. but i cant remember his name or anything.
Help please
