I didn’t really mean to get one, I wanted to out try twin motor driving & have been trying to decide whether to get a new second gear box for my Blackfoot Xtream or just get a Wild Dagger (or one of the others of that stable) for about six months. I was being good & had a fixed budget & had bid & lost on a few Daggers, then this popped up & for no real reason (other than having wanted one for the last 20 odd years) I decide to totally blow the budget out of the window! I’ve not been looking so have no real idea if £135 is a reasonable price for one, but I love it already so don’t mind.
I’m very impressed with the tyres I thought they would be shot like the ones from my original Blackfoot (I had from new) were when I dug it back out. These are very soft with no cracks at all, do you guys think they would be the originals?
It seems to be very complete, apart from the light bar & the cracked screen can any one see anything else missing?
It has got this strange hole:
I think it may have been drilled to get at the servo screw?
It’s had a new MSC fitted, I was wandering why the resistor wasn’t fitted & found the wires weren’t long enough! I’ll be fitting an ESC soon anyway. I just wanted to try it out as standard first. Is there any reason I can’t fit an ESC that worked with a 12T motor directly into those bullet connectors & keep the series / parallel switch? I’d like to still be able to easily slow it down for my boy to drive. It’s one truck that I think really needs a ESC though, the brake function annoys me on the rear wheel drive cars, I preferred the MSC direct reverse, but this thing just forward rolls going into reverse, hopefully a progressive brake will avoid that.
Then I’ll need to ball race it, I read some where it wasn’t worth ball racing Clods, but I can’t think that’s right is it?
Finally, besides a new paint job, I’ll need to do something about the usual lack of steering from the front wheels (or rears when going backwards), the servo savers look to have been tightened right up all ready, there is no movement in them it just seems to be flex in the rods from the servo & the gear boxes rotating rather than the wheels moving. It’s ok when out in the open it turns eventually, but it’s annoying when trying to crawl up something you need to get it aligned with just right. I don’t really want to go with a servo on the gear box as I’d like to keep it looking standard, any other suggestions?
Find content
Not Telling
