KEV THE REV
Member Since 13 Aug 2004
Offline Last Active Yesterday, 08:36 PM
#490689 Don't buy this Blazer.
Posted by KEV THE REV on 03 April 2013 - 09:36 PM
One of the vintage Hilux pics was mine - and thanks to an alert from a TC member ( thanks Simon )it was reported
#490206 The $60 Sand Scorcher Tell me what I have exactly?
Posted by KEV THE REV on 01 April 2013 - 10:30 AM
If you look at the rear A arms ,the MK1 had 2 bearings in them , later chaged to 1 bearing to the outer , the MK1 servo saver was different also to the MK2 . Those MK1 front arms are very delicate and can break easily if run too hard , hence beefing them up on the MK2 . A great result for $60
#489418 I've been given a....
Posted by KEV THE REV on 26 March 2013 - 03:39 PM
I've received a lot of help over the years with my projects etc and I've returned the favour to many other members , good on you guys ;)
#489005 Looking for a good 7.2 6 cell Humpback Battery
Posted by KEV THE REV on 23 March 2013 - 08:00 PM
Carson 7.2v 2700 Tamiya Type Hump Back Pack #55059 from
Modelsport UK
#487469 Are The BlackFoot Roll Bar & Spots The Same Ones For Hilux?
Posted by KEV THE REV on 12 March 2013 - 09:00 PM
Pretty sure the spots & roll bar are the same
#481878 Vintage Sand Scorcher Rebuild
Posted by KEV THE REV on 30 January 2013 - 08:39 PM
The Scorcher you have is a Mk1 which has many differences between the later 'Mk2' and certainly a lot different to the recent re-re Scorcher .Your rear gear casings have seperate 'ear type' rear cage lugs as opposed to a 'solid' rear bar for cage mounting and various other small differences .You could try filling that duff thread in with 'chemical metal'and re-tapping it to look cleaner than a bolt if it is going to be a display 'shelfer' ( a Mk1 should be due to the rarity of the original parts)Those oh so rare front arms are lighter ,thinner ,weaker castings than the Mk2 and re-re , and apart from looking 'odd' the re-re arms have different sized ball races to the original .The twin bearing rear arms are the mk1 original type too , very hard to get hold of but if you are going to run it the single bearing type will do .All in all ,you have a very nice Scorcher with the early and rare black bumper , a much sought after bug
#480262 Just bought a Lunchbox!
Posted by KEV THE REV on 19 January 2013 - 11:17 PM
That is one supercool - red hot Lunchie , you should have lots of fun with this   :)
#470960 TR-15T 'Reinforced' Parts for Dyna Storm
Posted by KEV THE REV on 22 September 2012 - 07:42 PM
The sprue is marked 'Dyna-Storm' but it is a charcoal gray , not black ,and it is for the TR15T .What you have is correct
#464054 3x8mm Step Screw
Posted by KEV THE REV on 22 June 2012 - 08:44 AM
Message sent :)
#463609 electric contact grease?
Posted by KEV THE REV on 15 June 2012 - 07:39 PM
Hi Guys,
I am after some of your expertise and knowledge.
I currently am using standard Tamiya push connectors and the standard Tamiya battery connectors, I know there are better connectors out there but my soldering skills are weak to non existant... :unsure:
Is there a gel or grease I can put on these connectors to improve the electrical connection between them and keep moisture out of the connectors without changing them?
I used to use copperease on my big car battery terminals, would this work on the small connectors too?
you can buy Tamiya switch lube which enhances electrical contacts  - which was used on Tamiya MSC's
#463279 Buying empty boxes, filled with genuine 1980s Tamiya air.
Posted by KEV THE REV on 12 June 2012 - 09:28 AM
I have a loft and cupboards full of kit boxes - some are mint new with just the contents removed and some are well used and some in between,and of course most have full kits in them, but I can't resist the kit box / body set box etc. When I say to people that I collect boxes they think I'm mental - well maybe I am , but who cares? .I use some of them to store cars or spares in , - cool eh?
