backtomyroots
Member Since 11 Jan 2005
Offline Last Active Today, 07:17 PM
Topics I've Started
TXT-2 Build, Nice truck !
19 May 2013 - 12:11 AM
More to come next week but just completed the truck, very nice with a few modifications !
Too excited to wait to get the details out but here are some teasers:
Bruiser Shifting (RE-RE)
21 April 2013 - 05:48 PM
Built my Bruiser Re-Re last year just been tinkering with running it now.
When the wheels are off the ground and I shift from 4wd to 2wd it doesn't seem to "catch" in middle gear but does in high 2wd. Same with going back to 4wd, seems to skip over middle gear.
When running (wheels off the ground though) and shifting, it shifts, but makes a bit of a "click or clunk" but seems to shift and not stutter a bit better.
Was this designed to shift standing still or while driving and does this sound like a "transmission rebuild" ? (Which, at the moment I've no time for).
(Spektrum DX3E has radio has shifting responsibilities)
The truck:
http://www.tamiyaclu...115311&sid=7434
:o
External BEC - Yes ? No ? I Dont't Know ?!
20 April 2013 - 08:47 PM
I'm not the most "electronic type" so seeking advice.
Truck: Tamiya TXT-2 Agrios
Steering Servo: HS-646WP (Waterproof/High Voltage/High Torque)
Servo Specs: Torque @ 6.0v = 157 oz-in
Torque @ 7.4v = 179 oz-in
ESC/Motor Combo: Traxxas Velineon System
Velineon System Specs: (ESC) BEC Current 6 volts
No Motor Limit
BEC Current 2.5A (with 6-cell NiMH)
Continuous Current 200A
Braking Current 320A
Peak Current Forward/Reverse 320A
(Motor) 10 Turn/3500 KV
Additionally running: Traxxas ESC Fan (Plugs right into the ESC)
Integy Motor Cooling Fan (Plugs into receiver)
Radio/ESC - To be Determined (Possibly Futaba 3PL System)
Battery: Traxxas 7.4v 5800 mah LIPO (25C) (May try a 3s Lipo for fun)
QUESTION ?
Do I need to run an "external BEC" such as those sold by Castle Creations ?
Am I to assume that the servo will get the minimum 6v from the esc as it is ? But to get the most from it do I need the BEC to get the torque up ?
I am a bit confused.
Or without the BEC will the servo be getting the standard 4.8v of power ?
Any advice would be great and appreciated. Any other External BECS recommended other than Castle's ?
Getting excited to get my AGRIOS built.
Wrangler Re Re - Scaled out with interior & Winch
05 April 2013 - 09:20 PM
Near mint Tamiya Wrangler Re Release Kit #84071.
Equipped with:
•Custom clear windshield and interior with Tamiya Holiday Buggy Cowboy Driver Head
•Functioning 3Racing winch mounted to front bumper
•Headlights and Taillights / Tamiya TLU-01 Light Unit
•Custom metal rear light protectors/guards
•Spektrum DX3E 3 Channel Radio (3rd channel operates winch)
•Junfac skidplate (now out of production)
•Full Ball Bearings
•Hitec High Torque Steering Servo
•Tamiya F350 High Lift Tires
•Spare rear mounted tire (no name tire from ebay)
•Tamiya TEU-104 ESC
•Axial Walker Evans Wheels (Tires are not glued on)
Good luck and check my other items, thanks !
Auction:
http://www.ebay.ca/i...=item2a2b673491
Left Handed Radios ?
18 March 2013 - 08:55 PM
Hey folks, who makes a pistol radio that can have the wheel flipped over for a left handed user ? (For a relative).
I've seen a few but am drawing a blank.
Want it to be 2.4 GHZ as well & reasonably priced.
Thanks !
