BuggyDad 4475 Posted November 11, 2021 6 minutes ago, Wooders28 said: I helped Barry, aka Granddad Stinky , with his front hex conversion, after I found the Kyosho RB5 was pretty much a bolt on mod, but it looks like the 'photo bucket ransom' has broken the thread up a bit..... Although, RB5 parts look a bit thin on the ground now and a therefore ,a bit pricey, but looking at the thread above, there's plenty of options 👍 Can't see the pics but I think this is to replace knuckles and axle with some from a 4wd. So same thing, different source parts? Share this post Link to post Share on other sites
alvinlwh 5895 Posted November 11, 2021 18 minutes ago, BuggyDad said: So same thing, different source parts? Even better if not from HK! Share this post Link to post Share on other sites
Wooders28 4723 Posted November 11, 2021 26 minutes ago, alvinlwh said: For road use, I can use Fastrax Arrows I used those for a bit on my Dark Impact, for on road use. But with 5700kv/3s power, the cheap wheels cracked in no time. 1 Share this post Link to post Share on other sites
BuggyDad 4475 Posted November 11, 2021 11 minutes ago, alvinlwh said: Even better if not from HK! Looks hard to find the bits though. Share this post Link to post Share on other sites
Wooders28 4723 Posted November 11, 2021 26 minutes ago, BuggyDad said: Can't see the pics but I think this is to replace knuckles and axle with some from a 4wd. So same thing, different source parts? The only pics you can see, are the ones I posted, but there's part numbers in the RB5 exploded diagram pic. It's to replace the dt02/03 front, with C hub and front hex from a Kyosho RB5, pretty much just bolts on! Only down sides, I think it altered the camber, so need adjustable turnbuckles, and there a bit of play with the C hub in the wishbone. Share this post Link to post Share on other sites
alvinlwh 5895 Posted November 11, 2021 @BuggyDadRegarding "just sticking in a 4WD front uprights", I have some spares from a TT01 and a M-05, both will not work as our C hubs are away too small. The 1260 bearings alone is wider than the hub clearance. Only way it can work is find some hubs using 850 or something like that bearings I believe. I will check the uprights of a SU-01, but that part is not available anywhere as a spare. Share this post Link to post Share on other sites
alvinlwh 5895 Posted November 11, 2021 4 minutes ago, Wooders28 said: It's to replace the dt02/03 front, with C hub and front hex from a Kyosho RB5, pretty much just bolts on! This? https://www.plazajapan.com/4548565210244/?setCurrencyId=4 Shame I just completed an order with PJ 2 days ago! 1 Share this post Link to post Share on other sites
BuggyDad 4475 Posted November 11, 2021 Yeah sorry, they're not 4wd ones, the principle is as per @Wooders28's pics above, except the 3racing option reuses the Tamiya c hubs. There's also Associated B5 similar parts but with more bits to find I expect a bit more money. 1 Share this post Link to post Share on other sites
Wooders28 4723 Posted November 11, 2021 22 minutes ago, alvinlwh said: This? https://www.plazajapan.com/4548565210244/?setCurrencyId=4 Shame I just completed an order with PJ 2 days ago! Those are RB6? Could be the same, i can't say for sure, as I've not tried. If I remember right, it was the shaft that was expensive. I had/have an RB5 in bits, as I used the rear end on an original Ultima resto mod build. Share this post Link to post Share on other sites
Wooders28 4723 Posted November 11, 2021 23 minutes ago, BuggyDad said: Yeah sorry, they're not 4wd ones, the principle is as per @Wooders28's pics above, except the 3racing option reuses the Tamiya c hubs. There's also Associated B5 similar parts but with more bits to find I expect a bit more money. I bet there's alot out there that'll fit! Watched an old cheap 2wd car go on ebay for just over a tenner, (i was looking for Ansmann parts!) that had 12mm hex fronts ,which i bet could have been made to fit. As time goes on, there'll be plenty that'll be snapped up for a song. Share this post Link to post Share on other sites
Frog Jumper 3661 Posted November 11, 2021 4 hours ago, alvinlwh said: Does the Schumacher 2.2s fit straight on? Slim ones right? Share this post Link to post Share on other sites
alvinlwh 5895 Posted November 11, 2021 4 minutes ago, Frog Jumper said: Sorry for being a nob, but need more to the search. Class > Buggy? Wheel diameter > 2.2? (My wheels measures out to be closer to 60mm than 55.8mm of 2.2) Width > ? On Modelsports website, they don't filter Schumacher by width. My guess is slim for Tamiya front wheels and rear for rear wheels, is that correct? Share this post Link to post Share on other sites
alvinlwh 5895 Posted November 11, 2021 @Wooders28 if you don't mind, do you know the difference between mini pins, mini dart, mezzo, stagger, etc...? I had seen a guide and it made no sense to me and nothing specific about road running. Which style will suit my needs best? Sorry for being a complete nob. Share this post Link to post Share on other sites
Wooders28 4723 Posted November 11, 2021 3 hours ago, alvinlwh said: @Wooders28 if you don't mind, do you know the difference between mini pins, mini dart, mezzo, stagger, etc...? I had seen a guide and it made no sense to me and nothing specific about road running. Which style will suit my needs best? Sorry for being a complete nob. Schumacher have designed tyres over the years, to suit the popular tracks (best sales). Mini pins where good on carpet, but been superceded by Cactus, not sure if the carpets changed over the years, as now it 'EOS' (European Off-road Serise) carpet. Darts where/are good on grass and Astro. Mezzo have been designed for Astro, although found for wet Astro (ours at least) the Ballistic Greens are better than silver Mezzo. They make 'Honeycomb' tyres , which where designed for the Schumacher race series down in Worksop, which I believe is a Cork like flooring. Schumacher don't do many road tyres in 2.2" , they do 1.9" ,and used them on an Ultima fronts. I use the ,'venom' tyre, on the rear, which I used to use on the old Nitro XTR3e, with the only other one I know of the ,road and track tyre. https://www.modelsport.co.uk/product/schumacher-road-and-track-rt1-rear-b30-pr-422454 1 Share this post Link to post Share on other sites
alvinlwh 5895 Posted November 13, 2021 @BuggyDad etc... Got my hex adaptor today and they are a BAD idea and completely useless. With them in, the lock part of the wheel nut will not even touch the axle. Never mind the fact that any attempts to tighten it will actually stop the wheel from turning. They are just too thick to be any use to us using stock DT uprights. Might work somewhat if they are 2 or 3 mm thinner. 1 Share this post Link to post Share on other sites
matisse 1581 Posted November 13, 2021 Imo best option is the Schumacher Cougar KR hex kit. Share this post Link to post Share on other sites
BuggyDad 4475 Posted November 14, 2021 15 hours ago, matisse said: Imo best option is the Schumacher Cougar KR hex kit. Sounds good I'd ordered the 3racing bits before seeing this. Interested to know what the advantages are of the Schumacher kit over that? Share this post Link to post Share on other sites
BuggyDad 4475 Posted November 14, 2021 16 hours ago, alvinlwh said: @BuggyDad etc... Got my hex adaptor today and they are a BAD idea and completely useless. With them in, the lock part of the wheel nut will not even touch the axle. Never mind the fact that any attempts to tighten it will actually stop the wheel from turning. They are just too thick to be any use to us using stock DT uprights. Might work somewhat if they are 2 or 3 mm thinner. Ah bad luck. I guess there must be a way to use them that works or others wouldn't be happy with them, but I can't get my head round what that is. I'll post up once I try out the 3racing bits. Removal of some c hub material is required, so am a little wary of weakening those, but we'll see what happens. Share this post Link to post Share on other sites
matisse 1581 Posted November 14, 2021 39 minutes ago, BuggyDad said: Sounds good I'd ordered the 3racing bits before seeing this. Interested to know what the advantages are of the Schumacher kit over that? Ease of fit. The Schumacher knuckles just needs the hole reaming to 3mm and a couple of spacers, whereas the 3racing part needs more work. Share this post Link to post Share on other sites
BuggyDad 4475 Posted November 14, 2021 41 minutes ago, matisse said: Ease of fit. The Schumacher knuckles just needs the hole reaming to 3mm and a couple of spacers, whereas the 3racing part needs more work. Ah. Gotcha. These? https://www.makeitbuildit.co.uk/front-hub-carriers-cougar-kr-pr-50584 I wonder whether they take the same axles, £7 here might be preferable to cutting my c hubs. There seemed to be a suggestion a lot of these axles are cross compatible anyway. Share this post Link to post Share on other sites
alvinlwh 5895 Posted November 14, 2021 7 hours ago, BuggyDad said: Ah bad luck. I guess there must be a way to use them that works or others wouldn't be happy with them, but I can't get my head round what that is. I'll post up once I try out the 3racing bits. Removal of some c hub material is required, so am a little wary of weakening those, but we'll see what happens. They can somehow work for longer axles where the nut can actually grip but it still does not remove the problem of the nut rubbing on the wheels itself. I am trying something else, but will have to wait 2 weeks for parts to arrive. Will do a writeup if it works. Share this post Link to post Share on other sites
matisse 1581 Posted November 14, 2021 5 hours ago, BuggyDad said: Ah. Gotcha. These? https://www.makeitbuildit.co.uk/front-hub-carriers-cougar-kr-pr-50584 I wonder whether they take the same axles, £7 here might be preferable to cutting my c hubs. There seemed to be a suggestion a lot of these axles are cross compatible anyway. There is a full conversion kit front and rear hex with all the bearings and hubs. https://www.makeitbuildit.co.uk/hex-wheel-conversions-12mm-f-r-cougar-47843?gclid=Cj0KCQiAhMOMBhDhARIsAPVml-GTSVaRBsdHKXJxSGyisE3-Xw1HbfgiuXX_EgKkqVlxsvxyAqI0yQsaAi9DEALw_wcB Share this post Link to post Share on other sites
BuggyDad 4475 Posted November 14, 2021 46 minutes ago, matisse said: There is a full conversion kit front and rear hex with all the bearings and hubs. https://www.makeitbuildit.co.uk/hex-wheel-conversions-12mm-f-r-cougar-47843?gclid=Cj0KCQiAhMOMBhDhARIsAPVml-GTSVaRBsdHKXJxSGyisE3-Xw1HbfgiuXX_EgKkqVlxsvxyAqI0yQsaAi9DEALw_wcB Gah! If only I hadn't been so hasty. Thanks! Share this post Link to post Share on other sites
Wooders28 4723 Posted November 14, 2021 2 hours ago, matisse said: There is a full conversion kit front and rear hex with all the bearings and hubs. What C hub (Yokes) did you use, the TRF? Trying parts off my Laydown , nothing was a direct fit, and would have needed some 'trimming' (hacking at it with a hacksaw 😏😁) Share this post Link to post Share on other sites
matisse 1581 Posted November 14, 2021 42 minutes ago, Wooders28 said: What C hub (Yokes) did you use, the TRF? Trying parts off my Laydown , nothing was a direct fit, and would have needed some 'trimming' (hacking at it with a hacksaw 😏😁) I did, the TRF 201, but the standard would have for as well with the right spacers 1 Share this post Link to post Share on other sites
