Dear all
We are building together with my 9y old son our first truck and the project went as planned until we got to the teaching mode of MFC03.
Dispite that we have double checked all the things and done the teaching mode several times. All the things are "backwards"
- engine is running slower front and having reverse lights on and reverse allarm is on
- signal lights are to wrong direction
Etc.
To me it sound like MFC03 get commands wrong way from controller? Or Is something still plugged wrong way?
What we have tried to change to throtle and stearing servo direction from controller - this helps with controller working to correct direction but don't help with engine, signal lights and sounds to work correctly.
We have combination of following gear:
- MCF-03 Euro-style
- Tamiya MB Actros 3363
- Carson Reflex Stick Multi Pro LCD 14 channels
We would greatly appricite any tips to fix the issue. Thank you in advance
Attached the picture how things are wired if that helps.
Annoyingly, Carson Tx/Rx seem to work in reverse and things must be set to reverse on the TX.
Carson, is in fact, Tamiya, so I am surprised that they don't work nicely together.
Try swapping the lights (say L/R) at the MFC side and see if it works. Work outwards from there to brake, acceleration, etc. Don't have one so not sure what all the functions are.
