Looking like a won't get my dad's signature, he's been getting more frail as the days have rolled by, and is now End of life care.
I asked him if it would be okay to draw around his hand, so i can give him a high five, and he gave a big smile.
Managed not to knock too much stuff over in the care home 🫣, but ...👍
Blue is his favourite colour, and so got his approval on choice of paint too.
20250213_131650
I'll add my projects into the mix.
My pride and joy, a Mercedes 190E 2.5-16 "Cosworth" that I bought a couple of years back. She needed massively de-chavving (un-riced, anti-bogan'd, dis-ruined, basically), as she had stickers, fake carbon strips, an AMG badge, modern wheels, interior damage from fitting speakers, the wrong grill, wrong indicators, rear bumper damage, side skirt damage, horrible exhaust and she was so low that the suspension mounts were hitting the ground!
Before:
20230417_145406.thumb.jpg.d7da6d621269561a15b1856502524533.jpg.2a7e6763ffee45ff54b5abd3caec664b.jpg
Now:
As of last year, I've started displaying her at classic car shows. Really enjoy it!
Still work to do and funds are limited, but she'll get there!
Now running a stainless exhaust system from Stainless Creations (Falkirk) and Green performance air filter. She sounds immense! :D
2 hours ago, Mikey P said:
Now:
Wow , superb , sooo much better 👏👍
Only heard (🙄) good things about them!! I know a few who've been there.
I've got a full 2.5" X pipe system from Magnaflow,
20200807_173517
Not sure how quiet it'll be though...
20200807_173523
Did buy some DB7 Vantage exhaust tips
20210531_155038
 But not sure what they'll do on the noise front...
20210531_154937
Loom done for the tail lights.😁
-LED Reverse light /fog light dual bulbs
-LED Stop / Tail bulbs
- LED Stop / Indicator switchbacks, with a 5 pin relay, allowing to run through a voltage regulator (when zero volts from the braking circuit) to give Tail/Stop/Indicator out of the same bulb.
- Sequential LED controller (capacitor hold on relay circuit), to give Sequential turn signals (which can be changed to different speeds, and different modes/sequence. Going to run the change button to the centre console, for 'show use only'...🙄
10 hours ago, Mikey P said:
First car show of the year, May 11th.
Bridge of Allan, Stirling, Scotland.
Looking good!
Completely forgot this was on!! 🤦‍♂️
  • 2 months later...
Been a good while since I've posted on here...
The capacitor discharge/hold on unit I built, the stripboard I used, one of the tracks has come apart, and lifted off the fibreglass/board, so going to have to redo it.
20250720_125446
I had trouble when soldering, tried various soldering irons, lead free solder, 60/40 solder and still rough as, had to run wire down the lengths, as it was lifting the track...😳
Any electronic guys on here, recommend a good stripboard ?
(Or if you've access to making a printed circuit board?...🙄🤞)
Just the last piece, before I can button it up.
20250720_125510
Also, been up and down the road a fair bit the past few months, and now at least the exhaust is all in the same country!! 😁
20250726_145948
Anyone had a chance over the last few months to get anything done on their project?
Found what looked to be a thicker and better quality stripboard on ebay. Cost the same for 1 as it did 5 of the others, but I just need 1 decent one, and buying 5 of the others turned out to be a waste of money...😔
20250731_170343
The terminal block doesn't clip together though, as the pins are a little further apart, don't think it'll be an issue..
20250801_143606
20250801_143558
Postman also delivered the bearing rebuild kit. Rockauto have an unbelievable delivery time, ordered and arrives within 2 days , all.duties paid etc, can't argue with that (although giving me an Audi TT fridge magnet, really?...🤦‍♂️🤣)
20250731_140317
 Also found a new pin and bolt in the box with the Diff..
20250730_225803 20250730_225657
Maybe because someone has damaged the carrier! 🤦‍♂️
20250730_225420
But machined the other side...
20250730_225311
Hopefully get this nailed in before the weather turns, and I go back to not feeling my fingers in the garage.🥶
