Just wandering if a scorcher body will fit on a DT02? My son has a holiday buggy but the body is badly damaged now, but the cost of a new bare body (no decals extras or driver is almost £30!!) I can get a full Scorcher bodyset complete for £3 more.
Thanks,
James.
14 minutes ago, Nobbi1977 said:
That should be a factory kit
Indeed, cheap cheerful chassis and scale looks. And prob 1/3 the price of a scorcher. 👍
James.
On 12/4/2021 at 2:35 PM, Killajb said:
What about these wheels please?
Max
This is mine, starting point a DT02 Sand Viper kit with some modification
to be more in line with the wheelbase and track width, I replaced the lower arms F/R with the R ones of the DF02 kit (both front and rear).
If you use a sand viper kit (high end, with metallic dogbone and drive cups) you can replace the dogbones with those himoto code 08061 or with other total 63mm long.
but if you are looking for a less "sand scorcher" and more "blitzer beetle" look, you can leave it as it is.
Gorgeous,
Could you please explain what you use for the body mounts ? I am trying to fit a beetle body on my dt02 (more in a bltzer spirit) and I am struggling with that point.
3 hours ago, menoce said:
Gorgeous,
I bent an aluminum rod, hollowed out two seats in the rear support and then the whole thing locked by a fiber support for mini4wd
and something similar on the front using pieces left over from other models
this first version was not very reliable and has been modified, simplifying it.
Thank you !
Once I get all my open projects done and once I can source a new body for around $50-60 again, I plan to make a low riding street version of the Sand Scorcher.
It will run touring car tires and will resemble a stance similar to this..
