Golden 169 Posted December 18, 2021 Has anyone got both of these models…? The rear wheels of the Holiday Buggy look to be the same design as the Super Avante, but look to be the “correct” shade of yellow…. Anyone able to confirm if the rears would be a straight swap/correct size - and if the colour match is closer to the Super Avante yellow box art for the shell? Share this post Link to post Share on other sites
Kol__ 3377 Posted December 18, 2021 I believe the rears are the same size, at 35mm width, with the new Super Avante being fluro yellow and the Holiday Buggy being a normal yellow. The HB 2WD bearing fit fronts however are thinner at 19mm, and I think the 4WD hex fit SA fronts are likely to be 30mm. Share this post Link to post Share on other sites
Superluminal 3750 Posted December 18, 2021 It does look like the HB yellow wheels is a better match to the yellow decals scheme of the Super Avante. You would need to run a set of rear wides up front as well - bit like the very original Avante then. Share this post Link to post Share on other sites
