Sgt.Speirs 1253 Posted January 11, 2022 @Honza: I see there no difference or a offset bearing on the ball diffs. Only the shims are different (TRF201: 0.1mm on both sides, TD4: 2x 0.2mm on both sides). Or do you meant something else? @Collin: You have to see what a RC car from the 90s not will be in 2022...a car for bashing. So making big jumps or flying through the air with this car is not the intention for this modification. But you're right there are materials which would be more suitable. On the other side, for the first loop/prototype non-professional FDM parts are sufficient (in my point of view). Regarding the stress loads on the FDM parts, I see this not so pessimistic. The brackets have to handle mostly compressive loads. The upper bracket is planar flush with the chassis, so vertical stress loads will be deflect (correct expression?) to the chassis and will not generate (big) deformation/torsion of the bracket itself. Vertical stress loads = loads from the suspension introduced via the sub-chassis/FRP plate or loads directly onto the sub-chassis/FRP plate Green the FDM parts, orange the screws/fasteners. For horizontal stress loads (hard landing onto the motor guard) should be split into the sub-chassis and into the upper bracket. In this load case, the gear case itself is also a supporting element for the upper bracket. So hopefully also no (big) deformation/torsion of the bracket itself. Disclaimer: These are my assumtions and no results of a stress analysis (FEM) 6 Share this post Link to post Share on other sites
bavee 1032 Posted January 11, 2022 On 1/9/2022 at 10:08 PM, Sgt.Speirs said: Maybe at the end of this conversion/mod there is a special TRF gear case with attachments for the King Cab/Hilux MR chassis available. And also the corresponding „sub chassis“ (FRP plate). We will see… That would be great! Share this post Link to post Share on other sites
Honza 937 Posted January 11, 2022 1 hour ago, Sgt.Speirs said: @Honza: I see there no difference or a offset bearing on the ball diffs. Only the shims are different (TRF201: 0.1mm on both sides, TD4: 2x 0.2mm on both sides). Or do you meant something else? I meant distance of the 1015 bearing from "plate" Pictures are from TD4 and TRF201 manuals (sorry for quality I'm on a phone) Share this post Link to post Share on other sites
Sgt.Speirs 1253 Posted January 11, 2022 @Honza: I have overseen this detail. But maybe this explains the usage of the different shims. Maybe there is somebody with a TD4 chassis can meassure the diff width from bearing (1510) to bearing Share this post Link to post Share on other sites
Honza 937 Posted January 11, 2022 2 hours ago, Sgt.Speirs said: @Honza: I have overseen this detail. But maybe this explains the usage of the different shims. Maybe there is somebody with a TD4 chassis can meassure the diff width from bearing (1510) to bearing From your picture, it seems that difference is at least 5mm. The TD4 is compatible with TA06 gear diff, so I guess that ball diff width on bearings is more or less the same. Different shims will make 1mm difference. However, TRF201 has steel outdrives, right? They shouldn't wear that much and rest of the diff should be same or at least compatible. Share this post Link to post Share on other sites
matisse 1581 Posted January 11, 2022 16 minutes ago, Honza said: From your picture, it seems that difference is at least 5mm. The TD4 is compatible with TA06 gear diff, so I guess that ball diff width on bearings is more or less the same. Different shims will make 1mm difference. However, TRF201 has steel outdrives, right? They shouldn't wear that much and rest of the diff should be same or at least compatible. From experience shimming the TD4 ball diff, there may be as much as a 1.5mm difference in width between that and the TA06 gear diff Share this post Link to post Share on other sites
Sgt.Speirs 1253 Posted January 22, 2022 After two busy weeks at work and preparation of my son‘s birthday I found today time to continue the project. I knew that I hardly find time in the last weeks and played with the idea to let the sub chassis plate milling by a local company. But I decided to do it manually…this time with no electric tools (except the drilling machine). The rough shape with the hacksaw… …the fine shape with the fret saw… …and the final step with different files. The plate fits! Drilling the holes is planned for tomorrow. 5 Share this post Link to post Share on other sites
Sgt.Speirs 1253 Posted January 28, 2022 One week later, the countersunk holes in the sub chassis plate are drilled and I could started with the final assembly. I also updated the upper bracket once again. I thicken the transition between the two mountings and I re-designed the front spacer to avoid rotating without using 2-component adhesive (lower bracket on the picture below). Assembling… And then another part arrived...the milled sub chassis plate in carbon fiber 10 Share this post Link to post Share on other sites
GTodd 1352 Posted January 29, 2022 7 hours ago, Sgt.Speirs said: One week later, the countersunk holes in the sub chassis plate are drilled and I could started with the final assembly. I also updated the upper bracket once again. I thicken the transition between the two mountings and I re-designed the front spacer to avoid rotating without using 2-component adhesive (lower bracket on the picture below). Assembling… And then another part arrived...the milled sub chassis plate in carbon fiber DUDE! SIGN ME UP! Seriously, I want right now! Tamiya are you paying attention? Why havent you done this????? 4 Share this post Link to post Share on other sites
Sgt.Speirs 1253 Posted January 29, 2022 During the last weeks I also started with the assembly of the chassis which I would also like to share with those who are interested. Step 1: Step 2: Step 3 to 5: Step 6 to 7: Step 8: Step 9: Step 10: Step 11 to 20 (assembly of the rear suspension with gearbox) I have already done in the previous post. So we can skip to step 23 where the gearbox with motor is married with the main chassis. Step 25 & 26: Step 27* to 29* with the sleeved dampers: Step 30 to 32: Step 33 to 41 (electrics) are skipped. Step 42: When I bought the chassis, it did not come with wheels and tires. I decided to use the wheel/tire combination of the Stadium Blitzer for this runner. Step 43: With the blue wheel nuts and in combination with the blue dampers and motorplate the chassis looks very nice in my opinion Now I'm looking forward for some dry or sunny days to make some test drives with the car. 14 1 Share this post Link to post Share on other sites
Kol__ 3377 Posted January 29, 2022 Brilliant mate, you've achieved such a great, high end finish to the work done so far, and not surprising, we've all been able to share the journey with you and seen the methodical level of dedication and accuracy you've been putting in. Bravo buddy, bravo! Although a fan, I don't own this chassis yet, but it would seem nuts not to put this out there in the main stream, so I really hope you do 1 1 Share this post Link to post Share on other sites
Grumpy pants 4485 Posted January 29, 2022 Absolutely superb, really impressive stuff 👍 Share this post Link to post Share on other sites
wtcc5 4900 Posted January 29, 2022 @Sgt.Speirs: Do I see an option on the shocktowers to use the upper holes as shockmounts, too? 1 Share this post Link to post Share on other sites
GTodd 1352 Posted January 29, 2022 11 minutes ago, wtcc5 said: @Sgt.Speirs: Do I see an option on the shocktowers to use the upper holes as shockmounts, too? Yes but thats for the stock shocks as they are for the long CVAs. The Med Hicaps are shorter. 1 1 Share this post Link to post Share on other sites
GTodd 1352 Posted January 29, 2022 Well done man, looking great! Share this post Link to post Share on other sites
ThunderDragonCy 7886 Posted January 29, 2022 That is such a cool looking truck Share this post Link to post Share on other sites
Sgt.Speirs 1253 Posted January 30, 2022 And some impressions from the carbon fiber sub chassis plate... Some edges of the plate are currently not perfect flush with the chassis, but these are some minor changes in the design. @GermanTA03Guy: Thanks for the tip about the company who milled this plate 8 Share this post Link to post Share on other sites
GermanTA03Guy 1327 Posted January 30, 2022 You're welcome looks fantastic. 1 Share this post Link to post Share on other sites
Sgt.Speirs 1253 Posted February 10, 2022 Before the first test drive I got some aluminum spacers. I decided to replace the FDM part in the front by these. Ready for the ride (3000KV brushless system @ 2s/4000mA LiPo)… …on the testing ground… …and after the successful ride (20 min over my bumpy lawn and my 10 cm high skate ramp). Everthing worked fine and the brushless system gave the car a nice boost. I even had to take care, that the car did not make wheelies by driving/accelerating over bigger earthworm hills. After the ride, no damages are visible on the (3d printed) parts. Ok, my garden is not representative for a RC track with bumps and jumps, but this will be the next challenge when the track near my home town has opened again. 10 Share this post Link to post Share on other sites
slydar 241 Posted February 12, 2022 Very neat work, especially the home made chassis plate Share this post Link to post Share on other sites
Sgt.Speirs 1253 Posted March 9, 2022 Only a little sign of life in this build thread here: Currently I'm waiting for the the body/decals (--> Hilux Monster Racer). In parallel I worked together with @ThunderDragonCy on a transmission case with includes the 3D printed parts of my design. ThunderDragonCy re-designed the transmission case of the TRF201/Zahhak for a gear diff (TA06 Gear diff transmission case for TRF201X and DN01 Zahhak). So the goal of this merge is a transmission case for the gear diff (e.g. TA06) which fits to the King Cab chassis attachment points. First design draft: Due to the gear diff width of the TA06 and the original ball diff width of the King Cab differs only by 1mm, maybe this transmission case will also work with the original sub chassis (frp plate). I will investigate this in the next week(s)... If there is interest here that this gear case should be available on Shapeways for example...let me know. 6 Share this post Link to post Share on other sites
GTodd 1352 Posted March 13, 2022 On 3/9/2022 at 3:25 PM, Sgt.Speirs said: Only a little sign of life in this build thread here: Currently I'm waiting for the the body/decals (--> Hilux Monster Racer). In parallel I worked together with @ThunderDragonCy on a transmission case with includes the 3D printed parts of my design. ThunderDragonCy re-designed the transmission case of the TRF201/Zahhak for a gear diff (TA06 Gear diff transmission case for TRF201X and DN01 Zahhak). So the goal of this merge is a transmission case for the gear diff (e.g. TA06) which fits to the King Cab chassis attachment points. First design draft: Due to the gear diff width of the TA06 and the original ball diff width of the King Cab differs only by 1mm, maybe this transmission case will also work with the original sub chassis (frp plate). I will investigate this in the next week(s)... If there is interest here that this gear case should be available on Shapeways for example...let me know. I am very interested, as in I want! Id love to rder all the associated parts from you now! I plate and the other components needed. 1 Share this post Link to post Share on other sites
Sgt.Speirs 1253 Posted March 17, 2022 And here is the final gear case... @ThunderDragonCy: Thanks for your support I printed both parts for the mentioned investigation...with the result that the original sub chassis plate will fit, but with too much compromises (the rear attachement points of the gear case are misaligned with the cassis plate respectively the orignal motor guard cover cannot be used). The merged upper bracket is flush with the chassis. The dog bones have not too much play. The four mounting holes from the main chassis fits perfect. The motor sits in the TRF gear case lower than in the original gear case. In this case the motor almost touch the sub chassis plate, so there is no space for mounting the motor guard cover from the top side of the plate: That means that for this gear case I have to modify the sub chassis plate once again...until the final 3D printed gear case parts will arrive. 4 2 Share this post Link to post Share on other sites
Sgt.Speirs 1253 Posted April 2, 2022 Small update for today until the gear case parts arrived from the UK Some other parts arrived the last weeks to completing the look: Hi-Lux Monster Racer body from TBG The decal set for the MR from mciracing Original B-Part Tree (TA-10005358) which includes the front bumber Original wheel set (TA-19335083) --> For both original parts thanks to Simone from Italy Front and rear body mounts I created by my own. For the tires I have not yet made a decision. I am thinking about the following pairings: 1. HPI Front Line + HPI Ground Assault: These were also used from a user here in his showroom >>Fully optioned Monster Racer<< 2. Jconcepts Carvers 2.2 + Traxxas Pro-Trax Spiked Tires 5 Share this post Link to post Share on other sites
