good evening all,
I have been stalking this forum for a few weeks and would like to say that there is some truly inspiring peeps on here. you have rekindled my childhood hobby and for that I have to say thanks ! i'm on the hunt for some wheels and tyres for a build I want to recreate ive seen on youtube. the chap builds beetle and puts Hoosier drag wheels front and back on black wheels, ive been searching high and low for them but cannot find.
they are for a Tamiya DT03 [1:10 scale] if any one can sell me some I would be a very happy man .
happy RC'ing
Chaps , I would appreciate a little help, I've bought the tyres , and tracked down the wheels to match ,the next hurdle is the wheels are hex (they are going on a Dt02 b) which means the Front axles are too long and the hex have no bearing d , I've overcome the bearing issue with ball raced inserts but the axles are too long and if I pack them out the Front face of the wheel binds as there is no facility to put the bearing against the lock nut. Please help !!!!!!
Do you have pictures of the problem? To be honest I don't understand the problem from your description.
Maybe your question is better placed in the general section or in the build tips section as not everyone take a look in the trading area.
Hi , thanks I'll repost in build tips
Is it the stock DT-03 buggy axles or the longer Aqroshot /Blitzer /Mad Bull ones you have that are too long?
I've got spare short (stock Neo Fighter) ones and would be happy to swap for some long ones because they're a part we break sometimes. Or can just send you them.
But before you buy/fit any other parts, is this for a runner? I would pop a load of spacing on the nut end of a long axle and run it to see whether your hex adapters work well for you, because if they don't then you'll be wasting time trying to fit other parts around them. As per other thread, I went for a proper hex fitting upright and axle, which is a better engineered solution than an adapter.
With any axle length you'll find the outer face of the wheel has the potential to bind against the nut, if the adapters are designed as I think they are. However, some do apparently get on with them fine.
Hi
It was an aqroshot we've put a brushless in it , and want to put Hoosier slicks , my basic problem is what wheels for the Hoosier slicks and the how to counteract any issues caused by the addition of these slicks and the wheels
2 minutes ago, Accidentalcarper said:
Hi
OK. Well, I've the shorter axles if you want to try/swap them. Equally, they're a standard part on many cars so I suspect they'll be common and easy to get hold of. Pretty sure these are they:
https://www.makeitbuildit.co.uk/tamiya-l-r-upright-for-58184-0555059-81513
But I suspect if you can't get them running right on the long axles with some spacers, you'll probably have problems on the short ones too. I didn't like the idea of hex adapters at all, hence going another route.
