RC_Maniac 14 Posted January 10, 2022 So my first post here, thought I’d show you what I’m working on. A bit about me first I have built a few classic kits Hotshot, Vanessa’s LB and Boomerang. I no longer have them but I did build them many years ago. I picked this up relatively cheap and it was in a state however all parts are there and the body was partly cut, some holes drilled in the wrong place. The body is roughly cut and I have stripped and rebuilt the chassis. What are peoples opinions? A few times I have thought about selling it on and start something I really want to do. But every time I look at the rear end I change my mind. I’m still a bit undecided whether to finish or not. 4 Share this post Link to post Share on other sites
svenb 3735 Posted January 10, 2022 Strip and rebuild it👍 1 Share this post Link to post Share on other sites
svenb 3735 Posted January 10, 2022 When I say "strip" I do mean the Tyrrell 😳 1 Share this post Link to post Share on other sites
alvinlwh 5846 Posted January 10, 2022 Use magnetic body mounts to avoid making more holes in the shell. 1 Share this post Link to post Share on other sites
TurnipJF 9113 Posted January 10, 2022 I have one of these in my fleet, and it is certainly eye-catching, be it on the shelf or on the track. The bodyshell is really difficult to do well though, and having succeeded in finishing mine without any glaring errors, I am very reluctant to give it the beans in case I damage it. However since the body on yours is already less than perfect, you probably won't have this issue. Unless you are sure you won't be getting any fun out of running it, I'd say finish it, run it, enjoy it, and maybe get a second bodyset that you can finish to a pristine standard and use for shelf display. Share this post Link to post Share on other sites
M 800STD 586 Posted January 10, 2022 Finish it and have a play. You can always move it on when you've had enough. Share this post Link to post Share on other sites
