Zealot 397 Posted January 12, 2022 19 hours ago, Collin said: Ah, no! The weight reduction is the feature. Isn't it obvious? Why should I cut a new one then? I only want to keep the dirt out of the gears, which means I have to close the holes with something pretty light. That would be a foil most likely. A sticky one. Yeah, I'd probably still make a new one, put an end mill bit in a drill press and do blind holes or slots so dust can't get in, you get the weight reduction and from the outside it still looks like a solid plate. Share this post Link to post Share on other sites
Collin 1956 Posted January 12, 2022 @martinjpayne17.5g You are the winner of a hand full of Good Luck Congratulation. 2 Share this post Link to post Share on other sites
Collin 1956 Posted January 12, 2022 4 hours ago, Zealot said: Yeah, I'd probably still make a new one, put an end mill bit in a drill press and do blind holes or slots so dust can't get in, you get the weight reduction and from the outside it still looks like a solid plate. Shure. But that would mean doing a new plate and not doing something out of this part you already have. 1 Share this post Link to post Share on other sites
KEV THE REV 2319 Posted January 12, 2022 I overestimated the weight of the silicone infill as I didn't notice that they were slightly recessed in the holes . That's my excuse and I'm sticking to it 😉 . It does look good though Share this post Link to post Share on other sites
Collin 1956 Posted January 12, 2022 Me too. Its so light and shure looks good! Also no dirt get stuck in the holes, that was the major argument against sicky foil for me. But have a look, it was not my invention : ) Share this post Link to post Share on other sites
