Parma made a direct fit lexan body.  Rare now…
Tamiya makes the Landfreeder body, which is the same as the lexan body on the ORV Bush Devil. It should be a direct fit to the BF.
Currently on EBay, there is an old Bolink body called Sun King. It should fit the BF too.
The important part here is the wheelbase. The BF has a wheelbase of approx 252mm or 10”.
as @Sir Crashalot has linked, the Tamiya Subaru Brat lexan body is the right size to go straight on.  The original Mud Blaster used the same chassis and had an ABS Brat body, so there's even some heritage.
JConcepts make some monster truck bodies in 10.5" length, these are slightly too long for the 10" of the Blackfoot but not a million miles away, the JConcepts website is helpful as it lists the wheelbase against all their bodies
https://www.jconcepts.net/shop/bodies/110th-scale/monster-truck
this recent one is 9.5" and might be a good fit (I plan to try this on my King Blackfoot once I've finished rebuilding it):
https://www.jconcepts.net/shop/1985-ford-ranger-traxxas-stampede-stampede-4x4-body
Kamtec make a lexan version of the Sand Scorcher body, and also a thing called the "Kamtec Baja" which is similar to the Scorcher but with some alternate details.  These are the same size as the Monster Beetle body, so will fit well.  Body cut lines aren't moulded, so you can choose where to cut the body to get the look you want, roundy and smooth or angular and aggressive, etc.
https://www.kamtec.co.uk/Kamtec-Repro-Tamiya-Sand-Scorcher-Bodyshell
