I know this might be a daft question, but how do you upload a picture in the forums?
For example if you're in the parts section and you want to show a part?
Thanks for that, but I don't think it helps me much! I'm not exactly a whiz when it comes to web stuff![8)]
Hey Deano
What you need, is some webspace. Usually, the company that lets you access the net give you some, contact them for more details.
Some other people here use www.montypics.com - what you do there, is upload a picture from your computer, and link to it.
For instance, the picture of the shark below is at http://www.andy.pentangle.co.uk/
And the filename is 'shark.gif'
So the link for the whole picture is http://www.andy.pentangle.co.uk/shark.gif
If you use montypics, the address will be www.montypics.com/whatever you're picture is called.
Then, all you do is click on the icon.jpg button above where you type your posts and insert the address of the picture in between the img prompts, like this;
Then it should show up!
Check out this post;
http://www.tamiyaclub.com/forum/topic.asp?...270&whichpage=1
Right click on the pictures of the beetle, then chose properties, and you'll see the 'picture address' thing I was on about.
