Installing the diffs in their housings:
Then threading the central shaft into motor mount, front chassis support, spur gear and both diffhousings (forgot to make a picture of the assembled spur gear and mount):
Suddenly it looks much more like a car ^_^
Rear suspension drive shafts, hubs and camber links:
New hexes :wub:
I bought a whole tie-rod set because the 6mm cups weren't available at that time :rolleyes:
I continue with the front suspension with new c-hubs:
A very different parts design compared to what I know.
Added to the car with new one-way outdrives:
The result so far:
Time for the delicious red motor installation:
Then the support-battery brace located below the topdeck:
I use titanium screws here, because the shop couldn't deliver enough red screws :D
Next is the high-torque servo saver and the servo mounts:
I had the choice between the original shape grey ones and wrong shape red ones...
... went for the grey mounts and a very questionable color change via Edding (please don't kick me off TC :rolleyes:).
Last step for today: Adding the topdeck with a "billion" screws:
The yellow stabilizers have some scratches. I hope the new red endballs will cover this...
I didn't use the grubscrews, because the manual doesn't mention them. Not sure though if Tamiya forgot to add them to the manual...
In the next step I rebuild the dampers and equipped them with red aluminium parts.
This is how they would look with white springs. Of course I will use yellow springs. Strange that the yellow springs of the 53571 set are darker than the original ones...
When I tried to install the dampers, I discovered, that I would have to use insanely long screws. And what weights in worse is, that I find it is too much red involved with the red aluminium cap  on top:
Unfortunately, I need to order black plastic caps, as the ones that came with the car are badly worn and scratched...
So I continued with body posts and bumper:
The original bumper is not available at the moment (only on Ebay for too much money). That is a bit surprising, as it was used for all F103GT cars that just came out months/years ago. I decided to wait until it is in stock again and used this still era-correct Hop-Up-bumper. The bumper-base is brand new. The old one looked not much better than the chassis in front.
The bumper design really influences how I see the design of a chassis.
For later (after the dampers will be installed), I prepared the tires. I have found Sorex 28R tires and Tamiya 2mm Offset wheels in between my hobby stuff and combined them with the black Sorex insert:
The damper caps arrived and I could replace the aluminum caps:
But before I put the dampers on, I decided to go for a brand new stabilizer set to make it perfect:
Oh... and the rear damper stay had deep scratches and had to be replaced also :rolleyes:
The gloss :wub:
The chassis with dampers:
Amazing build, as always ! :)
Would you mind tell me what is the diameter of the ballstud below, please ? Or the inner diameter of the aluminium shock caps.
Thanks !
I've the red caps on mine and of a similar mind🤔
The blue caps look superb but the reds look a bit much!
I'm tempted to strip the red anodising off and fit them to a set of 49141 dampers on a TB Evo or is that sacrilege?😮
Thanks !
Thank you!
The ballstuds have a diameter of 4.8mm
@svenb:lol: As long as it looks better than the original I see no problem here. Just keep i mind, that deanodizing will take material off.
Time for some pictures of the 99% finished chassis. Some more details will be worked on plus a body will be done too.
And now with Sorex tires:
:wub:
Masking done:
Tamiya preferred to have window decals over window masking stickers for this body, so I had to do it myself...
Painting done. Fortunately no mistake happened and the tiny last rest of the gun metal paint lasted for the lower portion of the body:
Attaching the the stickers was no problem and rather easy for a Tamiya body. Unfortunately while drilling the right side mirror hole and test fitting the mirror, it fell out of my grasp and into the sink drain, were it disappeared :(  I then took the time to disassemble the whole drain pipe below the sink, but it was gone... "insert badword"! Frustrating! So with only one unpainted mirror it looks like this:
  • Sad 1
A little more work on details.
First, I added the second pair of turnbuckles to the front hub:
To make it look equal, I chose to use 6mm balls and ballcups on the inner mounts.
Then (a day later), a little more red hardware arrived:
For the full red experience:
The bumper left the chassis for the body. It wouldn't fit under the relatively short Mercedes front. The bumper plate got the correct sticker:
And last for today, I ordered a set of body parts for the second mirror and painted them era correct in bright yellow:
  • Like 12
@wtcc5that's excellent. I tell myself I don't want/need to get in to Tamiya beyond buggies and trucks. Then I see a car like yours and the itch gets stronger!
