nginsb 137 Posted March 13, 2022 I've been very much looking forward to building the Fighting Buggy Re-re, in fact this buggy was on my wish list for years after missing out on the first production run. I managed to pick one up more recently and its been sitting on the shelf waiting for the right time to build. Well, I've released there never really is a right time, life will always get in the way, and time must be made for such enjoyments. So here goes, finally, the Fighting Buggy build. I plan to do as spec, no hop-ups and likely will follow box art. This will take me a while, will post progress here for anyone interested. 11 Share this post Link to post Share on other sites
toyolien 4681 Posted March 13, 2022 Looking forward to this build. I really like these buggies. If they were slightly better runners I'd certainly have one. 1 Share this post Link to post Share on other sites
Hobbimaster 190 Posted March 13, 2022 Thread lock every screw that goes into metal! When I built mine, I strictly followed the manual. The first light run resulted in the set screws that held the front suspension arms on all loosening up, even though plenty of torque was applied. 2 1 Share this post Link to post Share on other sites
Willy iine 18806 Posted March 13, 2022 43 minutes ago, Hobbimaster said: Thread lock every screw that goes into metal! When I built mine, I strictly followed the manual. The first light run resulted in the set screws that held the front suspension arms on all loosening up, even though plenty of torque was applied. You strictly following the manual and things started falling apart does not sound good!! Good luck with the build, @nginsb! 1 Share this post Link to post Share on other sites
nginsb 137 Posted March 13, 2022 Thanks all, @Hobbimaster I'll be sure to follow this sound advice - especially since this one is going to be a runner and not just sit on the shelf. Pics to follow.. 1 Share this post Link to post Share on other sites
Re-Bugged 10153 Posted March 13, 2022 +1 for @Hobbimaster’s advice. I did that to mine, and after a few runs everything is still in tact 👍🏻 It’s a beauty when it’s done 😉 Happy building mate. 2 1 Share this post Link to post Share on other sites
moffman 5752 Posted March 15, 2022 Yep I'd go with that advice thread lock every metal to metal screw and if you are going to run it get a spare body (just the plastic part) because I can assure you the first roll (and they are very good at rolling over) will destroy the body! It's a heavy chassis for them thin roof bars to cope with! 4 1 Share this post Link to post Share on other sites
Willy iine 18806 Posted March 15, 2022 Wow, @moffman!! That is a beauty. 1 Share this post Link to post Share on other sites
Wheel_Nut 322 Posted March 17, 2022 Such a classy buggy. The first time I saw one (long ago), I was sure its worth $1000 because of all the metal parts. Share this post Link to post Share on other sites
nginsb 137 Posted March 17, 2022 Off to a bit of a slow start, but more than happy to be taking my time with this one. Rear-end is taking shape, using plenty of thread lock wherever needed (thanks for all the advice!), in fact this is the first kit that I have built that included a small amount of Tamiya gel thread lock with the kit. I usually use loctite so will have to see how this stuff stacks up. Thoroughly enjoying the build and quality of the metal parts. I chose to go with the larger 20T pinion, and can switch it for the smaller 15T once I know how it runs and what kind of terrain I might run it on. Couple of pics, more to come. 6 Share this post Link to post Share on other sites
nginsb 137 Posted March 17, 2022 On 3/15/2022 at 10:52 AM, moffman said: Yep I'd go with that advice thread lock every metal to metal screw and if you are going to run it get a spare body (just the plastic part) because I can assure you the first roll (and they are very good at rolling over) will destroy the body! It's a heavy chassis for them thin roof bars to cope with! Absolutely brilliant looking buggy, @moffman looks like you managed to find an original decal sheet for this one? Share this post Link to post Share on other sites
moffman 5752 Posted March 17, 2022 8 hours ago, nginsb said: Absolutely brilliant looking buggy, @moffman looks like you managed to find an original decal sheet for this one? Thanks very much its very appreciated! Not quite a full set of decals I had an old half set (left overs really) from back in the original days which consisted of the bf Goodrich and a few original champion plugs etc so it a bit of mix and match! Share this post Link to post Share on other sites
nginsb 137 Posted March 21, 2022 A little further with the build, managed to complete the rear damper system and front axles. I think one of the things that has always drawn me to this buggy is the unusual reserve tank system they have gone with - I can't say I've seen this implemented anywhere else and it just looks brilliant. Was a royal pain to get right with no air bubbles in the tube but with some perseverance (a little swearing and a lot of shock oil), I managed to get it free of air. Quite certain that after the first couple of bumps on the trail, air will creep in, since the reserve tank isn't all that full. The front axle and damper assembly is also a marvel, unique to anything I have built before and just top quality components. Great fun putting this together. Looks like steering end-points will be important to set on this model to keep the front wheels reasonably in sync. Moving on to installing the electronics tomorrow, will post a pic of the finished chassis once everything is installed. 5 Share this post Link to post Share on other sites
nginsb 137 Posted April 16, 2022 Big delay waiting on a few radio bits and pieces but the chassis build is finally complete and all electronics are in. Steering end-points are set and have done a basic test run around the house. Seems to run well, this is quite a weighty vehicle, may have to tighten up the rear spring or looks like it will bottom out easily. I've given the body shell a quick sand and will do a few coats of primer spray before the final colour. Still not certain if doing box-art TS-15 or something different... Has been a really enjoyable build, looking forward to adding to my collection (which is growing ever so slowly!) 5 Share this post Link to post Share on other sites
FooRCscale 6 Posted April 25, 2022 This is looking great. One on my 'to do' list. Share this post Link to post Share on other sites
Grumpy pants 4485 Posted April 25, 2022 On 3/13/2022 at 4:11 PM, Hobbimaster said: Thread lock every screw that goes into metal! When I built mine, I strictly followed the manual. The first light run resulted in the set screws that held the front suspension arms on all loosening up, even though plenty of torque was applied. The original came with cable ties for the front arms to stop them coming off, I wonder if the rere suffers the same issues ? Share this post Link to post Share on other sites
c64orinoco 667 Posted May 7, 2022 I should start work on mine, I got it over a year ago. Share this post Link to post Share on other sites
nginsb 137 Posted July 16, 2022 Finally got round to finishing the Fighting Buggy build - and about time! Was a really enjoyable build and very pleased with the outcome - I generally stuck to box-art with some modification to the roll cage (went silver rather than red) and used a slightly deeper blue for the body colour. Yet to take it out for a spin which I will do in the coming days, still enjoying just looking at it on the shelf (!). Couple of pics below for those interested. I'm contemplating my next build, which I hope will be the Wild One Blockhead Motors edition...if I can get hold of one. 6 Share this post Link to post Share on other sites
Re-Bugged 10153 Posted July 17, 2022 Nice tidy job 👍🏻 I’ve got one of these, very tempted to get another 😁 1 Share this post Link to post Share on other sites
GeeWings 2830 Posted July 17, 2022 Lovely stuff @nginsb. Such an iconic buggy. High on my list for sure! 1 Share this post Link to post Share on other sites
c64orinoco 667 Posted July 18, 2022 It looks great! A classic Tamiya car. 1 Share this post Link to post Share on other sites
Wheel_Nut 322 Posted July 19, 2022 I love the accents you made to the original colour scheme. The old models have lasting qualities that justify the purchase cost. 1 Share this post Link to post Share on other sites
