mastino 1085 Posted April 1, 2022 Hi there, Is there no alternative to the alu ball nut even from another manufacturer? I can't find it in EU shipped at good price. Thanks. 1 Share this post Link to post Share on other sites
FlyHustla 32 Posted April 2, 2022 I thought about trying a small nylock nut Share this post Link to post Share on other sites
mastino 1085 Posted April 3, 2022 14 hours ago, FlyHustla said: I thought about trying a small nylock nut Yes, it's not very easy because it lacks the space to insert the wrench but I solved it by notching the head of the nut and inserting two small washers after the spring. Then I was able to hold it in place with a screwdriver. 2 1 Share this post Link to post Share on other sites
mastino 1085 Posted April 3, 2022 I found out that the ball diff used on the TD2 and TD4 chassis ( available as spare 22025 WITH the alu ball nut) can also be used on the M07 and M08 chassis instead of the gear differential. So the opposite may be true.... This is what I have on my M07, I'm going to try to use it.... Share this post Link to post Share on other sites
Howards 457 Posted April 4, 2022 It's an M3 nut; you can wedge a nyloc M3 nut in the plastic diff nut housing that the Durga uses (D parts I think...look it up in the TD4 thread) XV01 gear diff is a direct swap. Share this post Link to post Share on other sites
mastino 1085 Posted April 4, 2022 It is smaller, M2.5 Share this post Link to post Share on other sites
Howards 457 Posted April 4, 2022 Sure. Point is you can cobble something approximate to the alu nut from a stock nut and a cheapy plastic part that Tamiya already make. 1 Share this post Link to post Share on other sites
mastino 1085 Posted April 4, 2022 2 hours ago, Howards said: Sure. Point is you can cobble something approximate to the alu nut from a stock nut and a cheapy plastic part that Tamiya already make. Yes Sir, k4 part from db01 kit. Thanks so much. 1 Share this post Link to post Share on other sites
