I discovered a way to work with E-clips that helped me a great deal.   Put your e-lips in oil.  I use shock oil.  This keeps them from flying away and kept them in place while mounting shock pistons.  Hope this helps.
Yup, works well on suspension pins etc too. I use this in combo with narrow long nose pliers and rarely suffer the dreaded e-clip 'ping' nowadays.
Meanwhile, the fairly useless Tamiya e-clip tool gathers dust in a drawer....along with a colony of long lost e-clips somewhere between the carpet and the skirtingboard :lol:
Needle nose pliers and build things in a clear plastic bag. Put your hands and the part in. If it springs off it only makes it to the bag.
11 hours ago, alvinlwh said:
Me too, but then they only come in one size.
Er no the tool comes either 2mm or 4mm sizes...I know because I have them both! 😁
I have the Dynamite one with 1.5mm-5mm (I think) in one handle.   I don't usually use it unless it's in a location I can't fit my flat nose smooth jaw pliers..
I think they used to come in the 4mm size (74033) but it is no longer available now, or at least nowhere I looked has it in stock.
Another item that could rise in price then!
I bought two of each size 10 years ago and are still using the original pair, so they do last.
Maybe another batch will be made again
I had seen them quoted at £50+ somewhere. 🤣
I have been using the Duratrax e-clip tool lately.  Much better, but can still require some persistence. A bit of oil, and the bag tip I think both sound helpful!
15 hours ago, Willy iine said:
Here’s that combo e-clip tool I have..  it’s like a pocket knife.
I usually just use my flat nose pliers though..
The go to tools are usually best
Yes, especially with my poor vision I tend to use my left thumb tip to hold the e-clip in place (on the shaft slot it is getting clipped onto) while I use the flat nose pliers, it’s less visually intensive vs lining  up the e-clip into the thin tool tip.
Plus I’m pretty clumsy I’ll end up dropping the e-clip somewhere and then need to take out my flashlight and get on all 4’s looking like a dog under my work desk.. and find something else and not the e-clip and bang my head.. :ph34r:
On 4/24/2022 at 8:01 PM, KEV THE REV said:
Not sure I'm doing it right
man-inside-plastic-bag-picture-idBD5768-001?s=2048x2048
There really is a stock photograph for everything 😂
8 minutes ago, KEV THE REV said:
Yep
and here's a photo of some stocks   :)
And another one 😀
apologies to the OP 😉
I’ve found that a magnetized flat-head screwdriver is great for placing the clips in the shaft slot, before clamping down. Especially in hard to reach areas, like the pins for suspension arms.
