Bob-T
E-Clips What a Pain
I discovered a way to work with E-clips that helped me a great deal.   Put your e-lips in oil.  I use shock oil.  This keeps them from flying away and kept them in place while mounting shock pistons.  Hope this helps.
I use Xcelite flat nose smooth jaw pliers.  Seems to keep the e-clips under control.
57 minutes ago, taffer said:
I use tamiya e clip tool! No issues then
Fancy!!!  *thumbsup*
Me too, but then they only come in one size.
Yup, works well on suspension pins etc too. I use this in combo with narrow long nose pliers and rarely suffer the dreaded e-clip 'ping' nowadays.
Meanwhile, the fairly useless Tamiya e-clip tool gathers dust in a drawer....along with a colony of long lost e-clips somewhere between the carpet and the skirtingboard :lol:
Needle nose pliers and build things in a clear plastic bag. Put your hands and the part in. If it springs off it only makes it to the bag.
Er no the tool comes either 2mm or 4mm sizes...I know because I have them both! 😁
I have the Dynamite one with 1.5mm-5mm (I think) in one handle.   I don't usually use it unless it's in a location I can't fit my flat nose smooth jaw pliers..
I think they used to come in the 4mm size (74033) but it is no longer available now, or at least nowhere I looked has it in stock.
Another item that could rise in price then!
I bought two of each size 10 years ago and are still using the original pair, so they do last.
Maybe another batch will be made again
I had seen them quoted at £50+ somewhere. 🤣
If anyone wants a brand new in pack one then I might be tempted to sell for £40 😂
I have been using the Duratrax e-clip tool lately.  Much better, but can still require some persistence. A bit of oil, and the bag tip I think both sound helpful!
Here’s that combo e-clip tool I have..  it’s like a pocket knife.
I usually just use my flat nose pliers though..
The go to tools are usually best
Yes, especially with my poor vision I tend to use my left thumb tip to hold the e-clip in place (on the shaft slot it is getting clipped onto) while I use the flat nose pliers, it’s less visually intensive vs lining  up the e-clip into the thin tool tip.
Plus I’m pretty clumsy I’ll end up dropping the e-clip somewhere and then need to take out my flashlight and get on all 4’s looking like a dog under my work desk.. and find something else and not the e-clip and bang my head.. :ph34r:
On 4/24/2022 at 8:01 PM, KEV THE REV said:
Not sure I'm doing it right
man-inside-plastic-bag-picture-idBD5768-001?s=2048x2048
There really is a stock photograph for everything 😂
8 minutes ago, KEV THE REV said:
Yep
and here's a photo of some stocks   :)
And another one 😀
apologies to the OP 😉
I’ve found that a magnetized flat-head screwdriver is great for placing the clips in the shaft slot, before clamping down. Especially in hard to reach areas, like the pins for suspension arms.
