Kol__ 3377 Posted May 31, 2022 Hi guys, Any advice on how to manage lifting stickers on a vintage Tamiya? Is there a suitable adhesive that I can use a small needle or something to carefully poke some under the lifted areas on the stickers and stick them back down? I've seen the Tamiya and other brand decal adhesives, but they all say they will soften the decal which is a concern. Although, I think that might be referring to those thinner static model decals Share this post Link to post Share on other sites
GeeWings 2830 Posted May 31, 2022 49 minutes ago, Kol__ said: Hi guys, Any advice on how to manage lifting stickers on a vintage Tamiya? Is there a suitable adhesive that I can use a small needle or something to carefully poke some under the lifted areas on the stickers and stick them back down? I've seen the Tamiya and other brand decal adhesives, but they all say they will soften the decal which is a concern. Although, I think that might be referring to those thinner static model decals Can't help much except to say that the Tamiya adhesive is indeed for slide scale model decals. 1 Share this post Link to post Share on other sites
Tamiyabigstuff 832 Posted June 1, 2022 I've rescued old decals in the past with double sided sticky tape - don't know if that would work for your issue ? 2 Share this post Link to post Share on other sites
Kol__ 3377 Posted June 1, 2022 Thanks guys, haven't found anything that I think will work yet. It's got to be safe for the sticker and for the polycarbonate, so something like super glue I don't think will work. Anyone else got any ideas? This must be an issue for other vintage owners Share this post Link to post Share on other sites
Aerobert 2143 Posted June 1, 2022 I've read that Shoe Goo should work, but I have no first hand experience. Maybe someone can confirm or deny. 1 Share this post Link to post Share on other sites
Willy iine 18805 Posted June 1, 2022 @Kol__ In my case I just buy new decals either originals or reprints.. sorry not much help, but when it comes to restoration sometimes it's best to replace than to fix with mediocre results.. unless of course one wants to have the not-perfect worn look which is also well accepted. 2 Share this post Link to post Share on other sites
Kol__ 3377 Posted June 1, 2022 Shoe goo could be a possibility, or I do have some 'Fantastic Elastic' flexible glue that could possibly work. I'm wondering if a tiny amount of it on the head of a needle placed under the edge of the sticker and then wiped flat with a cloth with some panel wipe fluid on it would both flatten it down and remove any excess glue🤔 Share this post Link to post Share on other sites
Kol__ 3377 Posted June 1, 2022 Cheer @Willy iine, these are new old stock stickers just applied, but they have some lifting in a few areas. I wonder if this is just due to age and could the problem areas be fixed and then it would be all good🤷 Share this post Link to post Share on other sites
martinjpayne 273 Posted June 1, 2022 @Kol__ You could try '3M Tape Primer 94', it's an adhesion promoter for vinyl wrap and adhesive tape. Should work if the lifting decal still has some sticky left. 1 Share this post Link to post Share on other sites
Willy iine 18805 Posted June 2, 2022 2 hours ago, Kol__ said: Cheer @Willy iine, these are new old stock stickers just applied, but they have some lifting in a few areas. I wonder if this is just due to age and could the problem areas be fixed and then it would be all good🤷 Oh I see.. that sucks. If it's not a clear area have you considered some rubber cement? Might work.. and should be removable just in case. I've had good luck with reprints too.. they use a different type of vinyl and while the reprint themselves may not be super precise or super high resolution like factory, they still look real good on the car.. my paint job is far flawed so kind of blends everything in.. 2 Share this post Link to post Share on other sites
WillyChang 1814 Posted June 2, 2022 BiTD yeah ppl used superglue to paste down lifting decal corners... but it kinda scarred the lexan too. Microsol & similar bottled decal solvents/adhesives are for Waterslide decals to soften the media & let it stretch around tight curves better. Won’t do anything for RC vinyl decals. Assuming you value to lexan as much as the decal, clean off all dirt from under the decal & try tacking down lifted edges with an acrylic clear or even nail varnish. Apply it on, wait till it mostly flashes off till tacky then press down & hold until it’s set. Original adhesive on vinyl media is pressure-sensitive, either water based or solvent based. Most RC decals usually solvent based adhesive so we can use mist of water to allow a bit of give during application. Or better still pros use “vinyl lube” (pretty much water with a bit of IPA and maybe a touch of ammonia or detergent) which activates the adhesive for even more aggressive bite once applied. Adhesion issues is often caused by contaminants and oils/silicones residue from skin contact... so keep everything squeaky clean & oilfree whilst decalling. Don’t forget fresh steel blades have a oil coating at factory to deter rust so degrease those too. 1 Share this post Link to post Share on other sites
mtbkym01 4008 Posted June 2, 2022 What about a bit of heat from a hair dryer/heat gun, I’ve had success in the past with lifting decals and heat, seems to reactivate the adhesive 1 Share this post Link to post Share on other sites
superted 121 Posted June 26, 2022 This might sound silly but Pritstick works and its not got any harsh chemicals to damage old stickers or paint. 1 Share this post Link to post Share on other sites
